Re: weak ignition?
[Re: bonefish]
#1879050
07/27/15 12:43 PM
07/27/15 12:43 PM
Thumperdart
State of confusion
can a weak MSD ign.effect AFR. Yep.....
Re: weak ignition?
[Re: bonefish]
#1879080
07/27/15 01:25 PM
07/27/15 01:25 PM
Posts: 715 Central TEXAS!!!!
sr4440
Central TEXAS!!!!
No it does not.
Lbs of air and lbs of fuel (the Air to fuel ratio) does not change because of a lack of or presence of a ignition source. Now if you are reading with a O2 sensor the lack of combustion will change the reading but the A/f has not changed at all. Climbing down off of my soapbox.
Joe
Without Data, you’re just another guy with an opinion.
Re: weak ignition?
[Re: Thumperdart]
#1879102
07/27/15 01:49 PM
07/27/15 01:49 PM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
REPHRASE:can a weak MSD ign. effect AFR READINGS.I think thump knew what I ment.
Re: weak ignition?
[Re: bonefish]
#1879257
07/27/15 04:30 PM
07/27/15 04:30 PM
Thumperdart
State of confusion
REPHRASE:can a weak MSD ign. effect AFR READINGS.I think thump knew what I ment. I knew what you meant and I stand by what I said.....no different than a bad spark plug/wire cap/rotor etc. Weak spark = rich mixture seen it many times..................
Re: weak ignition?
[Re: bonefish]
#1880522
07/29/15 02:33 AM
07/29/15 02:33 AM
Posts: 7,506 Az
Crizila
Az
this car was running perfect then all of a sudden it just started running real rich at cruise.it went from 13.8- 14.5 to 10.00 to 11.00 on the afr meter.ive checked everthing possible.the only thing I havnt changed out is the msd and the dist. What makes you think it's an ignition problem? Could be a fuel issue - carb related.
Fastest 300
Re: weak ignition?
[Re: Crizila]
#1880572
07/29/15 10:02 AM
07/29/15 10:02 AM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
this car was running perfect then all of a sudden it just started running real rich at cruise.it went from 13.8- 14.5 to 10.00 to 11.00 on the afr meter.ive checked everthing possible.the only thing I havnt changed out is the msd and the dist. What makes you think it's an ignition problem? Could be a fuel issue - carb related. Its the ONLY thing left that hasnt been replaced or thuroughly vetted.
Re: weak ignition?
[Re: Crizila]
#1880575
07/29/15 10:05 AM
07/29/15 10:05 AM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
this car was running perfect then all of a sudden it just started running real rich at cruise.it went from 13.8- 14.5 to 10.00 to 11.00 on the afr meter.ive checked everthing possible.the only thing I havnt changed out is the msd and the dist. What makes you think it's an ignition problem? Could be a fuel issue - carb related. Its the ONLY thing left that hasn't been replaced or thoroughly vetted.
Re: weak ignition?
[Re: bonefish]
#1880585
07/29/15 10:31 AM
07/29/15 10:31 AM
sr4440
Central TEXAS!!!!
if the ingnition was weak, or misfiring,. you would have incomplete combustion and the O2 would read lean (there's more oxygen left). There is only 2 ways for the O2 to read rich, you have added more fuel or you have less air. In each of these cases you must have combustion to burn all remainding oxygen.
just a note, with a weak ignition the O2 will read lean, plugs will be rich.
Have you checked your IAB's? they may have gotten pluged.
Joe
Re: weak ignition?
[Re: sr4440]
#1880594
07/29/15 10:57 AM
07/29/15 10:57 AM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
Joe I checked the carb out several times and even sent it back to BIGS. it came back with a clean bill of health.
Re: weak ignition?
[Re: dogdays]
#1880993
07/29/15 07:30 PM
07/29/15 07:30 PM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
Fuel pressure or carburetor power circuit.
R. been there ,done that,up down back and forth.
Re: weak ignition?
[Re: bonefish]
#1881060
07/29/15 09:05 PM
07/29/15 09:05 PM
Posts: 7,506 Az
Crizila
Az
R. been there ,done that,up down back and forth. If all that's left is the box and dist., go with the box first. All the wiring up to snuff? Alternator putting out at least 14 volts? Battery load test good?
Fastest 300
Re: weak ignition?
[Re: Crizila]
#1881130
07/29/15 10:13 PM
07/29/15 10:13 PM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
R. been there ,done that,up down back and forth. If all that's left is the box and dist., go with the box first. All the wiring up to snuff? Alternator putting out at least 14 volts? Battery load test good? brand new alt and batt.
Re: weak ignition?
[Re: bonefish]
#1881607
07/30/15 04:43 PM
07/30/15 04:43 PM
Posts: 12,129 Cleveland
sunroofgtx
Cleveland
Weak coil? How old and what type of coil?
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
Re: weak ignition?
[Re: sunroofgtx]
#1881616
07/30/15 04:58 PM
07/30/15 04:58 PM
Posts: 7,506 Az
Crizila
Az
Weak coil? How old and what type of coil? good place to start!
Fastest 300
Re: weak ignition?
[Re: sunroofgtx]
#1881694
07/30/15 07:33 PM
07/30/15 07:33 PM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
Weak coil? How old and what type of coil? brand new blaster 2,now I have a spare.
Re: weak ignition?
[Re: bonefish]
#1884287
08/03/15 01:59 PM
08/03/15 01:59 PM
Thumperdart
State of confusion
OK, I changed the 6al to a 7al-3 and put my old msd dist back in.no change. Have you checked each plug wire and changed the plugs yet?
Re: weak ignition?
[Re: bonefish]
#1884333
08/03/15 03:04 PM
08/03/15 03:04 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
Is it rich, or does your meter just "say" that it's rich?
Re: weak ignition?
[Re: Thumperdart]
#1884366
08/03/15 03:37 PM
08/03/15 03:37 PM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
OK, I changed the 6al to a 7al-3 and put my old msd dist back in.no change. Have you checked each plug wire and changed the plugs yet? new plug wires and im on my 3rd set of plugs.wires aint brand new maby 6 mo old.MSD 8.5
Re: weak ignition?
[Re: TRENDZ]
#1884371
08/03/15 03:40 PM
08/03/15 03:40 PM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
Is it rich, or does your meter just "say" that it's rich? plugs are black and sooty.it idles pretty fair but loads up real bad at cruise.if I let it idle awhile it will cruise ok for a few mi;les then load up again.
Re: weak ignition?
[Re: bonefish]
#1884385
08/03/15 03:58 PM
08/03/15 03:58 PM
Thumperdart
State of confusion
Is it rich, or does your meter just "say" that it's rich? plugs are black and sooty.it idles pretty fair but loads up real bad at cruise.if I let it idle awhile it will cruise ok for a few mi;les then load up again. FIX THE CARB.................
Re: weak ignition?
[Re: Thumperdart]
#1884403
08/03/15 04:16 PM
08/03/15 04:16 PM
Posts: 13,377 Marion, South Carolina [><]
an8sec70cuda
Sounds like you have carb issues. My old style 9375 dominator would foul out plugs going down the highway at 60 mph, but would idle clean all day. WOT was good too.
Re: weak ignition?
[Re: Thumperdart]
#1884406
08/03/15 04:18 PM
08/03/15 04:18 PM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
Is it rich, or does your meter just "say" that it's rich? plugs are black and sooty.it idles pretty fair but loads up real bad at cruise.if I let it idle awhile it will cruise ok for a few mi;les then load up again. FIX THE CARB................. im tryin to find someone around here with another carb or would be willing to try mine.ive had this carb apart numerous times and replaced every soft part.like I said I even sent it back to Bigs and he said it was perfect,he even X-rayed the dang thing.if I cant figer this DELEMA!! out pretty soon I may have to let that Thumper guy take a look at it
Re: weak ignition?
[Re: bonefish]
#1884451
08/03/15 05:03 PM
08/03/15 05:03 PM
Posts: 7,506 Az
Crizila
Az
Does the carb hold the float level while running? Sight plugs removed and fuel level set at the bottom of the sight plugs?
Fastest 300
Re: weak ignition?
[Re: bonefish]
#1884590
08/03/15 09:03 PM
08/03/15 09:03 PM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
Is it rich, or does your meter just "say" that it's rich? plugs are black and sooty.it idles pretty fair but loads up real bad at cruise.if I let it idle awhile it will cruise ok for a few mi;les then load up again. FIX THE CARB................. im tryin to find someone around here with another carb or would be willing to try mine.ive had this carb apart numerous times and replaced every soft part.like I said I even sent it back to Bigs and he said it was perfect,he even X-rayed the dang thing.if I cant figer this DELEMA!! out pretty soon I may have to let that Thumper guy take a look at it yes it does
