360 Magnum Valve Springs #190746
01/11/09 07:22 PM
01/11/09 07:22 PM
Caldwell. Id
E
edbux Offline OP
edbux  Offline OP
E
Caldwell. Id
With the Mopar Performance springs PN P2549464; would the stock retainers be sufficient? Or I should use??
1967 Dart 270 360/727
Re: 360 Magnum Valve Springs [Re: edbux] #190747
01/11/09 08:44 PM
01/11/09 08:44 PM
Lake Orion, MI
goldduster318 Offline
Lake Orion, MI
I assume you mean P5249464. I believe these are the R/T springs I used, and the stock retainers don't fit (these are not beehive springs...the stock ones are). you will need the P4452032 retainers or the retainers from a 2.2 or 2.5 OHC 4-cyl
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
