904 output shaft question #188442
01/09/09 12:28 PM
01/09/09 12:28 PM
Ansonia, CT
CJK440 Offline OP
CJK440  Offline OP
Ansonia, CT
I have 2 904 output shafts. The front tip on one has a plain round pilot for the thrust washer, the other has some funny shaped notches with a thrust washer that has keys that engage it. I guess this it to keep the friction surface on one side of the washer only.
Whats the real difference?? I want to change the output that has the "keyed" surface with the one with the regular pilot. Any reason why I can't just remove the "keys" inside the thrust washer an use it???
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
Re: 904 output shaft question [Re: CJK440] #188443
01/11/09 08:13 PM
01/11/09 08:13 PM
CT
turbocolt2.4L Offline
CT
the output shaft with the round pin takes a fiber washer and a steel shim on the forward drum if you mix and match need to make sure your endplay is good.
Re: 904 output shaft question [Re: turbocolt2.4L] #188444
01/12/09 10:48 AM
01/12/09 10:48 AM
Ansonia, CT
CJK440 Offline OP
CJK440  Offline OP
Ansonia, CT
For some reason I'm not too keen on the fiber washer, I'd rather use metal but the shaft I am going to is has the full round pilot.
Any reason why I can't just drill out the metal washer and use it??
Re: 904 output shaft question [Re: CJK440] #188445
01/12/09 08:10 PM
01/12/09 08:10 PM
CT
CT
i never drilled one but dont see why you cant.
