Re: How much boost will it hold. [Re: Skypower] #1888905
08/10/15 04:41 PM
08/10/15 04:41 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
After the car is built upgrade the motor. That's how I did it.
I picked my car up from a junkyard and built everything with the plan of racing it. Took several years but was fun building it.
Re: How much boost will it hold. [Re: Skypower] #1888944
08/10/15 05:47 PM
08/10/15 05:47 PM
Skypower Offline OP
Skypower  Offline OP
That's the problem I just got the car together and now I'm getting crazy thoughts to add the turbo's we have laying around.
Re: How much boost will it hold. [Re: Skypower] #1888981
08/10/15 06:35 PM
08/10/15 06:35 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Post pics. Sounds tuff
Re: How much boost will it hold. [Re: Skypower] #1888982
08/10/15 06:37 PM
08/10/15 06:37 PM
Skypower Offline OP
Skypower  Offline OP
I don't know how to post pics on here I have a build thread on A bodys. Hemi Cuda just for fun.
Re: How much boost will it hold. [Re: Skypower] #1889017
08/10/15 07:32 PM
08/10/15 07:32 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I had 43 runs on my stock block combo. Hit 30 psi on most of those. My short block is fine but I pulled it and went aluminum block to feel better about it living.
I knew it was on borrowed time, didn't want to ruin a good engine. But it let me sort out my homebuilt car and make runs for seat time. If you keep it at 15-20 psi with a good efi tune you should live a long time. But you plan on racing it so there's always the chance.
