Need counterweight dimensions - 340: 4" stroker Crank #190682
01/11/09 05:51 PM
01/11/09 05:51 PM
Central New York
DropTopE Offline OP
DropTopE  Offline OP
Central New York
If somone has the diameter (radius) swing for the 340 4" stroker crank I would really appreciate you posting them for me. I just did the initial set in of the 340 block into my Hot Rod and I will have to notch the pan to clear the steering rack in its present position. Enough for me to worry about hitting the crank. The rack lines up right under one of the counter weights. I don't have my crank yet and know that I will have to do intensive fit up once the motor gets built, but for now I would like to find out how much trouble I am really in. Attached picture shows about how close. Theere is about 4 inches of space from the rack to the pan mounting surface.
Re: Need counterweight dimensions - 340: 4" stroker Crank [Re: DropTopE] #190683
01/12/09 05:59 PM
01/12/09 05:59 PM
Central New York
DropTopE Offline OP
DropTopE  Offline OP
Central New York
Somebody must have one of these that they can measure for me. Looking for the swinging radius of the crank counterweight. Particularly for the front one, but I think they are all the same. Say for an eagle forged crank with 4.00" stroke.
