You guys were right about the bigger carb
#1899193
08/25/15 05:00 PM
08/25/15 05:00 PM
Posts: 11,725 Portage,michigan
B3422W5
Portage,michigan
It's faster with the 950 over the 750. Got it to go 12.11 with the new 750( air was terrible) Ended up at 11.91 with the 950. Best 60 foot to date with car on that pass. Didn't have a chance to jet it down, know I left ET on the table, but with moving timing around and swapping carbs around it was enough for one night.
Car acts funny with the 750, doesn't rap crisply, accelerates lazy. Put the 950 on, in the water box car raps so quick it hits the shift light ultra fast, sounds different even, accelerates faster.
Re: You guys were right about the bigger carb
[Re: B3422W5]
#1899197
08/25/15 05:08 PM
08/25/15 05:08 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Car acts funny with the 750, doesn't rap crisply, accelerates lazy. Put the 950 on, in the water box car raps so quick it hits the shift light ultra fast, sounds different even, accelerates faster. Thats the thing with the SB.... they love the air... then you just put enough fuel to it to burn right to make the power... but they love air
[Re: B3422W5]
#1899214
08/25/15 05:42 PM
08/25/15 05:42 PM
Posts: 1,784 PA
W5DART66
PA
Car acts funny with the 750, doesn't rap crisply, accelerates lazy. Put the 950 on, in the water box car raps so quick it hits the shift light ultra fast, sounds different even, accelerates faster. LOL ......
[Re: B3422W5]
#1899251
08/25/15 06:42 PM
08/25/15 06:42 PM
B3422W5
Portage,michigan
After the season think i am going to stick 4.56 gears in it, and remove these 4.10's. Trapping at barely 6k at the stripe Problem is this hydraulic cam and springs are going to be maxed at 6500. Might put a solid in it, have to talk to Dwayne about that...
[Re: Hot 340]
#1899253
08/25/15 06:47 PM
08/25/15 06:47 PM
B3422W5
Portage,michigan
What was the reason it wouldnt rev? I assume its fixed? Timing was off, guys at a shop next door used a fancy setup( digital deal) and set it wrong. I went and bought my own light. Plus this little motor doesn't have a lot of grunt from a roll in high gear. Had too high of fuel pressure( 8), changed it to 6.5, new plugs, and the 750 shiny new carb is a dog
[Re: RV2]
#1899260
08/25/15 06:58 PM
08/25/15 06:58 PM
B3422W5
Portage,michigan
Interested in your combo would you share more info? 30 over 318 magnum Lightened 340 crank, scat rods, diamond Pistons Magnum RT heads, 2.02 valves, massaged. Dual plane, air gap knock off 950 proform 231-238@50 hydraulic cam, 595 gross intake lift 10.44 compression Cheapy 99 dollar 1 5/8 headers into dyno max bullets 8 inch convertor 904 4.10 gear, 28 inch tire, 3415 with me in it, flat hood. 71 New Yorker rear shocks, CE 3 way fronts, shift at 6200, trap at 6000
[Re: B3422W5]
#1909808
09/10/15 11:28 AM
09/10/15 11:28 AM
Posts: 17,924 Akron, Ohio
ProSport
Akron, Ohio
Nice run! I vote for the solid cam and more gear!
[Re: B3422W5]
#1909836
09/10/15 12:13 PM
09/10/15 12:13 PM
Thumperdart
State of confusion
Car acts funny with the 750, doesn't rap crisply, accelerates lazy. Put the 950 on, in the water box car raps so quick it hits the shift light ultra fast, sounds different even, accelerates faster. They usually are................good deal and it would be even faster totally dialed in........the carb that is.
[Re: B3422W5]
#1909869
09/10/15 01:04 PM
09/10/15 01:04 PM
Posts: 13,385 Marion, South Carolina [><]
an8sec70cuda
Glad you got that figured out!
[Re: B3422W5]
#1909886
09/10/15 01:27 PM
09/10/15 01:27 PM
B3422W5
Portage,michigan
Still puzzles me about the 750 not working. Almost think there is internally something wrong with it. Shouldn't be that much difference( and I know the 950 is a wee bit fat) Just surprised the bigger carb is so much better. I would have thought even a 650 would supply enough fuel. Learn something every day..... Lol
[Re: B3422W5]
#1909902
09/10/15 01:44 PM
09/10/15 01:44 PM
Thumperdart
State of confusion
My stock stroke 360 was quicker and faster every time I went bigger and ended up w/an 850 speed demon(flowed 930)and went a best of 11.88 @ 114 mph at 3200+ lbs at L.A.C.R.`s high elevation track.........
[Re: Monte_Smith]
#1909905
09/10/15 01:45 PM
09/10/15 01:45 PM
B3422W5
Portage,michigan
AIR FLOW........the fuel is not the issue.........LOL!!!! I know, more air, more fuel, equals more power. My point was at 6200 rpm max, how much air can 323 inches gulp in and burn. My guess is some carb guru could probably put a 650 on this little motor and get it to run better than I have gotten it to run with a 950... Lol
