diplomat brakes on 69 road runner #188205
01/08/09 11:23 PM
01/08/09 11:23 PM
Ky
moparmafia Offline OP
Ky
i was wondering if anyone has swapped the disc brakes from a diplomat to 68- 70 b body? is this a safe swap? the caliper will be mounted on the front side and can this just be swapped to the other side? thanks for any help.
Re: diplomat brakes on 69 road runner [Re: moparmafia] #188206
01/09/09 12:00 AM
01/09/09 12:00 AM
Madison Wi
NTOLERANCE Offline
NTOLERANCE  Offline
Madison Wi
Ive got dippy cop car brakes on my 65 Coronet.
Pretty straight forward bolt on, had some problems getting a good brake hoes to work. I am sur ethere are better alternatives, but I finally decided on the diplomat hoses. they end up with a slight bend to them but they fit the stock 65 frame mount.
The spindles are slightly taller, (3/8") so it does change your steering/suspension geometry some. Some feel its a better change, some feel is worse, some feel it doesnt change anything.
My car doesnt even have a sway bar, so it didnt bother me.
