Re: Oil Return Hole - Coolant Cavity Cross Contamination On Hemi
[Re: dm69charger]
#1898725
08/24/15 11:46 PM
08/24/15 11:46 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
I would tube it like you do with push rod/port interference. Get a tube the size of the drain, and epoxy it in place.
[Re: dm69charger]
#1898953
08/25/15 11:52 AM
08/25/15 11:52 AM
Posts: 2,663 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
You might have to drill or ream the hole to a certain size and then drive the sleeve in.
2011 Drag Pak Challenger
[Re: dm69charger]
#1899115
08/25/15 03:32 PM
08/25/15 03:32 PM
Posts: 43,240 Bend,OR USA
Cab_Burge
Marine Tex It is has been used in the boating industry for years for gas tanks to hulls of all types IHTHs That or Loktite Green sleeve retainer
