06 ram 2500 4x4- removing front brake rotors #1898389
08/24/15 03:43 PM
08/24/15 03:43 PM
md
mopars4ever Offline OP
md
What would be the safest way to remove my front brake rotors on my 06 ram 2500 4x4? They are pretty darn rusty and if they are anything as bad as my back rotors then I`m in for a work out. I was thinking if I beat on them them it may hurt the hub bearing. I`m putting on new rotors so I`m not worrying about saving them. How hard would it be to cut them off? Any other ideas?
Re: 06 ram 2500 4x4- removing front brake rotors [Re: mopars4ever] #1898562
08/24/15 07:51 PM
08/24/15 07:51 PM
Cleveland Ohio
sportfury70 Offline
sportfury70  Offline
Cleveland Ohio
Few blows with a 4lb hammer should do it.
Rears probably hung up on rust inside parking brake drum.
Re: 06 ram 2500 4x4- removing front brake rotors [Re: sportfury70] #1898852
08/25/15 03:32 AM
08/25/15 03:32 AM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
Put pressure on with a pry bar and as stated hit them with a big one. Some pop off and others are a ____!
Re: 06 ram 2500 4x4- removing front brake rotors [Re: mopars4ever] #1898926
08/25/15 10:45 AM
08/25/15 10:45 AM
md
md
That`s pretty much how I got the back ones off. Thanks guys for the advice.
Re: 06 ram 2500 4x4- removing front brake rotors [Re: mopars4ever] #1902118
08/29/15 10:48 PM
08/29/15 10:48 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
my 06 rotors came off fairly easily on my 4x4 2500 cummins
**Photobucket sucks**
