Re: Gen III Hemi, please post things to avoid and know..
[Re: hudsonhornet7x]
#1862996
07/03/15 07:06 PM
07/03/15 07:06 PM
Posts: 3,101 cincinnati ohio
mcat4321
cincinnati ohio
Thanks guys, I am confused by EFI and am trying to learn as much as I can before the engine is in.
One last thing. Would tuning the engine with a magnuson supercharger be harder than N/A? not harder, just different
[Re: cudaman1969]
#1872523
07/17/15 08:30 PM
07/17/15 08:30 PM
Posts: 1,545 USA
hudsonhornet7x
USA
Couldn't find the other post on the Nag1 trans so I'll put it here. The output yoke is for a fixed driveshaft (no up and down). Found a simple solution, a 2006 Dodge Sprinter has a different yoke(four finger instead of three) that allows a u-joint type driveshaft to be attached. Replace the yoke (bolts on)and use a junk yard drive shaft. There is electronics now for this trans(five speed) and they are plentiful in salvage yards for about 500 apiece and they fit with no cutting. I think this is the same trans MB puts in the 500 hp AMGs. That bit of info is very interesting. Where do you find the electronic portion for the swap?
#1872531
07/17/15 08:42 PM
07/17/15 08:42 PM
Posts: 8,356 fredericksburg,va
cudaman1969
fredericksburg,va
Go back into early post of the guy who put a Gen111 in a 70 RR (he had a big write up on body stiffing also), he found some one to make up the control. I have it bookmarked so I'll go find it.
Guys name is Darius on for b body's only. Body stiffing
[Re: cudaman1969]
#1872885
07/18/15 02:18 PM
07/18/15 02:18 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
I was told not to do it. I insisted.
4 of 8 piston oilers broke off. 4.08 stroke
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: sixpackgut]
#1872890
07/18/15 02:23 PM
07/18/15 02:23 PM
Posts: 1,545 USA
hudsonhornet7x
USA
4 of 8 piston oilers broke off. 4.08 stroke Too much stroke in relation to the oilers?
[Re: gregsdart]
#1872910
07/18/15 02:58 PM
07/18/15 02:58 PM
sixpackgut
Charleston
Idk, plenty of clearance. I really dont know
[Re: gregsdart]
#1878948
07/27/15 08:08 AM
07/27/15 08:08 AM
Posts: 3,943 Melbourne.....Oz-land
Moparmal
Hi all - a while back I promised that Id do a genuine comparison between the Modman 6.1 intake and the Edekbrock 5.7 dual quad dual plane.
I experienced significant tuning issues with the Modman running both single and dual carbs - (333 RWHP) and it only really worked half way decent when I installed a full height divider (346 RWHP)
Below is the dyno chart ( same dyno..similar atmospherics) showing three (3) runs
The BLUE line was the Modman with divider - this netted a 11.9@ 114mph
The MIDDLE RED is the EDDY - same carbs - 360 rwhp
The Upper RED is the Eddy with twin 1" 4 hole spacers. - 368RWHP
A bit more tuning yielded 376 RWHP
The Eddy had a home port match to the 6.1 heads.
The headers were shorty hot rod headers - complete junk.
I think this proves conclusively that the Modman is a JUNK NA intake.
My guess is that the carbs are losing about 15 rwhp to the EFI....
Drivtrain losses ~ 90hp verified by mph/ weight at the track
[Re: cudaman1969]
#1888939
08/10/15 05:43 PM
08/10/15 05:43 PM
Posts: 310 Castle Rock, CO
wegner426
Castle Rock, CO
Couldn't find the other post on the Nag1 trans so I'll put it here. The output yoke is for a fixed driveshaft (no up and down). Found a simple solution, a 2006 Dodge Sprinter has a different yoke(four finger instead of three) that allows a u-joint type driveshaft to be attached. Replace the yoke (bolts on)and use a junk yard drive shaft. There is electronics now for this trans(five speed) and they are plentiful in salvage yards for about 500 apiece and they fit with no cutting. I think this is the same trans MB puts in the 500 hp AMGs. Are yo sure they fit with no cutting? The link to the only well documented install I have seen is below. As you go through the pages you will see they end up cutting the tunnel and the crossmember. http://www.forebodiesonly.com/forum/showthread.php?7651-Ma-s-cuda-A-long-time-coming/page4
[Re: wegner426]
#1888992
08/10/15 06:51 PM
08/10/15 06:51 PM
cudaman1969
fredericksburg,va
Couldn't find the other post on the Nag1 trans so I'll put it here. The output yoke is for a fixed driveshaft (no up and down). Found a simple solution, a 2006 Dodge Sprinter has a different yoke(four finger instead of three) that allows a u-joint type driveshaft to be attached. Replace the yoke (bolts on)and use a junk yard drive shaft. There is electronics now for this trans(five speed) and they are plentiful in salvage yards for about 500 apiece and they fit with no cutting. I think this is the same trans MB puts in the 500 hp AMGs. Are yo sure they fit with no cutting? The link to the only well documented install I have seen is below. As you go through the pages you will see they end up cutting the tunnel and the crossmember. http://www.forebodiesonly.com/forum/showthread.php?7651-Ma-s-cuda-A-long-time-coming/page4 Look up Darius, that's his post name, he can tell you everything you need to know. Did all this to a 70 RR. He has a great post on b-body's only.
[Re: cudaman1969]
#1889008
08/10/15 07:20 PM
08/10/15 07:20 PM
wegner426
Castle Rock, CO
Couldn't find the other post on the Nag1 trans so I'll put it here. The output yoke is for a fixed driveshaft (no up and down). Found a simple solution, a 2006 Dodge Sprinter has a different yoke(four finger instead of three) that allows a u-joint type driveshaft to be attached. Replace the yoke (bolts on)and use a junk yard drive shaft. There is electronics now for this trans(five speed) and they are plentiful in salvage yards for about 500 apiece and they fit with no cutting. I think this is the same trans MB puts in the 500 hp AMGs. Are yo sure they fit with no cutting? The link to the only well documented install I have seen is below. As you go through the pages you will see they end up cutting the tunnel and the crossmember. http://www.forebodiesonly.com/forum/showthread.php?7651-Ma-s-cuda-A-long-time-coming/page4 Look up Darius, that's his post name, he can tell you everything you need to know. Did all this to a 70 RR. He has a great post on b-body's only. Thanks for sharing this build, but it looks like the cutting of crossmember and tunnel starts on page 3. http://www.forbbodiesonly.com/moparforum/showthread.php?1121-B-Body-stiffening/page3
[Re: wegner426]
#1889137
08/10/15 11:00 PM
08/10/15 11:00 PM
cudaman1969
fredericksburg,va
Couldn't find the other post on the Nag1 trans so I'll put it here. The output yoke is for a fixed driveshaft (no up and down). Found a simple solution, a 2006 Dodge Sprinter has a different yoke(four finger instead of three) that allows a u-joint type driveshaft to be attached. Replace the yoke (bolts on)and use a junk yard drive shaft. There is electronics now for this trans(five speed) and they are plentiful in salvage yards for about 500 apiece and they fit with no cutting. I think this is the same trans MB puts in the 500 hp AMGs. Are yo sure they fit with no cutting? The link to the only well documented install I have seen is below. As you go through the pages you will see they end up cutting the tunnel and the crossmember. http://www.forebodiesonly.com/forum/showthread.php?7651-Ma-s-cuda-A-long-time-coming/page4 Look up Darius, that's his post name, he can tell you everything you need to know. Did all this to a 70 RR. He has a great post on b-body's only. Thanks for sharing this build, but it looks like the cutting of crossmember and tunnel starts on page 3. http://www.forbbodiesonly.com/moparforum/showthread.php?1121-B-Body-stiffening/page3 With the smaller yoke I showed I think you might get away without cutting anything other than the 4 bolt mount crossmember to fab the mount to the trans.
[Re: gregsdart]
#1905202
09/02/15 07:37 PM
09/02/15 07:37 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
I traded a 19 yr old BB for my 6.1 core and probably put another 7K in it with EFI and all. Headers: 800 Pan and pickup: 500 4.05 stroke rotator: 2300 cam used: 200 timing set: 90 lifters used: 100 Manley pushrods: 120 Manley springs: 350 Head work: 1400 Oil pump: 150 ATI balancer blem: 200 EFI setup: 1700 gaskets: 200
Mopar to the bone!!!
