Page 2 of 3 1 2 3
Re: Suspension Upgrade for Challenger [Re: shawge] #1884957
08/04/15 02:03 PM
08/04/15 02:03 PM
Spartan040 Offline OP
What would happen if I decided to ditch my idea and go with coil-overs and power rack and pinion all around? Would performance be about the same as with all the Hotchkis and Firm Feel stuff I listed?
Also, out of curiosity, would it be possible to ditch the rear leaf springs and go with a Street Lynx coil over kit but leave the rest of the suspension parts? How would that affect performance?
Re: Suspension Upgrade for Challenger [Re: Spartan040] #1885525
08/05/15 12:21 PM
08/05/15 12:21 PM
Massachusetts
Sneke_Eyez Offline
Sneke_Eyez  Offline
Massachusetts
You can go all out and take out the stock suspension stuff all you like, but I think you will find the same reaction from many here:
These cars had a good setup from the factory that just needs some updating.
Updating is less expensive and less work than it is to slam additional suspension setups under the car that are designed like a Ford or a Chevy.
Lots of people love their RMS setups, so clearly they make a good product.
The issue for many on this section is that coil-over setups don't seem to perform better than the updated stock setups and require more money and more modifications to install than the updated stock systems. So the basic answer to your second question would be: Yes, performance would be about the same for more money.
Many people are against a 4 link on these cars as well - if you look through this section, there are a lot of discussions of 4-link versus OEM or 3-link setups.
Most recently the coil-over versus stock, 4-link versus 3-link was debated in this thread: https://board.moparts.org/ubbthreads/ubbthreads.php/topics/1869049/sons-71-duster.html#Post1869049
Personally, if I was going to go all out on a suspension package for an E-Body and I truly decided that I wanted to do away with the stock stuff, I'd go for an Art Morrison Full Frame, a Schwartz G-Machine Chassis, or a Roadster Shop Chassis, which are all available for an E-Body.
But there is a LOT of cost there - and I'm not sure that the cost is worth the performance (just to end up running Corvette spindles!).
1969 Satellite Wagon - G3 Hemi Swap Incoming. | 1969 Coronet Post Coupe.
2002 Intrepid ES | 2009 Ram SLT | 2004 300M Special | 2002 300M Pro Am - Hers
Are you a New England Mopar Enthusiast?
Come check out the revived NorthEast Mighty Mopar at www.northeastmightymopar.com
Re: Suspension Upgrade for Challenger [Re: Sneke_Eyez] #1885629
08/05/15 02:48 PM
08/05/15 02:48 PM
Thanks for the link. I looked into the G-Machine, it looks very cool but it comes with a coil-over setup. Could I ditch that and put in the Hotchkis parts instead? And I'll look into the Art Morrison frame
Re: Suspension Upgrade for Challenger [Re: Spartan040] #1885723
08/05/15 04:57 PM
08/05/15 04:57 PM
Massachusetts
Sneke_Eyez Offline
Sneke_Eyez  Offline
Massachusetts
Nope, once you go with one of those frame/chassis setups, you are looking at GM stuff.
Hotchkis makes OEM-style replacement stuff for Mopars - torsion bars and strut rods and swaybars that replace factory stuff, but are better.
I doubt that any of their stuff would be compatible with the GM parts used on those setups, but I suppose you could ask.
I don't know why you would, though, those are three very reputable names in the AutoX/Pro-Touring world, I'm sure whatever they sold to you will be great for handling, even if it will be super expensive.
My personal problem with all of that is: How much greater would it be than the Hotchkis or Firm Feel stock-style stuff attached in a factory way for a lot less money?
Re: Suspension Upgrade for Challenger [Re: Sneke_Eyez] #1886616
08/06/15 10:48 PM
08/06/15 10:48 PM
Good point. I think I'll just stick with the stuff on my list
Re: Suspension Upgrade for Challenger [Re: Spartan040] #1887967
08/09/15 12:21 PM
08/09/15 12:21 PM
Plano, Texas
68cuda440 Offline
68cuda440  Offline
Plano, Texas
Another thread on this forum has been following a Valiant with torsion bars, he has been doing pretty good for himself without the expensive coil over conversion.
https://board.moparts.org/ubbthreads/ubbt...tml#Post1743045
Michael 1968 Barracuda Notchback Coupe 440 EFI 6-pack, T56 Magnum 6-spd
Re: Suspension Upgrade for Challenger [Re: Spartan040] #1888134
08/09/15 05:06 PM
08/09/15 05:06 PM
Manitoba Canada
67autocross Offline
67autocross  Offline
Manitoba Canada
Both can work for you, just depends what you are looking for. I don't really buy the cost argument on the coil over vs stock type set up, if you are starting with a stock front end that you have to replace everything on one of the bolt in coil overs kits may be cheaper in the end, but you have to buy the whole thing at once.
Both drive good but I would give the edge to a alterktion over a stock set up on the street, they certainly are much easier to adjust and have more suspension travel, brake kits may be cost a bit less as they use more common spindles.
All out handling I would guess may just end up coming down to the tires and proper setup more than what front end is used in the car. Just my 2cents
A new iron curtain drawn across the 49th parallel
Re: Suspension Upgrade for Challenger [Re: TC@HP2] #1891811
08/14/15 01:26 PM
08/14/15 01:26 PM
Finland
janimm Offline
janimm  Offline
Finland
Originally Posted By TC@HP2
Originally Posted By Spartan040
Good info, thanks. And I know it won't make it go faster or slower, I just want to know if it'd be harder to steer with a 10:1 ratio vs a 12.7:1
Harder to steer, if you are using power assist, no. However, what fast ratio steering does is make a car feel "twitchy" and very sensitive to inputs at higher speeds. At 75 mph highway speeds, it may feel like you can change lanes by flicking your wrist. Generally speaking, the higher the speeds the car is used at, the slower the steering speeds tend to be. Uber fast steering ratios are great for autocross, disasterous for top speed events.
I was worried about this when I purchased the borgeson steering box, since I have FirmFeel quick ratio pitman and idler arms. For me, this combo works very well. The steering in center area is still slower than for example in my bmw m5, or 07 320d. I have taken my car to 150+ mph, no "twitchy" feeling of any kind.
I do have tubular uca:s with 7deg caster set in.
Re: Suspension Upgrade for Challenger [Re: janimm] #1892672
08/15/15 11:06 PM
08/15/15 11:06 PM
Central Utah
Mopargnome Offline
Mopargnome  Offline
Central Utah
I am currently building a Challenger for a customer in a pro touring style. I have widened the wheel tubs 2 inches in the rear to fit a big back tire in it. Ordered a Hotchkiss TVS for it. The rear springs will be moved inside the frame rails to get maximum tire in the back. One thing I have wanted to do is box the LCA's. Any pictures of that? I don't want to block access to any important areas on them. I will also be bracing and fully welding the stock K member. This is a great thread chock full of info!
Re: Suspension Upgrade for Challenger [Re: Mopargnome] #1892690
08/15/15 11:35 PM
08/15/15 11:35 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
LCA braces are shown here, they do not block access
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Suspension Upgrade for Challenger [Re: Mopargnome] #1892694
08/15/15 11:41 PM
08/15/15 11:41 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
www.AREngineering.com makes ready made plates with holes in them.
I made this in 1998 with 3 pieces 1" strap.
Re: Suspension Upgrade for Challenger [Re: Mopargnome] #1892908
08/16/15 12:12 PM
08/16/15 12:12 PM
Bitopia
jcc Online content
jcc  Online Content
Bitopia
Well add this to this to your info base, 99% of time LCA boxing here, is pointless, and is mainly monkey see monkey do.
https://en.wikipedia.org/wiki/Monkey_see,_monkey_do
"Monkey see, monkey do
From Wikipedia, the free encyclopedia
Monkey see, monkey do is a pidgin-style saying that appeared in American culture in the early 1920s. The saying refers to the learning of a process without an understanding of why it works. Another definition implies the act of mimicry, usually with limited knowledge and/or concern of the consequences.[1]"
Re: Suspension Upgrade for Challenger [Re: jcc] #1892937
08/16/15 01:12 PM
08/16/15 01:12 PM
Central Utah
Mopargnome Offline
Mopargnome  Offline
Central Utah
Thanks Goody and AutoX! I will be doing that as soon as I am decide to take a break from the body. As for JCC, what's the deal? Not on positive comment on this thread. I think he needs a hobby besides sitting at his computer and typing nonsense!
Re: Suspension Upgrade for Challenger [Re: jcc] #1892979
08/16/15 02:57 PM
08/16/15 02:57 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
The one strap I put on the end near the ball joint I would not put there again.
The one under the sway bar connection I probably would to support the extra forces of a really thick swaybar bar on the LCA sway bar tab.
The strap at the very back of the LCA I would definitely put on again. The two halves of the LCA like to slightly move apart and it puts slack on the pivot/bushing point. Now I've noticed there is no side to side slack, but over 35 years there is slack between the OD of the LCA pivot and the LCA stamped ID. I don't know if this is from wear or original tolerances. I think both contribute, but I was not like that way in 1997.
Re: Suspension Upgrade for Challenger [Re: Mopargnome] #1892998
08/16/15 03:51 PM
08/16/15 03:51 PM
Bitopia
jcc Online content
jcc  Online Content
Bitopia
"Nonsense"?
"what's the deal?"
If you asked a real pertinent question, I would respond in kind.
I missed the memo on only "positive" comments being allowed.
Have another banana.
Re: Suspension Upgrade for Challenger [Re: ahy] #1893028
08/16/15 04:54 PM
08/16/15 04:54 PM
central CT
cudazappa Offline
cudazappa  Offline
central CT
Originally Posted By ahy
Brakes sound good. I run a Cobra based kit with 13" in front and 11.7" in the rear. I started with Bear front only and drums in the back. Not the best. Hard to balance and I burnt up the drums at a track day. I installed the Dr Diff rear disc kit and a huge improvement. With the brakes you choose, need to check piston area, especially on the front. The Cobra based kit has smaller piston area vs stock Mopar and needs more hydraulic pressure. I wound up changing to a 15/16" master + dual 8" booster to get my setup to 100%.
Do you have pics of your brake setup? I have a very similar front setup (same PBR calipers, Baer branded kit) and it is calling for the calipers to be rear mounted. How bad was it to install the rear discs? And the booster? How much vacuum? My 360 doesn't make much.
1971 Challenger
Re: Suspension Upgrade for Challenger [Re: Spartan040] #1893035
08/16/15 05:02 PM
08/16/15 05:02 PM
central CT
cudazappa Offline
cudazappa  Offline
central CT
BTW: just another Hotchkis TVS customer here (minus the subframe connectors) and love how it handles now with a proper alignment. It is definitely the best bang for the buck. I am proof it can be done on the cheap as everything was bought with a discount online, discount at a show, or someone had an open box product that they decided not to install. Definitely wasn't one click shopping, but I saved serious dough. I run the FFI Stage 3 with fast ratio arms, and 1.18 torsion bars. I have the old RCD Bilstein shocks out back, and just switched to QA1 sing adj up front and you can't tell by the ride I have big t-bars. Also am running an aluminum headed small block and fiberglass hood on my Challenger.
1971 Challenger
Re: Suspension Upgrade for Challenger [Re: Mopargnome] #1893152
08/16/15 08:06 PM
08/16/15 08:06 PM
Manitoba Canada
67autocross Offline
67autocross  Offline
Manitoba Canada
Might as well put the LCA plates on, not a whole lot of other things you can do to a car for $25.
Re: Suspension Upgrade for Challenger [Re: cudazappa] #1893275
08/16/15 11:29 PM
08/16/15 11:29 PM
IN
ahy Offline
ahy  Offline
IN
I also run a Bear 13" kit on the front purchased ~10 years ago. I first installed it with the iron master supplied by Bear and a reman OE 9" single diaphragm booster. The Bear hoses did not work as supplied for rear mount calipers - too short. I wound up using them as a pattern by cutting them in half and using a piece of poly tube slipped over the flex part to join the halves. That way I could adjust length and orientation of the ends. With T bars out, I tried full jounce, full rebound and full left and right adjusting the hose length and orientation until it worked. I used some hose clamps to lock the poly tube in position and sent the mock-ups off to Inline Tube. A week or so later they sent back a set of perfect hoses.
Maybe/hopefully Baer or Dr Diff have the hoses figured out now.
With that I had good functional front brakes... but not enough line pressure for max effort stopping. As I got more serious about track use, that needed fixed. First was the 8" dual booster. I got it from Mancini, however Dr Diff sells them also. Straight forward installation... at least no harder than a stock booster. Working on the linkage under the dash is not my favorite but as the saying goes, just nuts and bolts. The back of the dual booster is a bit larger diameter so the hole in your original firewall re-enforcing plate will be a little small... either hog it out or get the new plate that fits (which I did). The dual booster was better but still not 100%. More pressure needed. I added a Dr Diff 15/16" master and it is good now. With sticky 200 TW handling tires, I have all the brakes I can use.
That took care of the front. My rear drums I burned up at a track day and switched to the Dr Diff Cobra based rear kit (mock up pics attached). As advised by Dr Diff, one axle shaft needed slightly lengthened to get contact with the thrust button and provide effective adjustment for the tapered bearings. I welded a hardened washer on the end of the shaft and machined it down based on test fit to get it dialed in.
The system works great with EBC yellow pads. Front and rear are balanced and great stopping capability on a road course with repeated laps.
PS: You asked about vacuum.... I have ~13" at idle after tuning. Before tuning it was under 10". Works fine for around town driving. Also, mine is manual transmission so while braking in gear, probably 20+" vacuum. If yours is lower, probably need a vacuum pump or hydroboost.
Re: Suspension Upgrade for Challenger [Re: Spartan040] #1893339
08/17/15 12:37 AM
08/17/15 12:37 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
How is dust and noise with the Yellow stuff pads?
Mopar to the bone!!!
Page 2 of 3 1 2 3
