Re: Replacing 72 Cuda trunk floor,easier with the tail panel off
[Re: NV69B7RR]
#1889979
08/12/15 12:49 AM
08/12/15 12:49 AM
moparpollack
Lil Herman
Lil Herman
85086
Short answer no, leave he gutters and tail panel together.
[Re: NV69B7RR]
#1890042
08/12/15 02:20 AM
08/12/15 02:20 AM
Posts: 2,103 East Coast, NJ
fig426
East Coast, NJ
Where you're at now, do your quarters first. Then pop the tail panel and do the trunk and 71 tail.
Chris from New Jersey
[Re: NV69B7RR]
#1890179
08/12/15 11:44 AM
08/12/15 11:44 AM
Posts: 1,106 michigan
440whiteboy
michigan
I'm replacing the trunk floor on my 72/71 Cuda with a 1 piece AMD piece. The quarters have been cut out already. I planned to replace the tail panel with a 71 version. Would it be easier to replace the trunk floor with the tail panel removed?
I'm not an expert bodyman by any means and want to be sure everything stays semi lined up.
Here is what I mean by the 1/4s already being cut out yes - must remove the rear tail panel to install one piece floor. trying to go from the side - quarter ( the trunk lid supports on the wheel wells will be in the way ) HOWEVER --- SENCE YOU PLAN TO INSTALL FULL QUARTERS WITH REAR PANEL - YOU WILL HAVE IT ALL OPEN ANYWAY TO DROP IN THE FLOOR PAN. Advice* - BEFORE REMOVAL -take pictures all around the rear inside & out. Take measurements of everything with notes of the original weld placements! -
They only see Stars... when hit by a Mopar!
[Re: NV69B7RR]
#1893610
08/17/15 03:33 PM
08/17/15 03:33 PM
Posts: 3,488 Annapolis, MD, USA
Vert
Annapolis, MD, USA
Somebody here did a nice photo shoot of replacing the trunk floor (1 piece) thru the opened tail panel. I had it bookmarked, but when the new software was installed those all went south. FOUND IT.
