yes by pass the ballist for a full 12 volts at the coil,ypu can pull the guts out of your ballist and solder the ends on a standed #10 wire and put it back inside the porcilan then it all still looks stock,thats another good thing with the pertronix..its easy to hide that you have it and it all looks stock under the hood
you can unplug and remove the ecu also...I allways just leave it plug up and there my self
I have cliped all the un-used wirers off the harnes before also...like the 2 wire plug for the old dist and the choke assist wires too
but thats when I strip one all down,you just need the one keyed hot wire and a full 12 volts for it to work
