Aviation fuel in a drag car. OK or Bad idea? #188618
01/09/09 04:35 PM
01/09/09 04:35 PM
alabama
mopars rule Offline OP
mopar addict
mopar addict
alabama
I have access to aviation fuel and was curious if there is a down side to running it in a dragcar. It's a lot cheaper than racing gas. Would the engine perform like its supposed too? What about the effect on parts in the engine?
Re: Aviation fuel in a drag car. OK or Bad idea? [Re: mopars rule] #188619
01/09/09 04:53 PM
01/09/09 04:53 PM
A shed in England
Tig Offline
Tig  Offline
A shed in England
Works for me, since c12 is really expensive over here, typically equal to $160.00 for 5 US gallons. We mix it with super unleaded to boost octane (50/50).
Opinions may differ though
Re: Aviation fuel in a drag car. OK or Bad idea? [Re: mopars rule] #188620
01/09/09 05:07 PM
01/09/09 05:07 PM
Back in the 1970 and 1980 we ran it straight in our 63 Ply and 64 Dodge super stock all the time and now I run it mixed with 93 octane in my six pack steet Road Runner never had a problem.
Thanks Moparts
Re: Aviation fuel in a drag car. OK or Bad idea? #188621
01/09/09 06:36 PM
01/09/09 06:36 PM
SW Ohio
cgall Offline
cgall  Offline
SW Ohio
It is 110 octane leaded gasoline, I've run it many times without issues.
Re: Aviation fuel in a drag car. OK or Bad idea? [Re: cgall] #188622
01/09/09 06:44 PM
01/09/09 06:44 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
I was lead to understand its more like 100-102 octane, and has some altitude additives that make it less than ideal to run in a car
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: Aviation fuel in a drag car. OK or Bad idea? [Re: B3422W5] #188623
01/09/09 06:49 PM
01/09/09 06:49 PM
Diego-Town, CA
Diego_Ted Offline
Diego_Ted  Offline
Diego-Town, CA
Yes that was the concensis!! Been down this path before.
diego
Re: Aviation fuel in a drag car. OK or Bad idea? [Re: Diego_Ted] #188624
01/09/09 07:20 PM
01/09/09 07:20 PM
Canada
RobR Offline
RobR  Offline
Canada
Av gas is 80-100 up here in canada...piss poor fuel...Back in the early 80's we use to run 100-130 Av gas (green)
The blue 80 that they have now I wouldn't put in a lawnmower.
Re: Aviation fuel in a drag car. OK or Bad idea? [Re: Diego_Ted] #188625
01/09/09 07:23 PM
01/09/09 07:23 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
I don't know if it still applies,but when I researched this years ago I was told that "aviation fuel" has a much lower burn speed,because aviation engines turned at a slower r.p.m. than most race engines.
I don't know if all aviation fuel is even the same though?
Re: Aviation fuel in a drag car. OK or Bad idea? [Re: Dunnuck Racing] #188626
01/09/09 07:41 PM
01/09/09 07:41 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
High octane gas has a slower burn rate than regular gas. High octane fuel does not make more power. Running more octane than you need can produce less power.
Re: Aviation fuel in a drag car. OK or Bad idea? [Re: MoparforLife] #188627
01/09/09 07:47 PM
01/09/09 07:47 PM
Northern Indiana
Northern Indiana
My info came from Steve Burns, president of V.P. race fuels.He started out using aviation fuel,and decided to improve on it's properties.
I think this is one of the reasons he offers many different race fuels,not all engines need the slow burn,but still need high octane.
Re: Aviation fuel in a drag car. OK or Bad idea? [Re: Dunnuck Racing] #188628
01/09/09 07:54 PM
01/09/09 07:54 PM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
I've used lots my earlier days. 100 low lead is what I used.I use to mix a quart of tolulene to 5 gals of 100 LL. Under about 12:1 CR it worked for me.
Re: Aviation fuel in a drag car. OK or Bad idea? [Re: MoparforLife] #188629
01/09/09 07:56 PM
01/09/09 07:56 PM
organ
maximum entropy Offline
organ
high octane makes it more resistant to detonation/ spontaneous ignition. high octane fuel can make more power- dynos don't lie. much.
Re: Aviation fuel in a drag car. OK or Bad idea? [Re: maximum entropy] #188630
01/09/09 08:03 PM
01/09/09 08:03 PM
Upper Midwest
Upper Midwest
Up to the point of your engines need for octane. After that point the power can deteriorate and using more octane than the engine wants is a waste of money. The burn rate of high octane is slower than lower octane. This the reason for more advance needed to get a complete burn for the power stroke of the engine.
Re: Aviation fuel in a drag car. OK or Bad idea? [Re: maximum entropy] #188631
01/09/09 08:03 PM
01/09/09 08:03 PM
GA
Boosted Offline
Boosted  Offline
GA
ran it in many turbo cars with no problems including the race cars... Av Gas has an aditive in it to keep it from freezing.. No harm at all except to a car running o2's...
106 octane fuel... Per the guy that delivers it to our local airport...
2011 RAM3500
1967 Fastback Barracuda with some go fast goodies.
Re: Aviation fuel in a drag car. OK or Bad idea? [Re: Boosted] #188632
01/09/09 08:18 PM
01/09/09 08:18 PM
Northern Indiana
Northern Indiana
Coutesy of V.P. racing fuels web site:
Re: Aviation fuel in a drag car. OK or Bad idea? [Re: Dunnuck Racing] #188633
01/09/09 08:32 PM
01/09/09 08:32 PM
Mississippi Gulf Coast
Mroctober Offline
Mroctober  Offline
When Racing Gas got to be HIGH change to Avia fuel car has not miss a beat !!!!!! same Time as the C12.
Re: Aviation fuel in a drag car. OK or Bad idea? [Re: mopars rule] #188634
01/09/09 09:14 PM
01/09/09 09:14 PM
Ortonville, MI
RoadRnnr69 Offline
Keyster
RoadRnnr69  Offline
Keyster
Ortonville, MI
Most av gas is 100 octane, they usually have lead and no lead. There is no highway tax on it, most airports would not let you drive a car up to the pump since that would be illegal.
Get in gas cans and tell them it is for a float plane. The down side is that it is usually more money than auto gas due to the limited competition . There isn't an airport on every corner to compete with.
Re: Aviation fuel in a drag car. OK or Bad idea? [Re: RoadRnnr69] #188635
01/09/09 10:00 PM
01/09/09 10:00 PM
wisconsin
jp66charger Offline
jp66charger  Offline
wisconsin
As a guy who buys it by the tanker load I can clear up a couple but not all your questions. First, it's called 100LL. 100 being minimum octane rating. Second, LL means low lead which is a misnomer, it is actually a very high lead content which explains white exhaust pipes on airplanes(and the O2 comment above). There is no such thing as unleaded av gas in the US.....yet. The EPA is in the process of outlawing the tetra ethyl lead which will change a fuel that has not changed since Jimmy Doolittle got it produced. Av gas will soon be about 84? octane without lead but some other lubricating agents added. You can probably run it without problems if you don't mind the lead but keep it in mind while reading a plug.
Re: Aviation fuel in a drag car. OK or Bad idea? [Re: jp66charger] #188636
01/09/09 10:48 PM
01/09/09 10:48 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
If its a "race car" ..it should have "race fuel" designed for application
IMO
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: Aviation fuel in a drag car. OK or Bad idea? [Re: bigdad] #188637
01/09/09 11:20 PM
01/09/09 11:20 PM
Northern Indiana
Northern Indiana
I'll just finish my two cents worth by saying that just because something works,that doesn't mean it works right.I wouldn't build a 20 thousand dollar engine just to look for the cheapest fuel to run in it.Just look at how many guys are looking for the "right" oil.
