Re: Aviation fuel in a drag car. OK or Bad idea?
[Re: mopars rule]
#188619
01/09/09 04:53 PM
01/09/09 04:53 PM
Posts: 2,923 A shed in England
Tig
A shed in England
Works for me, since c12 is really expensive over here, typically equal to $160.00 for 5 US gallons. We mix it with super unleaded to boost octane (50/50). Opinions may differ though
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: mopars rule]
#188620
01/09/09 05:07 PM
01/09/09 05:07 PM
Back in the 1970 and 1980 we ran it straight in our 63 Ply and 64 Dodge super stock all the time and now I run it mixed with 93 octane in my six pack steet Road Runner never had a problem.
Thanks Moparts
[Re: cgall]
#188622
01/09/09 06:44 PM
01/09/09 06:44 PM
Posts: 11,713 Portage,michigan
B3422W5
Portage,michigan
It is 110 octane leaded gasoline, I've run it many times without issues.
I was lead to understand its more like 100-102 octane, and has some altitude additives that make it less than ideal to run in a car
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: B3422W5]
#188623
01/09/09 06:49 PM
01/09/09 06:49 PM
Posts: 5,406 Diego-Town, CA
Diego_Ted
Diego-Town, CA
Yes that was the concensis!! Been down this path before.
diego
[Re: maximum entropy]
#188630
01/09/09 08:03 PM
01/09/09 08:03 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
High octane gas has a slower burn rate than regular gas. High octane fuel does not make more power. Running more octane than you need can produce less power.
high octane makes it more resistant to detonation/ spontaneous ignition. high octane fuel can make more power- dynos don't lie. much.
Up to the point of your engines need for octane. After that point the power can deteriorate and using more octane than the engine wants is a waste of money. The burn rate of high octane is slower than lower octane. This the reason for more advance needed to get a complete burn for the power stroke of the engine.
#188631
01/09/09 08:03 PM
01/09/09 08:03 PM
Posts: 2,648 GA
Boosted
GA
ran it in many turbo cars with no problems including the race cars... Av Gas has an aditive in it to keep it from freezing.. No harm at all except to a car running o2's...
106 octane fuel... Per the guy that delivers it to our local airport...
2011 RAM3500
1967 Fastback Barracuda with some go fast goodies.
[Re: jp66charger]
#188636
01/09/09 10:48 PM
01/09/09 10:48 PM
Posts: 34,909 S.E. South Dakota !
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
If its a "race car" ..it should have "race fuel" designed for application
IMO
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
