Starter Relay #1905470
09/03/15 02:06 AM
09/03/15 02:06 AM
Mesa, Arizona
dart4forte Offline OP
Mesa, Arizona
Anyone tell me how to bypass the neutral safety switch. My ignition switch is giving me problems and I need to go out and seat the rings in my fresh motor. Looking for a temp fix until I can go into a detailed fix of the starting system.
Abe Lincoln
Re: Starter Relay [Re: dart4forte] #1905490
09/03/15 02:45 AM
09/03/15 02:45 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Put a wire from the relay lead that the safety switch runs to and run that to ground. That will bypass the switch.
Don't forget that it is bypassed and you can now start in gear.
Re: Starter Relay [Re: dart4forte] #1905501
09/03/15 03:03 AM
09/03/15 03:03 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
The "G" terminal on the relay needs to be grounded.
Re: Starter Relay [Re: Jim_Lusk] #1905505
09/03/15 03:28 AM
09/03/15 03:28 AM
Mesa, Arizona
Mesa, Arizona
Thanks Jim
Abe Lincoln
Re: Starter Relay [Re: dart4forte] #1905592
09/03/15 11:56 AM
09/03/15 11:56 AM
OT you might read "breakin secrets" at www.mototuneusa.com
