Page 4 of 5 1 2 3 4 5
Re: Mark Williams Billet Caps for 8 3/4 [Re: runnerrt] #1892287
08/15/15 10:22 AM
08/15/15 10:22 AM
Mo.
racerx Offline
racerx  Offline
Mo.
Same with an 8.75. One under an early 6 cylinder A-body was weak as water. The hi-po units were much better.
So which 8 3/4 was the better one? 489,741,742? shruggy
Re: Mark Williams Billet Caps for 8 3/4 [Re: J_BODY] #1892323
08/15/15 11:53 AM
08/15/15 11:53 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Originally Posted By J_BODY
Same deal with Thumpers car..... once in a great while the car sees a track, yet every discussion on this topic the same two chime in on how it doesn't not happen to them. Mike you constantly chime in on this.... are you telling the OP to use the 8.75 over the D60??? Heavy big block stroker with a 4 speed. Your chit, as noted above, is apples to oranges. What a coincidence the factory put the D60 behind performance big block 4 speed cars..... guess they ran low on the mighty 8.75 and figured the D60 would do in a pinch.
You must not read... I said... heavy car or a 4
speed will break a 8 3/4.. they work great in LIGHT
cars
wave
Re: Mark Williams Billet Caps for 8 3/4 [Re: runnerrt] #1892335
08/15/15 12:15 PM
08/15/15 12:15 PM
North Central, Indiana
Roughbird72 Offline
Roughbird72  Offline
If anyone doesn't believe that 8 3/4 cases don't flex because of the lack of pinion support, look at the housing & the damage to it from the ring gear shearing teeth. This was done prior to the brace being welded to the housing. Dry hops, on & off the throttle at 20-30mph in 1st on the street showing off in my younger years claimed the ring gear that did this. The brace covers the worst part, not sure why the cap didn't break.
I am still running the 8 3/4 because i still have quite a few spare cases & only get to the track 1-2 times a year. As mentioned previously, billet caps & braces are just band-aids ... especially on heavy BB cars.
A 60 is in the future for my car, because it's stronger/more dependable. twocents
72 Plymouth Roadrunner 11.08@123.25
Re: Mark Williams Billet Caps for 8 3/4 [Re: racerx] #1892378
08/15/15 01:33 PM
08/15/15 01:33 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Early /6 a-body's? 99% had 7 1/4 rears. My 3 speed /6 Twister has the 489. 741 weakest, 742 then 489 but of those two each has their good and bad points but neither will not hold up behind a 4 speed unless he has 675-14s, they where made with grease I think.
Re: Mark Williams Billet Caps for 8 3/4 [Re: Quicktree] #1892385
08/15/15 01:39 PM
08/15/15 01:39 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
How about a 3200 lb 700 horse 470 BB w/stock caps and w/60 ft`s in 1.36`s.......?
700 HP work are those CAB 700HP?
Yes, we share the same dyno and I drive to Oregon every sunday to dyno my stuff. thumbs
thats what I thought laugh2 . 700 CAB HP is around 600 real HP. to give you an example my challenger at 3100#s made 468hp to the wheels and ran 10.40 @ 130mph and thats with a tight converter and 16x32 steam rollers. car would run easy 10.20s range with those corrected. if you think you are making 700hp you are only fooling yourself. twocents
YOU`RE kidding right? Screw the "math" equations this and that bs. My old solid cammed 906 headed motor on Pettis`s dyno made 615 hp and 580+ tq. and went 10.40`s at around 3250 lbs. all day. So you`re telling me that a bigger better fully ported e-head and a 680-660 lift w/276-281 @ .050 solid roller and low drag back cut rings is making LESS hp.... whistling Ya right. Put your motor in a street weight car like mine and get back w/me............ laugh2
Re: Mark Williams Billet Caps for 8 3/4 [Re: Thumperdart] #1892393
08/15/15 01:49 PM
08/15/15 01:49 PM
Q
Quicktree Offline
Quicktree  Offline
Q
you are a silly man,Dyno's don't go down the track. your numbers don't add up to 700hp any way you look at it. you are 100 pounds heavier than my challenger I ran 130mph with a stock stroke 360 don't you think I would gain more than 5mph with 200 extra HP?
Re: Mark Williams Billet Caps for 8 3/4 [Re: J_BODY] #1892400
08/15/15 01:59 PM
08/15/15 01:59 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Stop it your hurting my feelings...........NOT! Some of you guys act like I`ve only made 50 passes or something. I have a stack of time slips from the 90`s up till now and use to T&T at L.A.C.R. almost monthly w/a warmed 360 then my BB and even showed Al Alguire my stack of slips when he was here. Back to building carbs and at the end of the year I`ll hit Bakersfield for my 9.60 or better and HOPEFULLY my lowly 8 3/4 lives but if it breaks which according to some it will, then I`ll put it back together and move on....... drumhit
Re: Mark Williams Billet Caps for 8 3/4 [Re: Thumperdart] #1892404
08/15/15 02:12 PM
08/15/15 02:12 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
If you we're making any real power you'd have broke that rear gear by now! laugh2 (come on! thats funny no matter who ya are!)
Re: Mark Williams Billet Caps for 8 3/4 [Re: racerx] #1892407
08/15/15 02:16 PM
08/15/15 02:16 PM
The 742 is the best stock 8 3/4, the 741 will live very well in a medium weight, medium power BB A body up My 440 powered 1969 Dart GTS weighed 3300 lbs with me in it and had many, many runs on the OEM 741 case and posi with the OEM 3.91 gears. That car went 11.17 at 122 MPH in Las Vageas in November many times the last time I raced it here shruggyThe stock 489 case with the crush sleeve is the weakest of the three, the 489 and 741 have the same size pinion gear diameter size at the front bearing scope shruggy If you put a pinon gear spacer in place of the crush sleeve then it is as good as the 741 up The 742 and Dana 60 pinion gear shafts are bigger diameter at the front bearing scope up whistling
Re: Mark Williams Billet Caps for 8 3/4 [Re: J_BODY] #1892441
08/15/15 03:20 PM
08/15/15 03:20 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
It IS funny cos everyone I know drives a 9-second car on the street and ALL of make around 599 hp.............just crazy and don`t know how they do it....... realcrazy
Re: Mark Williams Billet Caps for 8 3/4 [Re: runnerrt] #1892449
08/15/15 03:41 PM
08/15/15 03:41 PM
Burlington, Ontario Canada
Dave_S Offline
Dave_S  Offline
742 case with MW cap, ARP studs and ring gear bolts, back brace
8.93 @ 149 3050lbs with driver. 1.21 60'
I change out the r&pinion every 300 passes.
NEVER broke in 15 yrs of racing. (100 passes/year)
Dave Stillie
'73 Swinger
5.7 Hemi, 88mm turbo, powerglide, cal-tracs & 8 3/4
Mega-Squirt EFI
[email]8.93@149
[/email]
Re: Mark Williams Billet Caps for 8 3/4 [Re: runnerrt] #1892452
08/15/15 03:48 PM
08/15/15 03:48 PM
Roughbird72 Offline
Roughbird72  Offline
Hmm? 3200# car, 9.79 @ 135.5 ... takes around 590-600rwhp to do that, 700hp seems legit to me.
Re: Mark Williams Billet Caps for 8 3/4 [Re: Roughbird72] #1892464
08/15/15 04:07 PM
08/15/15 04:07 PM
Portage,michigan
B3422W5 Online content
B3422W5  Online Content
Portage,michigan
My ex car weighs 3220 currently. A while back the motor made 705 ish horsepower on a dyno with Best machine.
That motor went 9.62@ 140 on super stock springs.
That almost 5 more mph than the above. Huge difference
When I had the car( little bit different combo) it went 135@ 3350. I figured it made about 640-650 REAL horsepower.
135@ 3250 ISNT 700 horsepower, it's a great elapsed time, but it isn't 700. More like probably 640-645.
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Mark Williams Billet Caps for 8 3/4 [Re: Roughbird72] #1892474
08/15/15 04:27 PM
08/15/15 04:27 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Naw, Quick said the "math" doesn`t add up........ whistling
Re: Mark Williams Billet Caps for 8 3/4 [Re: Thumperdart] #1892478
08/15/15 04:33 PM
08/15/15 04:33 PM
Q
Quicktree Offline
Quicktree  Offline
Q
it doesn't but keep telling yourself it does and one day you will believe it laugh2
Re: Mark Williams Billet Caps for 8 3/4 [Re: Thumperdart] #1892491
08/15/15 05:01 PM
08/15/15 05:01 PM
Roughbird72 Offline
Roughbird72  Offline
whatever the case your car/chassis seems to be working PDG ... up
Re: Mark Williams Billet Caps for 8 3/4 [Re: Roughbird72] #1892499
08/15/15 05:24 PM
08/15/15 05:24 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
That was my very first pass on new combo and carb was lean up top so there`s more there and now it`s 3050lbs. so a new best is comin soon........ thumbs
Re: Mark Williams Billet Caps for 8 3/4 [Re: Thumperdart] #1892521
08/15/15 06:32 PM
08/15/15 06:32 PM
tboomer Offline
tboomer  Offline
I was running 11.35 with a 489 case in my 64 with the old 446". When we built the Dana I sold the 489. The 3.91 gears looked new yet with no wear. I was always told the 489 case was the good one. Now it goes 10.15 at 132 mph. What is that at a tad over 3600#? About 550 HP? stirthepot
Re: Mark Williams Billet Caps for 8 3/4 [Re: Thumperdart] #1892531
08/15/15 06:57 PM
08/15/15 06:57 PM
Roughbird72 Offline
Roughbird72  Offline
Nice! punkrocka
Re: Mark Williams Billet Caps for 8 3/4 [Re: tboomer] #1892532
08/15/15 06:59 PM
08/15/15 06:59 PM
Roughbird72 Offline
Roughbird72  Offline
And then some... popcorn
