fuel sender?? #1872077
07/17/15 12:49 AM
07/17/15 12:49 AM
mn
flyman Offline OP
flyman  Offline OP
mn
So I need to replace my fuel sender in my 1957 D100 truck project. I will be using the original dash. Does anyone know what the resistance values for the original sender is? Is there any aftermarket pieces available? Thanks moparts!!
Re: fuel sender?? [Re: flyman] #1872166
07/17/15 04:11 AM
07/17/15 04:11 AM
Rancho Cucamonga, CA
D_C Offline
D_C  Offline
There is this similar post from a few days ago:
https://board.moparts.org/ubbthreads/ubbt...tml#Post1869862
Re: fuel sender?? [Re: D_C] #1872305
07/17/15 02:01 PM
07/17/15 02:01 PM
mn
flyman Offline OP
flyman  Offline OP
mn
That post was on a Dart. I dont have a functioning sender to try. Mine was all rotted. Still looking for the answer to the ?
Re: fuel sender?? [Re: flyman] #1872343
07/17/15 03:10 PM
07/17/15 03:10 PM
D_C Offline
D_C  Offline
There are Parts for a '57 - '60 truck here, Group 3, third page:
http://www.vintagepowerwagons.com/pdf/parts/03fuel.pdf
There is a good, detailed "Allpar" article on Sending Units here:
http://www.allpar.com/history/mopar/electrical2.html
As far as the Testing Procedure, there is also something in the Moparts Tech Section, though you have to read through it:
http://www.moparts.org/Tech/Archive/fuel/10.html
There is a YouTube video on "Mopar Fuel Sending Unit Testing":
http://www.youtube.com/watch?v=ZxsNvqyq4Ts
And this "Mopar Muscle Magazine" article on Fuel Sending Units:
http://www.hotrod.com/how-to/engine/mopp-1208-fuel-sending-unit-replacement/
Re: fuel sender?? [Re: D_C] #1872396
07/17/15 05:10 PM
07/17/15 05:10 PM
mn
flyman Offline OP
flyman  Offline OP
mn
Lots of great info thank you very much!!!
