Scored 2 Danas!! Axles wont come out.
#188392
01/09/09 10:42 AM
01/09/09 10:42 AM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
A guy I know through work gave me two Danas. One being a 3.54 open and the other a 3.73 PowerLok. But, Ive got a problem with the 3.73 unit. One axle is broke in 2 places and wont come out. It broke off at the hub and also in the housing. Short of cutting the housing to get the axle out, any ideas? The other axle on the same rear wont come out either. Ive tried my best to get the floater assembly out, but it wont budge. I really dont care if I have to cut it all apart as the housing is too narrow (dually rear) for me. Any ideas besides Thanks
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: Scored 2 Danas!! Axles wont come out.
[Re: stroked470]
#188394
01/09/09 11:10 AM
01/09/09 11:10 AM
Von
NE Oklahoma
You will have to change the Spider gears out in the Powerlock if you use it. Most 3/4 and 1 ton rears have 16 spline axles. I believe Randy's Ring and Pinion sell the replacement gears.
Yeah, I know that. FWIW, the 3.54 rear has 30 spline axles, but Im going to 35 splines, so no matter.
[Re: Von]
#188395
01/09/09 11:21 AM
01/09/09 11:21 AM
I would start by chop sawing the housing ends off then see how far in the axle is broken. Then possibly weld a chain to whats left to pull it out. You have to cut the housing ends off anyway. Sheldon
