Mopar did some under the table politicing as far as the 1963 "Stage Two cars and motors" are concerned, according to Tom Hoover at one of the old Mopar drag seminars in the mid 1970s all the "Stage Two cars" had hand modified combustion chambers, same thing on the intake manifolds and the later stage three carbs and camshafts. He said they where not production line made, special assembled off the line, for drag racing only
I've look at a lot of Max Wedge heads at a lot of swap meets and at races in SO CA ,AZ and Nevada and I have never saw or know any other Mopar racer(Landy, Bagshaw, Lambeck, Hickman, Deana, Hale, McCanless and so on, that has ever seen a set of the production heads with the Stage Two head casting numbers on them
IHTHs
