440 header pics needed. #189726
01/10/09 06:32 PM
01/10/09 06:32 PM
Inver Grove Heights MN
74RR Offline OP
74RR  Offline OP
I need a picture of a drivers side header for a 440 in a 74 B body.
Thanks.
Re: 440 header pics needed. [Re: 74RR] #189727
01/11/09 01:46 PM
01/11/09 01:46 PM
74RR Offline OP
74RR  Offline OP
Thanks.
Re: 440 header pics needed. [Re: 74RR] #189728
01/11/09 04:04 PM
01/11/09 04:04 PM
Central NC
gch Offline
gch  Offline
Central NC
No longer have the car or any pics but I had to severly dent the tube that exits beside the big isolated steering coupler on my hookers.Did'nt have that problem with TT1.
Re: 440 header pics needed. [Re: gch] #189729
01/11/09 07:10 PM
01/11/09 07:10 PM
74RR Offline OP
74RR  Offline OP
I have a problem with one of header tubes just touching my mini starter. I wonder how I can remedy this.The starter and headers are on and fit but there is one small spot where the starter is just barely touching one header tube.
Re: 440 header pics needed. [Re: 74RR] #189730
01/11/09 07:17 PM
01/11/09 07:17 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Pull out the hammer and dent the tube. Alternatively, I've heard some guys say they take a c-clamp on the tube with a flat board on the side you don't want dented, then cranked the c-clamp's screw.
Re: 440 header pics needed. [Re: DaytonaTurbo] #189731
01/11/09 08:22 PM
01/11/09 08:22 PM
74RR Offline OP
74RR  Offline OP
I have a C clamp and a flat board.I like the idea,thanks.
