Re: FBO Ign System?
[Re: scratchnfotraction]
#1881460
07/30/15 12:45 PM
07/30/15 12:45 PM
RapidRobert
I talked to Don way back & yes he's an interesting guy to talk to. His coil was leaking oil out of the top right off the bat & I got sick & sat on the project for a year then called him & he said I should tighten the screw & I replied that a coil should not be leaking at all & he graciously sent me another one for free & for all he knew I coulda been driving it for a year before it went out (kudos to him for his generousity). But it gets worse, the one he sent me lasted for several months before it started missing on the way home one day & then an hour later going down the road it died completely & blew up the muffler with a loud bang as I coasted to the side of the road. That's been my FBO experience. Just me I dont agree with his timing procedure but his limiter plate sounds like a good deal. PS yes I was using a very generous ballast (1.6 ohms)
Re: FBO Ign System?
#1881482
07/30/15 01:38 PM
07/30/15 01:38 PM
Posts: 3,141 tennessee,usa
mattsmopars
tennessee,usa
I had one of his older kits several years back, that I was not impressed with at all. Matt
Re: FBO Ign System?
#1885956
08/05/15 11:01 PM
08/05/15 11:01 PM
Posts: 1,521 Tacoma, Washington USA
Adam71Charger
I've always heard 50/50 feedback about Don and FBO. Even so, I decided to go with a complete ignition setup from him and (as far as I know) he gave me a decent deal. Got the DAYTONA CD-1 Box, a locked out distributor and E-Coil (cant remember the e-coil brand) as well as brass cap/rotor.
I've had it for a couple months on the shelf waiting for my new engine to finally get fully assembled (waiting on a couple exhaust components, radiator, tran rebuild, and gas tank.)
Its been a while so I've forgotten all the features but the Daytona igntion Hooks up to a laptop and can 3d map your timing and nitrous timing, and you can program different curves like one for city driving, racing and have it retard for when you hit the nitro. It can retard up to 20 degrees if I remember correctly.
Anyways, I hope it works as cool as it sounds. Im not sure I should use it to break in the engine though, Ive never used an ignition like this before. I might just hook up the dizzy to a parts store ignition box and coil for the break in and then switch to the FBO box when my engine is out of the danger zone
Re: FBO Ign System?
#1886997
08/07/15 05:21 PM
08/07/15 05:21 PM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
I spoke with Don yesterday and ordered the kit with the book, springs and advance limiter plate for a friend of mine that runs a Dart Sport 360 in a class called Car Club Challenge here at Bremerton Raceway and Pacific Raceway. My friend has a modified 360 with the original unmodified distributor, some (MSD) add ons and other "tricks of the week". I am expecting his book and the distributor mods to make a difference. Subtle changes are easy and cheap to make and hardly anyone of us really needs "Arc Welder Ignition Systems", just proper timing and a clean spark at the plugs.
Of course, he also needs some fresh race tires, but that is not my problem
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
Re: FBO Ign System?
[Re: Adam71Charger]
#1887024
08/07/15 06:04 PM
08/07/15 06:04 PM
RapidRobert
What exactly do you mean by big block setup? the dist, a big block dist either a low deck one (383/400) or a high deck one (440/413) & lower shaft length is the (only) difference between the two
Re: FBO Ign System?
[Re: Adam71Charger]
#1887238
08/07/15 11:56 PM
08/07/15 11:56 PM
Posts: 15,445 Omaha Ne
TJP
Omaha Ne
I have a customer that bit and spent the $$ on a big block setup. Stock 69, 440 magnum. I will just say I was not impressed with the advance curves, or the way they went about achieving them. NUFF SAID, What exactly do you mean by big block setup? The "package' he bought was supposed to be tuned and tweaked for his application. The timing and advance curves setup in that distributor were BEYOND CONSERVATIVE, IE: think a pig performance and mileage wise. which is what it was, Think overheating to boot.
Re: FBO Ign System?
[Re: TJP]
#1887247
08/08/15 12:12 AM
08/08/15 12:12 AM
RapidRobert
What exactly do you mean by big block setup? The "package' he bought was supposed to be tuned and tweaked for his application. [quote] Oh OK it was a BB dist supposedly curved for his app
Re: FBO Ign System?
[Re: sogtx]
#1889312
08/11/15 04:21 AM
08/11/15 04:21 AM
Posts: 1,805 ky hills
thehemikid
ky hills
run away !! I guess the limit platesare cool , but .. Dont use his coils.. What trouble did you have with the coil? Leak, die, or ...
Re: FBO Ign System?
[Re: sogtx]
#1893586
08/17/15 02:56 PM
08/17/15 02:56 PM
RapidRobert
He cc'd me by mistake on a forward of an email to his supplier ... previous sale where i found a couple problems with his stuff... Wasnt pleasant. But the plates are cool... Why dint i think of thAt. He was bad mouthing a customers' complaint (you in this case) to his supplier and inadvertently sent a copy of that to you? Major faux paw (sp) on his part! Yes the plate is innovative but for $25 I'll make one myself
