1970 340 6bbl auto carb questions #1892040
08/14/15 08:32 PM
08/14/15 08:32 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
I was checking out the pnumbers on the carbs that came on my 70 ta auto challenger and they are supposed to be:
4792 center carb (auto)
4789 front carb
4790 rear carb
But turns out that i have
And (2) 4790 carbs.
Are the 4789 and 4790 carbs the same carbs just setup different and thats why they carry a different part number or are they different and not interchangeable?
Re: 1970 340 6bbl auto carb questions [Re: domingo] #1892126
08/14/15 11:12 PM
08/14/15 11:12 PM
Philadelphia PA
Pynzo Offline
Drugs are bad
Pynzo  Offline
Drugs are bad
Philadelphia PA
Holley sells 4790 replacement carbs only, no 4789. I bought a set and a 4792 center. The difference is in the metering block between the outboard carbs, besides the part numbers. A '70 FSM should have the metering block orifice sizes listed.
Re: 1970 340 6bbl auto carb questions [Re: domingo] #1892129
08/14/15 11:15 PM
08/14/15 11:15 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
My 4790 carbs are oem.
I guess i could run one those aftermarket metwring plates w screw in jets and id be set???
Re: 1970 340 6bbl auto carb questions [Re: domingo] #1892130
08/14/15 11:23 PM
08/14/15 11:23 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Domingo, your pair of 4790's will run just fine on a stock 340 with the stock 4790 metering plates, no need to change anything. If you want to tune them for performance (I suggest doing this on a dyno) go ahead with the Promax plates and play with the jetting, or the budget route, drill the metering plates to a larger size per the instructions on this link.
Six Pack Tips
Re: 1970 340 6bbl auto carb questions [Re: domingo] #1892293
08/15/15 10:29 AM
08/15/15 10:29 AM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Yes. Thats what i was thinking...just putting the aftermarjet metering pkated w screw in jets and tune em right. I just wantwd to know if they were just the same carb set up diffwrently....which u kust confirmed.
They are goin on a fast syyle 416 toa w w2 heads. Promax plates will come inm handy.
Re: 1970 340 6bbl auto carb questions [Re: domingo] #1892372
08/15/15 01:21 PM
08/15/15 01:21 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
And just to clearify, the 4789 and 4790 carbs have the same metering plates (41's). So other than the list numbers and date codes they are identical.
Re: 1970 340 6bbl auto carb questions [Re: ScottSmith_Harms] #1892379
08/15/15 01:36 PM
08/15/15 01:36 PM
Philadelphia PA
Pynzo Offline
Drugs are bad
Pynzo  Offline
Drugs are bad
Philadelphia PA
So other than the part numbers what's the difference between front and rear carbs? I know the idle mixture screw setting was set on a flow bench, then plugged. Would the factory idle mixture settings be different front and rear?
Re: 1970 340 6bbl auto carb questions [Re: domingo] #1892439
08/15/15 03:18 PM
08/15/15 03:18 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
SAME
Re: 1970 340 6bbl auto carb questions [Re: ScottSmith_Harms] #1892494
08/15/15 05:14 PM
08/15/15 05:14 PM
Philadelphia PA
Pynzo Offline
Drugs are bad
Pynzo  Offline
Drugs are bad
Philadelphia PA
Ok great. Fired up my new Holley's today and didn't have to adjust the idle mixture one bit. 1/4 out diaphragm side and 1/2 turn throttle factory settings on my outboards.
Re: 1970 340 6bbl auto carb questions [Re: domingo] #1892513
08/15/15 05:53 PM
08/15/15 05:53 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Why the heck did they use different part numbers then????
Re: 1970 340 6bbl auto carb questions [Re: domingo] #1906776
09/05/15 10:20 AM
09/05/15 10:20 AM
MA
ragtop Offline
ragtop  Offline
MA
I also would like to know why they had different part numbers for the front and rear
