Where does the Fuel Sender Wire Go... #1907039
09/05/15 06:57 PM
09/05/15 06:57 PM
Spokane Valley, WA
Big Bad Bee Offline OP
Spokane Valley, WA
…Thru the trunk floor on a 70 Bee. I have a new trunk floor and it has no holes in it. I can easily resort to putting it just about anywhere since this is a Resto-Mod, but I'd just as soon put it in the best place… Where the factory did. Pix will get you life long friendship.
Thanks, Lindy
I’m listening.
Re: Where does the Fuel Sender Wire Go... [Re: Big Bad Bee] #1907056
09/05/15 07:19 PM
09/05/15 07:19 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
i can't get you a pic but on my 69 RR the wire comes out of the rear lights harness and goes through the smallish grommet closest to the seat on top of the 'hump'. drivers side of course
click this link and enlarge the pic and you'll see what i mean
http://www.partsgeek.com/gbproducts/AC/1...CFYGRHwodpbEKHQ
Re: Where does the Fuel Sender Wire Go... [Re: Big Bad Bee] #1907127
09/05/15 09:11 PM
09/05/15 09:11 PM
Philadelphia PA
Pynzo Offline
Drugs are bad
Pynzo  Offline
Drugs are bad
Philadelphia PA
'70 Bee directly above the sender. I can't get you a pic I'm too far from the car. Wait till next weekend I've got original floors still.
Re: Where does the Fuel Sender Wire Go... [Re: mikemee1331] #1907132
09/05/15 09:19 PM
09/05/15 09:19 PM
Spokane Valley, WA
Spokane Valley, WA
The image and your description are perfect! Thanks!! wave
I’m listening.
Re: Where does the Fuel Sender Wire Go... [Re: Big Bad Bee] #1907138
09/05/15 09:34 PM
09/05/15 09:34 PM
Just me if I was to add one I'd drill the trunk floor as far forward as reasonably possible so as to keep any jostling of items in the trunk from ever severing/chafing/catching that blue wire over time. EDIT I'd want it over the hill/down further rather than just slung sideways on that forward flat "shelf" under the package tray like I've seen some & actually I'd think that'd put it closer to the sender
