Where to find P/S brackets?
#1905784
09/03/15 05:04 PM
09/03/15 05:04 PM
Posts: 105 Ontario, Canada
D149
Ontario, Canada
I want to replace the TRW P/S pump on my '68 Valiant (273) with a Saginaw pump that I have. Does anyone reproduce the correct brackets for mounting the Saginaw pump on the cast iron water pump of the early small blocks? I haven't been able to find any. Thanks Dave
1968 Valiant Signet 4dr. 273 4spd 1969 Road Runner 383 4spd 1969 Barracuda 318 auto 1970 Dart Swinger 340 4spd 1975 Cordoba 400-4bbl 1988 Caravelle 318 Auto 1999 Dakota R/T 2000 Viper GTS 2001 Ram 2500 Diesel 6spd 2018 Dodge Challenger GT (Winter beater!)
Re: Where to find P/S brackets?
[Re: D149]
#1905959
09/03/15 10:56 PM
09/03/15 10:56 PM
Posts: 75,082 U.S.S.A.
JohnRR
U.S.S.A.
I want to replace the TRW P/S pump on my '68 Valiant (273) with a Saginaw pump that I have. Does anyone reproduce the correct brackets for mounting the Saginaw pump on the cast iron water pump of the early small blocks? I haven't been able to find any. Thanks Dave How does a company reproduce a part that didn't exist ?
[Re: JohnRR]
#1906063
09/04/15 12:22 AM
09/04/15 12:22 AM
D149
Ontario, Canada
I want to replace the TRW P/S pump on my '68 Valiant (273) with a Saginaw pump that I have. Does anyone reproduce the correct brackets for mounting the Saginaw pump on the cast iron water pump of the early small blocks? I haven't been able to find any. Thanks Dave How does a company reproduce a part that didn't exist ? My Dad's '69 Barracuda 340 (with A/C) has a saginaw pump on it. Pretty sure it's original.
[Re: D149]
#1906392
09/04/15 04:45 PM
09/04/15 04:45 PM
JohnRR
U.S.S.A.
I want to replace the TRW P/S pump on my '68 Valiant (273) with a Saginaw pump that I have. Does anyone reproduce the correct brackets for mounting the Saginaw pump on the cast iron water pump of the early small blocks? I haven't been able to find any. Thanks Dave How does a company reproduce a part that didn't exist ? My Dad's '69 Barracuda 340 (with A/C) has a saginaw pump on it. Pretty sure it's original. If that is the case then check Bouchillon
