4.7 magnum a good engine?
#1903956
09/01/15 01:05 PM
09/01/15 01:05 PM
Posts: 1,521 Tacoma, Washington USA
Adam71Charger
Im looking for a newer work truck. A friend of mine owns a car lot that has a 2007 Dakota SLT 4x4, 187k miles, with the 4.7 Magnum, an engine I have no experience with. Hell give me a great price on it, but it is high mileage and I dont know anything about these engines, or trucks actually. Are they durable, long lasting?
Re: 4.7 magnum a good engine?
[Re: Adam71Charger]
#1903994
09/01/15 01:24 PM
09/01/15 01:24 PM
Posts: 28,067 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
After that many miles, if the engine is still strong it likely won't go to pieces.
It's always a crap shoot with high mileage vehicles.
[Re: Adam71Charger]
#1904000
09/01/15 01:26 PM
09/01/15 01:26 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
It'll be ok in a Dakota that doesn't tow much. I had one in an 03 quad cab dakota. not powerful. not that fuel efficent, but all in all, a decent small truck motor. needs lots of RPM to tow any weight though.
mine started ticking at 120k miles. it was a lash cap near #6 or #8. I just drove with it like that and had no drivability or oil pressure issues.
**Photobucket sucks**
[Re: Adam71Charger]
#1904061
09/01/15 02:02 PM
09/01/15 02:02 PM
Posts: 4,848 Memphis
HemiRick
Memphis
i just had to replace the timing chains in one of these motors at 197K miles as they had become noisey
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: Adam71Charger]
#1904096
09/01/15 02:38 PM
09/01/15 02:38 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
I have 3 blown up 4.7s in my shop right now and we can not find usable replacements, lots of other blown up 4.7s in the JY but no running ones. None of them have 200,000 yet.
[Re: Adam71Charger]
#1904258
09/01/15 05:59 PM
09/01/15 05:59 PM
HotRodDave
Kalispell Mt.
3.9 is very reliable and gets about 2 more MPG than the V8 if gear ratios are the same but you got to watch most V6 got 3.92 gears and V8s typically got 3.55s.
[Re: Adam71Charger]
#1904500
09/01/15 10:38 PM
09/01/15 10:38 PM
Posts: 12,093 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
The 4.7 equates to about 273". Does anyone think that even with today's efficiencies that 273"s is enough in a truck? The 4.7 is not a bad engine, I just think that they ask too much of it.
And the 3.9 is in a similar circumstance. Not a bad motor, but is just too small to do what they want it to do, day in and day out. Personally, I would much rather have the GM 4.3. I am not a Chebby fan, but the 4.3 has proven to be a reliable and powerful motor in the chassis that GM has put it in. The 3.9 has not.
I would NOT buy a high mileage 4.7 in a truck. Just my opinion. The 2.0, 2.4, 3.3, 3.8 and the 5.7 are very good engines by any standard. However, the 2.7, 3.9, and 4.7 engines have not had as good a service record.
Master, again and still
[Re: DaveRS23]
#1904707
09/02/15 08:01 AM
09/02/15 08:01 AM
Posts: 10,847 Oakdale CT
gdonovan
Oakdale CT
The 4.7 equates to about 273". Does anyone think that even with today's efficiencies that 273"s is enough in a truck? Yes, depending on what you are doing. I used my 2001 work truck (GM 4x4 with the small V8) to tow an open deck trailer with a car on it and a full bed with 4 engines and 6 transmissions from Maine to CT. It did the job without much complaint, I was impressed. As a retired Chrysler dealer tech I'd not own a vehicle with a 4.7. You will have people sing its praises about how they have "xxx" number of miles on them but they are the exception not the rule. The fact you can't find a good one in the yards tells you all you need to know.
"I think its got a hemi"
[Re: Adam71Charger]
#1904933
09/02/15 02:53 PM
09/02/15 02:53 PM
Posts: 20,179 Park Forest, IL
slantzilla
Park Forest, IL
In that year range they all will be fairly similar, just try to find one with the lowest miles and best maintenance records. Personally I would go for a 5.9.
[Re: Adam71Charger]
#1905013
09/02/15 04:18 PM
09/02/15 04:18 PM
Posts: 1,819 Middle of A Field
OrangeProwler
Middle of A Field
The later 08+ 4.7 would the one I would go after. Over 300hp and with a programmer you could pickup another 20-30hp. The head design on those engines is different using 16 plugs compared to 8 plug for the prior version. I have an 04 4.7 in a 4x4 Ram. It's 235hp and 295 pounds of torque. It does the job but, needs to be revved. Even when its revved its still slow. The 4.7L is 287 cubic inches and a SOHC engine. Looks like an older Mercedes Benz 4.5L V8 in a way.
With that 4.7L I'd have some reservations. The 1st thing is oil changes. The oil jets/passages in the 4.7L V8 are small. If its had anything less than Mobil 1 or a good quality synthetic/oil filter I would pass.
The other thing with the 4.7L V8 is overheating. If it's been overheated more than once and severely overheated then it's time to replace the head gaskets. In addition, their maybe other problems such problems with the heads. Overheating the heads on the 4.7L also cause warpage problems or cause the guides to fail and pretty toast the engine.
The other things I don't care much about the 4.7L V8 is the exhaust manifold studs. Even new OEM replacements will break causing an leak. The 4.7L has three timing chains. With that mileage I would suspect to replace those along with the guides. As someone else already mentioned a sludgy engine can cause a lash adjuster failure on these engines. I'm not sure about the newer 08+ engines which got a little redesign in the cylinder head department.
Would I recommend a 4.7L V8 knowing what I know now? Probably not. Mine is already getting tired at 171k miles In fact, Chrysler just phased these engines out of production about 2 years ago. And when mine let's go I'm going with a 5.7L Hemi or something else. They're tons of aftermarket support for the newer Hemi plus it is OHV design.
[Re: Adam71Charger]
#1905223
09/02/15 08:11 PM
09/02/15 08:11 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
I had a 2002 Ram quad cab with a 4.7. That truck never gave me a bit of any problem. Traded it in at 205,000,and the new owner is driving it with no problems.Still has the OEM water pump on it,and I never had to pull the valve covers either,in fact I never touched the engine.I did maintain it,oil and filter every 4-4500,I used 15w40 in it after it hit 9000 miles.
[Re: Adam71Charger]
#1905393
09/03/15 12:16 AM
09/03/15 12:16 AM
Posts: 2,415 Connecticut
Ron_M
Connecticut
I didn't have much luck with my 02 Durango 4.7l, 80K on the clock. Tried to keep up with it's needs and it nickeled and dimed me to death. I don't miss it.
Common sense is a flower that does not grow in everybody's garden
[Re: Adam71Charger]
#1905453
09/03/15 01:34 AM
09/03/15 01:34 AM
Posts: 10,570 Freeport IL USA
poorboy
Freeport IL USA
Somewhere in the late 90s/early 2000s the 3.9 was replaced with a 3.7. The 3.7 & the 4.7 are of the same design with the same issues, from what Ive read.
A 3.9 works on a standard cab truck caring lighter loads. If you load up your truck or need more then a standard cab, the 3.9 will be under powered and the gas mileage will be worse then a 5.2 or 5.9.
A 5.9 is a bit harder on gas then a 5.2, but its a lot more fun. Either in a Dakota would make a great work truck. Like said earlier, lower miles, best upkeep will get you a better truck. Make sure the bottom is not rusty.
Once past 2001 or 2002, the Dakota started putting on a lot of weight and grew in size. If your after a newer truck, a full sized truck might be a better buy. The original design of the Dakota was a great size, but unfortunately, as the years progressed, they moved farther and farther from the original design until there really wasn't much difference in size, options, or price between it and its full size brother. Gene
