Re: Pertronix or Mopar Performance Electronic Ignition
[Re: MidPenMopar]
#190602
01/11/09 04:49 PM
01/11/09 04:49 PM
Posts: 4,102 Cochise County Arizona
SPWC
I replaced the points on my 65 Fury Wagon with a Pertonix ignitor kit. Very simple install. Pull the points and condensor,pop in the pickup plate and collar,gap them with the little plastic piece they provide. Install the the rotor provided. Run the Black Wire to - on the coil and red to + on the coil. Reinstall the distributor cap and your done.Also a good idea to replace the coil with a higher output one such as a Flamethrower.I didnt replace the coil on my Fury and it still runs ok,but has a tendency to occasionally fuel foul the plugs since the conversion.
Good idea to always carry the points and condensor in the glovebox to convert it back over in case the ignitor fails and leaves you stranded as Pertronix arent normally available over the counter at most parts stores.
The Mopar Performance kit,while more expensive and requiring more wiring,is probably a better choice,IMO.
You have to install an electronic distibutor,the wiring harness and control box. All these parts are available over the counter at parts stores,if the parts in the kit should fail on a road trip.
[Re: FC7AARcuda]
#190603
01/11/09 05:08 PM
01/11/09 05:08 PM
Posts: 18,159 Mass
DAYCLONA
Mass
Pertronix,....no headaches, if you follow the instructions, best to delete the ballast resistor from the system, and DO PURCHASE their Flamethrower coil, (black or chrome avl, looks stock) as it has a different ohm rating to work with their Hallcell trigger, if you can install point(s) and tune a car, you can install a Pertronix,....I would recommend you purchase a rebuilt point distributor, so your install/conversion starts with a "new" dist,.....if you decide to eliminate the ballast(smart move) you should just buy a double ended Stak-on electrical blade connector to tie the 2 ballast connectors together,.....recheck your timing, as the Pertronix install will bump it up a little, if you perform it in the car with out changing the dist current timing position, and if your timing is already highly advanced, and your car may not start, and you'll be pulling your hair out wondering why,......the Mopar Performance ignition set up is just a redundant MESS, that actually impeeds your engines full potential, the system is designed to modulate the spark, basicaly retarding the ignition,.....the first install I ever performed of a Pertronix, I noticed instantly quicker ignition while cranking, more advance timing out of the same dist, no more carbon arching in the caps, no high rpm ignition break up.......until somethimg better comes along, I wouldn't use anything else IMHO
[Re: DAYCLONA]
#190605
01/11/09 05:20 PM
01/11/09 05:20 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
the mp conversion does get you a new distributor, where as how many miles does you distributor has on it..ever check how much wear there is in the bushing in the shaft?
mp does have a chrome box that is available..since most people believe that the orange box retards the timing in higher rpm..
also the new mp distributor has a faster advance curve for additional performance...and the vacuum advance can be adjusted.
there is another thread on here about HEI ready to run distributors that require only two wires to hook up and run.
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: 70AARcuda]
#190606
01/11/09 05:24 PM
01/11/09 05:24 PM
Posts: 18,159 Mass
DAYCLONA
Mass
That's why in my post, I recommended a rebuilt distributor, to perform the Pertronix conversion,....start off with good parts, follow the instructions, and you'll have no problems
[Re: DAYCLONA]
#190607
01/11/09 06:23 PM
01/11/09 06:23 PM
Posts: 1,482 Lake Orion, MI
goldduster318
Lake Orion, MI
I put the MP type kit (had a very nice distributor & a stock module already, so I bought the $20 wiring harness), and as long as you're comfortable cutting one connector off your stock harness, and crimping/soldering 2 connectors, and drilling 2 holes to mount the box, its an easy install. It took me LESS than an hour, and if you use an aftermarket coil, you don't need the ballast resistor with a 4-pin module. It certainly ran better than the points ignition ever did.
Removing/re-installing distributors in at least a small block is a 5 min job. I turn the crank over to TDC, take a picture of the relative location of the vacuum can and rotor position, and then I just use the same cap and rotor. Mine fired right up.
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
