cooling system advice needed
#1878365
07/26/15 12:55 PM
07/26/15 12:55 PM
Posts: 92 south carolina U.S.
DOUGG
south carolina U.S.
current setup-65 satellite-383/.030 over-9.25 comp-3.73 gears.Problem is factory 22 in. radiator is taking a crap & running hot on 90deg. days. Has worked fine until recently(leaking & probly clogged) with flex fan & no shroud. Plan is to use 22in. alum. radiator ( 2 or 3 row ? ) with same fan & probably add shroud. Don't really want to cut core support for 26 in. Can this work?
Re: cooling system advice needed
[Re: DOUGG]
#1878391
07/26/15 01:30 PM
07/26/15 01:30 PM
Posts: 1,373 Rancho Cucamonga, CA
D_C
If it were my car, I would take your existing radiator, that you know fits, and have it Re-Cored to 3 or 4 Row High-Efficiency replacements. That is what I did for the 26-inch radiator in my '71 440 Charger 13-years ago and I have never had any cooling issues since. If you have a problem in the future, most any radiator shop can fix a Brass/Steel Radiator. Also, it will work and still look "Original" without needing to make modifications. Here is a Hotrod Magazine article on "How to Select a Radiator": http://www.hotrod.com/how-to/engine/1304cct-how-to-select-a-radiator/
[Re: DOUGG]
#1878418
07/26/15 02:12 PM
07/26/15 02:12 PM
RapidRobert
Since it happened all of a sudden (if I'm reading that correct) you might check the stat (toss it for a day/wont hurt anything). is it now running hot in stop & go or on the highway or both? I'd get a 3 row & there just was an informative thread on different alum rads having different tube sizes (see if you can retrieve it or scroll back several days/1 week). nothing else changed all of a sudden (timing/vac leak) that might be affecting this so k.i.s.s. a new rad sounds reasonable
[Re: RapidRobert]
#1878438
07/26/15 02:39 PM
07/26/15 02:39 PM
DOUGG
south carolina U.S.
thanks for the response guys. Didn't mention that car was originally 318 eng. Don't know if that matters. Not concerned about original. just want best system. Rad has leak all along bottom tank, & ran hot after 30 min. freeway driving at 2800rpm. Puked coolant at overflow. Looking at options. Thanks
[Re: DOUGG]
#1878445
07/26/15 02:51 PM
07/26/15 02:51 PM
Posts: 15,487 Omaha Ne
TJP
Omaha Ne
if you're trying to maintain a stock appearance their is only 1 place to go IMO. http://www.restorationradiators.com/about.htmWe had a problem child 22" radiator equipped factory 440 car that refused to run cool. After many lost hours and $$ Glen ray built a unit, we dropped it in and the problem went away.
[Re: DOUGG]
#1878555
07/26/15 06:11 PM
07/26/15 06:11 PM
Challenger 1
Cincinnati, Ohio
current setup-65 satellite-383/.030 over-9.25 comp-3.73 gears.Problem is factory 22 in. radiator is taking a crap & running hot on 90deg. days. Has worked fine until recently(leaking & probly clogged) with flex fan & no shroud. Plan is to use 22in. alum. radiator ( 2 or 3 row ? ) with same fan & probably add shroud. Don't really want to cut core support for 26 in. Can this work? First I would make sure your not lean on the fuel mixture. Then I would replace the flex fan, it does not move enough air. Then I would see it there's an improvement, I betting there will be. Then I would fabricate or buy some kind shroud for the radiator. I bet you there's nothing wrong with the radiator except for it's leaking. If any thing like said, have it re cored, don't replace it. Good luck.
[Re: DOUGG]
#1879576
07/27/15 10:32 PM
07/27/15 10:32 PM
Posts: 2,103 East Coast, NJ
fig426
East Coast, NJ
I"ll be putting a 3 core champion 26" in my T/A this week. I'm running warm so to rule out the radiator I bout one. $200 shipped. It doesn't look remotely original, but I need one for the race car so it will be my guinea pig to see if I have a radiator problem. If that cures it, then I'll get the original recored. I just don't know who recores around here.
Chris from New Jersey
[Re: fig426]
#1880188
07/28/15 05:44 PM
07/28/15 05:44 PM
DOUGG
south carolina U.S.
Thanks guys. Probably gonna use a champion. Don't need original as the entire car is modified from original & to recore mine is $$$$.
[Re: DOUGG]
#1880374
07/28/15 11:01 PM
07/28/15 11:01 PM
fig426
East Coast, NJ
Thanks guys. Probably gonna use a champion. Don't need original as the entire car is modified from original & to recore mine is $$$$. I put my champion in today . It is shiny and pretty. Then came the die grinder to enlarge the holes because they were off by about a quarter inch everywhere. Then came the drill to drill holes in the bracket to put the shroud on because those holes didn't line up, only to find that when all was said and done, the shroud doesn't fit flush with the radiator because the brackets for the shroud stick way out. But she sure is shiny. But when all was said and done, I am ok with the crappy fit for only $200 for the 3 core. ..... And.... I took it out in the 90 degree air and beat the snot out of it. The best I could get was 210 degrees creeping around and beating it. So I guess it works. Good luck.
[Re: mopower440]
#1880637
07/29/15 11:49 AM
07/29/15 11:49 AM
fig426
East Coast, NJ
Im having the same problem. I have the 1972 dart swinger with the 440 in it. I am using the original stock 318 radiator and shroud with flex fan. Its ok when its cold out but during the summer months here in TN. it wants to run 210-220 degrees. Im not sure what to do with it.. Pull a couple degrees out of the timing? That's my next step. See if I can lose some temperature there.
[Re: mopower440]
#1880703
07/29/15 01:18 PM
07/29/15 01:18 PM
RapidRobert
but during the summer months here in TN. it wants to run 210-220 degrees. Im not sure what to do with it.. this is stop & go I am assuming? I'd try a rigid fan blade properly spaced into the schroud if you have one laying around & other than that as said you might just need more radiator. I got a 2 core Champion off of evilbay for $189 to my door which ain't bad & I only had to redrill one hole in the dr side flat flange & it cooled OK but a DD 318 sure ain't gonna test its cooling capabilities
[Re: DOUGG]
#1880837
07/29/15 03:32 PM
07/29/15 03:32 PM
fig426
East Coast, NJ
How about a 6 vane vs 8 vane pump? Does one cool better than the other?
