'Cuda trunk lip corners #190338
01/11/09 10:15 AM
01/11/09 10:15 AM
Northern MN
1E2C Offline OP
1E2C  Offline OP
Northern MN
A while back I saw someone was producing patch panels to redo the upper/forward corners of the trunk lip at what was a pretty decent price. Now that I'm wanting to actually buy the parts all I can find is a replacement panel to replace the entire right or left side trunk lip, and of course at about 3 times the price of just the corners. Does anyone know if just the corners are still available and from whom or am I stuck buying the larger piece and trimming off what I don't need?
Thanks,
Mike
Re: 'Cuda trunk lip corners [Re: 1E2C] #190339
01/11/09 04:57 PM
01/11/09 04:57 PM
GMP440 Offline
GMP440  Offline
Check with AMD. They sell either the corners seperately or are part of the trunk gutter assembly. If AMD's are part of the trunk gutter assembly just cut off what you need and weld on.
Re: 'Cuda trunk lip corners [Re: GMP440] #190340
01/11/09 05:07 PM
01/11/09 05:07 PM
GMP440 Offline
GMP440  Offline
Here is the pic of the trunk gutter from AMD. The corner is part of the trunk gutter assembly.
Cut corner off and weld in.
Re: 'Cuda trunk lip corners [Re: GMP440] #190341
01/11/09 05:27 PM
01/11/09 05:27 PM
Northern MN
1E2C Offline OP
1E2C  Offline OP
Northern MN
Yeah, I saw those, it just hurts to spend 75 bucks for each side and throw most of it away when I know I saw just the corners not so long ago for around 20 bux each. (I'm a cheapskate, yanno?)
Thanks though,
Mike
Re: 'Cuda trunk lip corners [Re: 1E2C] #190342
01/13/09 12:25 PM
01/13/09 12:25 PM
Northern MN
1E2C Offline OP
1E2C  Offline OP
Northern MN
One more shot.
