Excessive ring wear with a small block stroker
#1878346
07/26/15 12:07 PM
07/26/15 12:07 PM
Posts: 1,487 STL
cdstl
STL
Have any of you guys, that have stroked a small block, had a lot more wear that requires a rebuild? Say after about 10k miles?
Some of the guys are batting around the idea that wear would be too much to accept if it needs to be rebuilt so soon.
Just trying to do some fact finding.
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
Re: Excessive ring wear with a small block stroker
[Re: cdstl]
#1878422
07/26/15 02:16 PM
07/26/15 02:16 PM
RapidRobert
Just trying to do some fact finding. go to www.mototuneusa.com and scroll down to & click on "breakin secrets" (easy 5 minute read) & see what you think
[Re: cdstl]
#1878710
07/26/15 10:30 PM
07/26/15 10:30 PM
Posts: 1,487 STL
cdstl
STL
Thanks, I was hoping that someone that has torn down a higher mileage stroker might chime in. Breaking-in is important, of course, but doesn't a stroker thrust against the outside wall more than a standard stroke motor? Thus wearing out the rings and bore faster?
I asked about ring wear when I should have asked about excessive bore wear. Which will take the rings out too.
Thx
[Re: lewtot184]
#1878861
07/27/15 12:34 AM
07/27/15 12:34 AM
RapidRobert
strokers and tatoos seem to be the fad now days and i don't particularly have a use for either. sooner or later the regret factor will raise it's head. I'm loosely considering one. what might I experience/run into that'll make me regret it? They ain't cheap thats for sure
[Re: RapidRobert]
#1878937
07/27/15 03:45 AM
07/27/15 03:45 AM
Posts: 6,906 IL, Aurora
ademon
IL, Aurora
strokers and tatoos seem to be the fad now days and i don't particularly have a use for either. sooner or later the regret factor will raise it's head. I'm loosely considering one. what might I experience/run into that'll make me regret it? They ain't cheap thats for sure Nothing from everyone I have talked to that has one. I'm thinking of a 4.125 stroke in a 340.
