1942 special deluxe #190220
01/11/09 01:23 AM
01/11/09 01:23 AM
Anonymous OP
Anonymous OP
Hi all.
I am in works to buy a 42 special delux for 2500...
There's no rust. Car looks pretty solid. All straight. Haven't seen much about this model or year. Anyone know if that's a decent deal? Car doesn't run but he said it did when he parked it 8ish years ago. Looks to have original flat head six. All interior is there. All trim.
Still 6 volt
He did say it needs a new master cylinder and wheel cylinders for brakes. As well as all new tires. Hasn't been driven in 8 years.
Here are some pics... Its dusty.. not rusty
Re: 1942 special deluxe #190221
01/11/09 12:01 PM
01/11/09 12:01 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
42s are rare because of the production stoppage to support the war effort. The car was probably an old military vehicle. Post some pictures when you can.
Re: 1942 special deluxe #190222
01/11/09 12:12 PM
01/11/09 12:12 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Aloha!
A 1942 is pretty rare due to production halting due to the Dec. 7th 1941 issues...
http://www.allpar.com/old/wartime.html
http://www.hemmings.com/hcc/stories/2005/11/01/hmn_feature4.html
pictures
http://images.google.com/images?hl=en&am...sa=N&tab=wi
EDIT: That's a pretty darn good price, they seem to start there and go up they are low supply, but also not very high demand.
You can find out more about the post war cars (which are very similar) on the P-15 page here
http://www.merc583.addr.com/mopar/index.html
Good luck with it!
Re: 1942 special deluxe *DELETED* #190223
01/11/09 05:16 PM
01/11/09 05:16 PM
Anonymous OP
Anonymous OP
Post deleted by 42PlyDeluxe
Re: 1942 special deluxe *DELETED* #190224
01/11/09 05:17 PM
01/11/09 05:17 PM
Anonymous OP
Anonymous OP
Re: 1942 special deluxe *DELETED* #190225
01/11/09 05:18 PM
01/11/09 05:18 PM
Anonymous OP
Anonymous OP
Re: 1942 special deluxe *DELETED* #190226
01/11/09 05:18 PM
01/11/09 05:18 PM
Anonymous OP
Anonymous OP
Re: 1942 special deluxe *DELETED* #190227
01/11/09 05:19 PM
01/11/09 05:19 PM
Anonymous OP
Anonymous OP
Re: 1942 special deluxe *DELETED* #190228
01/11/09 05:19 PM
01/11/09 05:19 PM
Anonymous OP
Anonymous OP
Re: 1942 special deluxe *DELETED* #190229
01/11/09 05:23 PM
01/11/09 05:23 PM
Anonymous OP
Anonymous OP
Re: 1942 special deluxe *DELETED* #190230
01/11/09 05:23 PM
01/11/09 05:23 PM
Anonymous OP
Anonymous OP
Re: 1942 special deluxe *DELETED* #190231
01/11/09 05:24 PM
01/11/09 05:24 PM
Anonymous OP
Anonymous OP
Re: 1942 special deluxe #190232
01/11/09 05:43 PM
01/11/09 05:43 PM
Sorrento, BC, Canada
4speeds4me Offline
4speeds4me  Offline
Pretty sweet...and suicide rear doors too. How much more could you ask for?
2 Demons...no, not my kids!
Re: 1942 special deluxe [Re: 4speeds4me] #190233
01/11/09 05:52 PM
01/11/09 05:52 PM
Anonymous OP
Anonymous OP
I could ask for the parts needed to make it run
Re: 1942 special deluxe #190234
01/11/09 07:06 PM
01/11/09 07:06 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
That's in great shape!
What are you going to need to get it running?
Tune-up stuff should be pretty easy, and fluids are normal.
Brake stuff may take a bit longer, but fairly easy to find. Check the links I posted.
Find out how long it's been sitting; you want to wake it up without causing any damage. If you have to drop the gas tank to clean it, it's better than filling it first. You also don't want to loosen up all the junk in the lines just to push it into the carb. There is a water distribution tube that goes inside the block's coolant passages. Better to check it before you get it hot. It would probably be a good idea to prelube it and rotate it by hand with fresh oil before just hitting the starter.
Another issue with the older cars mentioned on the P-15 site is wiring. There is only one fuse for the whole car (headlight circuit). Better to inspect all the wiring before installing that new 6V battery. This is also a 6 volt positive ground vehicle, so don't go jumping it with a 12V negative ground car, unless you follow the instructions very carefully. Good luck waking the slumbering Mopar!
Re: 1942 special deluxe [Re: RodStRace] #190235
01/11/09 09:00 PM
01/11/09 09:00 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Re: 1942 special deluxe [Re: RodStRace] #190236
01/11/09 10:05 PM
01/11/09 10:05 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Man, that is one sweet looking ride! I'm not real into 4 doors, buy I could go for that one.
Being a hot rodder, I would have to update that to disc brakes with an updated master, a more modern rear axle, and add a bit more power to the flathead 6. I'd keep the original parts, for who ever might own it after me, but I want good brakes and a bit more power. Add in some radial tires and cruise that thing for ever. (well, OK for 4 or 5 years until I got tired of it. ) Gene
Re: 1942 special deluxe #190237
01/12/09 01:45 AM
01/12/09 01:45 AM
Anonymous OP
Anonymous OP
Thanks for all the links. Much appreciated. He said the brakes were grabbing. And that I should replace the cylinders. I did put the drums back on today. Filled the tires with air and put her back on the ground for the first time in eight years yay. Hopefully tomorrow I will be getting aaa to tow her home.
Then I can start documenting and clean her up. I'll post pics of eeverything for those who care.
You should see the engine bay.
Re: 1942 special deluxe #190238
01/12/09 08:27 AM
01/12/09 08:27 AM
Oh
RacerGofKGB Offline
Got The Big One
RacerGofKGB  Offline
Got The Big One
Oh
You need to buy the car. If you dont buy it, then you will have to change your screen name.
Re: 1942 special deluxe [Re: RacerGofKGB] #190239
01/12/09 10:01 AM
01/12/09 10:01 AM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
i stock distributor cap,rotor,points, condenser, should have wheel cylinder rebuilt kits, might have brake master cylinder rebuild kit,,,,
