Sunk float on carb again #1871326
07/16/15 01:26 AM
07/16/15 01:26 AM
Prescott Az
73 SSP Offline OP
73 SSP  Offline OP
Prescott Az
help Would allowing the car to sit for a month cause the float to sink if not why does it happen? I just had the float replaced earlier this year for the same thing. This is a factory 2 bbl on a 400. Is this a common problem with 2 bbl carbs? purple help
Re: Sunk float on carb again [Re: 73 SSP] #1871344
07/16/15 01:56 AM
07/16/15 01:56 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I assume holley 2bbl?
Might be the ethanol in the gas. You may want to go to Holley's site and see if they have a ethanol resistant float.
That or it's off brand poor quality stuff.
Don't be the exception.
Re: Sunk float on carb again [Re: 73 SSP] #1871477
07/16/15 11:42 AM
07/16/15 11:42 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
If it's a plastic/phenolic float, replace it with a brass float, I've had this issue with the plastic/phenolic floats
Re: Sunk float on carb again [Re: 73 SSP] #1871913
07/16/15 10:11 PM
07/16/15 10:11 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Brass floats do it too, I've seen a bunch of brand new floats (regardless of the carb style) fail in this way. I have not seen a problem with older original brass floats that are cleaned up and re-used. So, it's either a new type of solder that todays fuel attacks, or just poor quality control.
twocents
Re: Sunk float on carb again [Re: 73 SSP] #1872023
07/16/15 11:49 PM
07/16/15 11:49 PM
Prescott Az
73 SSP Offline OP
73 SSP  Offline OP
Prescott Az
Thanks guys it turned out to not be a sunk float but dirt in the needle and seat.However I think its time to upgrade my rose to 4 bbl.
