Re: 96 Dakota RPM limiter
[Re: Randy..]
#1898182
08/24/15 09:12 AM
08/24/15 09:12 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
contact Ryan Hogan who does SCT tuning on a lot of Dodge trucks with Magnum motors. good news, you're playing with a 1996 which is OBD-II and can use SCT. SCT is the easiest way to raise your rev limiter, speed limiter, change your shift points, idle speed, and once you start feeding the truck boost, you can change your timing and air fuel ratios as well. http://www.dakotart.com/forum/showthread...uestions-thread
**Photobucket sucks**
[Re: Randy..]
#1898340
08/24/15 02:45 PM
08/24/15 02:45 PM
Posts: 12,424 Kalispell Mt.
HotRodDave
Kalispell Mt.
Have to use a magnum V8 flex plate and the balance will depend on if you have internal or external balance and if the external balance weight is on your converter or not.
I don't know any trick to raise the RPM limit on the old computer short of switching to the new one and programing it. 96 I think is still the old computer with the new programing, a lone orphan deal.
Probably not much help now but I just add a bunch more cubes to keep from raising the limiter.
[Re: dogdays]
#1898755
08/25/15 12:12 AM
08/25/15 12:12 AM
70Cuda383
Marysville, O-H-I-O
Contact Ryan anyway. A computer and wire harness, and that 95 will forget it's a 95 and thinking was a 96 since the day it left the factory. AND it'll accept SCT
[Re: Randy..]
#1898795
08/25/15 01:08 AM
08/25/15 01:08 AM
Posts: 791 Bama
Randy..
Bama
Was just thinking the same today, I have access to a 96 harness and ECM off one of my old projects, think ill do that, easy and cheap!
