Steering column removal #189802
01/10/09 07:41 PM
01/10/09 07:41 PM
Bellevue WA
360ChallengerB3 Offline OP
Bellevue WA
I have a 65 Belvedere w/power steering. Is the easiest way to remove the steering column to pry the steering-shaft coupling off, or is there an easier way?
Re: Steering column removal [Re: 360ChallengerB3] #189803
01/10/09 07:58 PM
01/10/09 07:58 PM
wisconsin
jp66charger Offline
jp66charger  Offline
wisconsin
Should be a bolt through the coupling at the power steering unit. Remove that bolt and the bolts under the dash. My Polara has just two bolts under the dash, my Charger and Dart have four bolts under dash. Good luck.
Re: Steering column removal [Re: jp66charger] #189804
01/10/09 08:21 PM
01/10/09 08:21 PM
Bellevue WA
Bellevue WA
so i need to remove the rectangular housing around the coupler to get to the bolt?
Like this?
Thanks for the help.
Re: Steering column removal [Re: 360ChallengerB3] #189805
01/10/09 08:25 PM
01/10/09 08:25 PM
wisconsin
jp66charger Offline
jp66charger  Offline
wisconsin
No. Down at the steering box there is a little one inch wide clamp looking thing. The bolt goes through that clamp and through the side of the input shaft on the steering box.
Re: Steering column removal [Re: jp66charger] #189806
01/10/09 08:34 PM
01/10/09 08:34 PM
wisconsin
jp66charger Offline
jp66charger  Offline
wisconsin
Just below the block you are trying to dis assemble should be a keeper that is either round or clamp like. The round one has a roll pin through it the clamp style has a bolt. My 66 has a roll pin my 63 has a bolt.
Re: Steering column removal [Re: jp66charger] #189807
01/10/09 08:55 PM
01/10/09 08:55 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Don't forget to disconnect the wiring too!
Re: Steering column removal [Re: jp66charger] #189808
01/10/09 09:53 PM
01/10/09 09:53 PM
Bellevue WA
Bellevue WA
Thanks much. That was much easier than ripping into the shaft column housing
Re: Steering column removal [Re: RodStRace] #189809
01/10/09 10:07 PM
01/10/09 10:07 PM
Bellevue WA
Bellevue WA
Wires and transmission cables disconnected.
(eyefull of dried road grit for my troubles removing the transmission cables)
