Re: Break-in start-up part III
[Re: Scott Carl]
#1894465
08/18/15 03:25 PM
08/18/15 03:25 PM
RapidRobert
you'll be fine. Look at it this way, it'll be the same as when this is all done & it sits overnight then you start it up the next day, the preoiling will still be in place. OT, the yellow wire I referred to on the starter relay might not be solid yellow but it is the only wire there that has a hint of yellow (& that is the one you would pull to disable the starter when doing ign checks to see if the coil/ECU are being fed in run and in crank). EDIT the pickup might drain some but it (the psi) jumps right back up within a second or two when fired like it will after the breakin
[Re: Scott Carl]
#1895033
08/19/15 12:56 AM
08/19/15 12:56 AM
RapidRobert
As it turns out, that wire was yellow and black and I was so obsessed with the diagram saying yellow, that I tracked down the black and yellow wire(s) and found they involve the seat belt warning circuit. Yeah I could tell you weren't happy & then it hit me that it must not be solid yellow and I did say yellow but with it being black/yellow then I (in the future) will be more specific
[Re: Scott Carl]
#1895325
08/19/15 01:38 PM
08/19/15 01:38 PM
RapidRobert
LOL Its all good. More an issue with my OCD than anything Yours or mine!
