Trans filter getting uncovered?
#1894130
08/18/15 01:56 AM
08/18/15 01:56 AM
Posts: 1,760 Windsor, ON, Canada
Diplomat360
Windsor, ON, Canada
Last year I installed a 9.5" converter in my 727 automatic. At the same time I also upgraded from a TCI deep pan to the really deep MP one which is 3.5" deep from mounting flange to inside bottom of the pan.
I retained the TCI aluminum filter extension, which is just a tad under 1" long...however, occasionally I feel the transmission kick-out of gear at the stop light, or on my driveway, most noticable when the car is somewhat on an incline...which makes me think that I still do not have enough trans fluid in (which I checked repeatedly) or that somehow the filter is potentially getting uncovered.
Now, I've never experienced this behaviour, or something like it before, so there could be a hidden transmission problem here, although it is a rebuilt unit with barely 2k miles on it. With the MP deep pan I'm thinking just to be safe I should run a longer filter extension anyways...what do you guys recommend? I posted a WANTED ad in the FOR SALE section as well.
Re: Trans filter getting uncovered?
[Re: Diplomat360]
#1894148
08/18/15 02:43 AM
08/18/15 02:43 AM
RapidRobert
You've restored the level to normal (reads full on the stick) plus the pan depth (& therefore the fluid depth is lower/more fluid) and the pickup is lower so if anything I'd think now it'd be less likely to be uncovered but wait for better (trans) guidance
[Re: Diplomat360]
#1894444
08/18/15 03:11 PM
08/18/15 03:11 PM
Posts: 25,791 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The filter needs to be near the bottom of the sump...it might not be your problem but it's not correct as it is now.
[Re: Diplomat360]
#1895029
08/19/15 12:50 AM
08/19/15 12:50 AM
RapidRobert
If not, is it possible to double up with 2 of the shorter ones?
