Re: vacum advance ports open or timed
[Re: Ken25]
#187420
01/08/09 01:15 AM
01/08/09 01:15 AM
RapidRobert
I would use ported & set the total(vac adv disconnected) at 38 & see where that puts your idle timing at & if that amount is enough for your particular cam for it to idle decent. For your curve if it is not pinging(too fast a curve) no damage is being done only that there would be more power to be had by a faster curve.
[Re: Ken25]
#187422
01/08/09 02:14 AM
01/08/09 02:14 AM
RapidRobert
you would raise the rpm up until it wont advance any higher which may be above 3000 rpm then turn the dist until you show 38 degrees & you would need a dial back light or a timing tape or a remarked timing marks to see where 38 degrees is at then lock the dist down THEN let it go back to idle & see where your idle timing is at(vac adv plugged for all of this) EDIT you would need your initial to fall between ~5-15 btdc & maybe back off your total from 38 if need be but see what you have 1st.
[Re: RapidRobert]
#187423
01/08/09 10:35 AM
01/08/09 10:35 AM
Posts: 738 Oh Canada
EV2CUDA
Oh Canada
Read the latest mopar mag explanation as to why to run your advance from ported, not direct vacuum. Steve Dulcich is the author.
71 Barracuda 383 4spd (500ci) 69 camaro 598, NOS 69 barracuda bbc procharger 77 t/a 6.0 turbo project 78 t/a 400 77 corvette 1983 hurst/olds 03 Viper 79 360 macho 71 demon 360 78 Warlock 5.7 hemi project
[Re: Ken25]
#187424
01/08/09 05:27 PM
01/08/09 05:27 PM
Posts: 1,760 Windsor, ON, Canada
Diplomat360
Windsor, ON, Canada
... not shure i understand how the system works pretty new at it
Do you understand the relationship between initial, mechanical and vacuum advance?
Initial is what you set the distributor up with BEFORE any advance kicks in. Usually done at idle.
Mechanical advance is what your distributor will throw in given the increasing RPM.
Vacuum advance is what the vacuum pot hooked up to the base plate of your distributor will throw in once the vacuum signal at the pot is sufficiently strong enough. This is in addition to the initial & mechanical advance. The 3 of them make up your TOTAL advance.
Now, that signal vacuum can be obtained from ported or direct vacuum source. Direct would typically be right from the intake manifold, often simply below the carb butterfly.
Ported source would come from a carb body, the primary difference is that this signal transmits the vacuum typically from a slot found in the primary bore of the carb, which is covered by the blades at idle. Once acceleration begins, the slot is exposed to manifold vacuum, and vacuum above and below the throttle blades equalizes.
This allows you to use initial & mechanical advance ONLY when accelerating, but when cruising you can utilize the additional vacuum advance, thus improving your fuel efficiency and mileage.
[Re: Diplomat360]
#187425
01/08/09 09:43 PM
01/08/09 09:43 PM
Posts: 3,895 Oregon
hooziewhatsit
So after reading this thread I went out and made sure my 318 was at 35* total (at ~3k rpms), with the vacuum advance disconnected.
Then, after I reconnected the vac advance, timing at 3k went to ~50-55*
So if I'm reading the above quote right, once I'm on the road, when I hit the gas, vacuum goes to near zero, so advance is initial + mech, ie, ~35*. While cruising, vacuum is high(er), so timing is initial + (less)mech + vac advance?
Right?
[Re: Ken25]
#187431
01/09/09 01:25 AM
01/09/09 01:25 AM
RapidRobert
turning the allen wrench in the vac can makes the can require more vacuum(or less depending on which way your turn the allen wrench) to overcome the spring tension & add advance. The amt of adv(in dist degrees) is stamped on the arm(which is inside the dist when its mounted). You can file the stops to add more adv that the can can provide or use paper clips or something similar to reduce its travel to reduce the amt of advance. & different cans give different amounts of adv that they can add & that # will be stamped on the arm. Vacuum adv is a very good economy aid & should be dialed in AFTER you have your initial & your mechanical curve dialed in.
[Re: GMP440]
#187433
01/09/09 08:18 PM
01/09/09 08:18 PM
Posts: 5,791 Hamilton, Ontario Canada
Magnum
Neither is wrong. Both offer additional advance above the mechanical and initial timing.
The ONLY difference between ported and manifold is you will have advance during idle and light throttle cruise conditions with manifold vacuum. Most engines need more timing at idle and using your starter as the gauge is wrong. You can also close your throttle blades more with more ignition timing at idle.
I've spend 2 years recording tank after tank in my truck. Ported and manifold have no effect on mileage. I'm sure it's better than without but my numbers show no improvement against each other. I did have tighten the carb idle speed screw with ported but had more torque just off idle with manifold. I have a manual trans. Not sure if this would be noticeable in an auto.
