Re: how often rebuild carb?
[Re: Exit1965]
#1907977
09/07/15 01:05 PM
09/07/15 01:05 PM
RapidRobert
I've had my carb on for about 6 years now. I think you are fine tho ethanol does raise hell. A plan I always wanted to try was that Gumout? commercial decades ago which said "soup up your eng, here is the soup" & they plumbed a can of it to the carb inlet & ran it on that. I think a high grade solvent like that would thoroughly clean gasoline deposits in every nook and cranny (& no need to take carb apart) unless it ended up messing with the AP plunger or needle neoprene on down the line.
