W2 Parts Questions #1871570
07/16/15 02:24 PM
07/16/15 02:24 PM
Indiana
Y
YO7_A66 Offline OP
YO7_A66  Offline OP
Y
Indiana
I am just thinking ahead (wish list) for some upgrades on my 340. I am thinking of finding parts "a little at a time" and the first two pieces would be a set of W2 Econo's and a W2 intake.
I would like to use a dual plane (street car) and I am curious of opinions as to what dual plane W2 intake would be good on a street car that would keep the rpms under 6500 or so.
Or, what about having my existing RPM intake ported and then new mounting holes added? The specs on it say good up to 6500rpms. How would the RPM intake react with the W2's?
Later on down the road, it would be the rockers.
I see that T&D make rockers for the W2's (could not verify ratio), and I found some Crane Race Gold 1.6 rockers too. I also found HS for $1000+. Hughes said that they do not make any and do not see making any in the near future. Are there any more selections for the W2 shaft mounted rockers?
Re: W2 Parts Questions [Re: YO7_A66] #1872130
07/17/15 01:51 AM
07/17/15 01:51 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
the intake rockers are the ones that are different..the W2 head exhaust rocker is a standard rocker. So a standard crane gold will work on the exhaust..you need 4 lefts and 4 rights for the intakes.
Summit still list the Crane w2 rockers..so they are available.
the dual plane intake was made by Weiand and has oval ports, they show up on Ebay every not and then.
http://www.jegs.com/i/Mopar+Performance/...SVvMaAnbL8P8HAQ
Tony
70 AARCuda Vitamin C
Re: W2 Parts Questions [Re: 70AARcuda] #1872192
07/17/15 08:43 AM
07/17/15 08:43 AM
Indiana
Y
YO7_A66 Offline OP
YO7_A66  Offline OP
Y
Indiana
Thank you 70!!
Who makes a good rocker arm shaft? It appears that most of the W2 rocker arm packages do not come with shafts. This is good for me so that I can buy parts separately as I have the budget. I found on the Mancini websight MP @ $160 and HS @ $180. Are these two comparable?
Re: W2 Parts Questions [Re: YO7_A66] #1872334
07/17/15 03:00 PM
07/17/15 03:00 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
There is a Weiand W2 dual plane intake for sale on page 1 of the small block parts for sale section here. It's not mine and I'm in no way affiliated with the seller.
Re: W2 Parts Questions [Re: justinp61] #1872363
07/17/15 04:04 PM
07/17/15 04:04 PM
Indiana
Y
YO7_A66 Offline OP
YO7_A66  Offline OP
Y
Indiana
That is a Weiand dual plane modified into a W2 intake with porting and holes relocated. That might be a good option but I am not ready to pull the trigger just yet.
I have been emailing T&D for their rocker quotes. They supply rocker shafts with their kit. Crane would be a little less expensive per rocker but they don't sell shafts. Once shaft pricing is put in with Crane, they are about $125 less than the T&D's full kit.
Re: W2 Parts Questions [Re: YO7_A66] #1872571
07/17/15 10:03 PM
07/17/15 10:03 PM
Los Osos, Ca
CKessel Offline
CKessel  Offline
Los Osos, Ca
No matter what shaft/rocker you use, make sure the oil holes are lined up with each other when the valve is closed. Years ago, I did up a set of W2's for my Duster and cooked half a set of the bushed DC rockers, custom pushrods, lash caps and both shafts. I can't remember if I got the shafts from DC or Ed Hamburger[ before he turned to the dark side]. I ran this by a guy I met who ran Mopars west coast skunkworks up by Laguna Seca. He said Mopar never got their feces together on the shafts and that the rocker would have to rotate past full valve opening, till it was almost 90*, for them to oil. This is exactly what I found on mine. I replaced the damaged pieces, ground in some oiling grooves on the new shafts, drained the metallic infused oil, cleaned the filter and off I went.
Carl Kessel
Re: W2 Parts Questions [Re: YO7_A66] #1872730
07/18/15 02:30 AM
07/18/15 02:30 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
if you have econo heads...check to see what the bolt thread on the pedestal is ...and check out mancini for shafts..
Tony
Re: W2 Parts Questions [Re: YO7_A66] #1884276
08/03/15 01:46 PM
08/03/15 01:46 PM
Indiana
Y
YO7_A66 Offline OP
YO7_A66  Offline OP
Y
Indiana
""I would like to use a dual plane (street car) and I am curious of opinions as to what dual plane W2 intake would be good on a street car that would keep the rpms under 6500 or so.""
How about intakes?
I am assuming that I would want to look for the Dual Plane W2 since I don't plan on high rpms. BuT I have read where the Dual Plane W2 may not be a good intake versus the Single Plane W2 intake.
Anyone running the Dual Plane W2 intake on a stock stroke 340/360 on the street?
Re: W2 Parts Questions [Re: YO7_A66] #1884548
08/03/15 07:53 PM
08/03/15 07:53 PM
Windsor, ON, Canada
Diplomat360 Offline
Diplomat360  Offline
Windsor, ON, Canada
Something else regarding the shafts to consider is whether the heads you end up with require the off-set hole locations on the shafts.
I'm in a bit of a similar situation as you...my next build plan calls for a stroker motor but W2 top-end, so far amongst nearly all the parts I have the long-valve Econo heads, but these take the standard on-center retaining bolt hole shafts...
Re: W2 Parts Questions [Re: YO7_A66] #1884624
08/03/15 09:44 PM
08/03/15 09:44 PM
Los Osos, Ca
CKessel Offline
CKessel  Offline
Los Osos, Ca
You need to figure out if you have the basic or econo heads. One has the pedestals to take the shaft directly and the other has them machined off which usually meant offset rockers and shafts. Makes a difference on all the pieces.
Carl Kessel
Re: W2 Parts Questions [Re: YO7_A66] #1884683
08/03/15 11:08 PM
08/03/15 11:08 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
This is an Race W2 head..notice the pedestal are machined flat..they require the stands and offset shaft.
Tony
Re: W2 Parts Questions [Re: YO7_A66] #1884684
08/03/15 11:10 PM
08/03/15 11:10 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
This is an Econo W2 the head has pedestals for the stock style rocker shaft.
this head is a standard length valve econo W2 head...there are also long valve Econo heads also.
Tony
Re: W2 Parts Questions [Re: 70AARcuda] #1884724
08/04/15 12:03 AM
08/04/15 12:03 AM
Indiana
Y
YO7_A66 Offline OP
YO7_A66  Offline OP
Y
Indiana
Thanks for the pictures on the heads. I have been collecting info on the w2 heads and I will add those to my notes.
Intakes: for a street driven W2 combo: dual plane or go with the single plane for a street setup?
If you run a W2 intake on the street, please let me know how it runs.
Thanks again to all!
Re: W2 Parts Questions [Re: YO7_A66] #1885228
08/04/15 10:16 PM
08/04/15 10:16 PM
Earth
Rob C Offline
Rob C  Offline
Earth
The only dual plane intake in now is the MP copy of the stock intake.
As far as single plane intakes go, I would look for the Holley Street Dominator. That would work with mild cams and gear ratios in the mid to low 3's. Use of a small carb would help. A 650 rather than a 750 improves throttle response.
Re: W2 Parts Questions [Re: YO7_A66] #1885348
08/05/15 12:38 AM
08/05/15 12:38 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
While I don't have W2s I am running ported edelbrock heads on a street driven 360 with a solid roller cam. I am running an Edelbrock Victor manifold and I have been real happy with it, no drivability complaints at all and it has made about 500HP on a good day going off of ET, MPH, and weight(11.18@120.5@3500lbs). The next motor is 90% complete and is a Ported W2 416 and I will be running an Edelbrock victor on it with some mild porting.
I have run single plane intake manifolds on several combos on both 340 and 360 and I have never had a complaint. The new stroker motor will be my first time with W2 stuff but I don't have any concern. The lack of a readily available W2 dual plane backs that up.
68 Barracuda Formula S 340
Re: W2 Parts Questions [Re: Bad340fish] #1885460
08/05/15 09:14 AM
08/05/15 09:14 AM
Indiana
Y
YO7_A66 Offline OP
YO7_A66  Offline OP
Y
Indiana
http://www.edelbrock.com/automotive/mc/manifolds/chrysler/victor-sb.shtml
""While I don't have W2s I am running ported edelbrock heads on a street driven 360 with a solid roller cam. I am running an Edelbrock Victor manifold and I have been real happy with it, no drivability complaints at all and it has made about 500HP""
""I have run single plane intake manifolds on several combos on both 340 and 360 and I have never had a complaint.""
""The lack of a readily available W2 dual plane backs that up.""
Thank you Bad!
I have read good reviews on the Victor intake. But since the power band starts at 3500rpms, this is why I have been looking into the W2 dual plane information. These are the part numbers that I have found so far:
P5249572: Aluminum, 9.600" deck height, dual plane
P5249572AB: Aluminum, 9.200" deck height, dual plane
I was thinking that since I will need to find a set of old W2's, I might as well search for a W2 dual plane intake too. If I can't find one in good shape, then the newer single planes may have to work. Or, I could have someone modify my existing RPM intake as an option and it specs out up to 6500rpms or so.
Thanks again for your reply.
Ref:
Aluminum Dual Plane Intake - 4 bbl Carb, W2 Heads
List Price: $300.00
Your Price: $255.00
You save: $45.00
Part Number :P5249572
Re: W2 Parts Questions [Re: YO7_A66] #1885477
08/05/15 10:07 AM
08/05/15 10:07 AM
Earth
Rob C Offline
Rob C  Offline
Earth
Sorry, having problems posting a picture of the Holley
Re: W2 Parts Questions [Re: YO7_A66] #1885609
08/05/15 02:21 PM
08/05/15 02:21 PM
P
Porter67 Offline
Porter67  Offline
P
Ive only one W2 motor but im sitting on alot of W2 parts, none for sale but the intake vary a good bit. Ive tried all in the pics except the new mopar dual plane as I just am concerned about the higher rpm aspect.
I probably should read more but whats your max rpm range and your converter and gearing?
Re: W2 Parts Questions [Re: YO7_A66] #1885611
08/05/15 02:23 PM
08/05/15 02:23 PM
P
Porter67 Offline
Porter67  Offline
P
More....I will go back and read from the top....
Re: W2 Parts Questions [Re: YO7_A66] #1885617
08/05/15 02:35 PM
08/05/15 02:35 PM
P
Porter67 Offline
Porter67  Offline
P
After reading the op, if your looking to stay under 6500 id consider a smaller plenum/runner single plane and a non ported set of castings since the whole concept of the W2 was to support higher rpm use imo.
There are still a few sets of nib shaft mount rockers floating around I know of in the $600 area, not mine but other racers.
Even unported 550-575hp is easy.
As well as I dont see why the mopar like w2 dual plane wouldnt support 6500 well, look at how we used to spin the 340-s with Xs and the 71 style intake.
