Dyno Cost #187102
01/07/09 08:50 PM
01/07/09 08:50 PM
NW Pa.
KD800X Offline OP
KD800X  Offline OP
NW Pa.
What is the going rate for dyno time?
Re: Dyno Cost [Re: KD800X] #187103
01/07/09 08:55 PM
01/07/09 08:55 PM
Col. Ohio
The Avg. Valiant Offline
Col. Ohio
Its about $100 an hour here, thats with all the gadgets and unlimited changes. I think we can get 6 hours unlimited for like $450 I believe. 3 pulls is $65 no A/F
Re: Dyno Cost [Re: The Avg. Valiant] #187104
01/07/09 08:57 PM
01/07/09 08:57 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
here in central fl I was given a price of 600 per day plus fuel and chemicals
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Dyno Cost [Re: dusturbd340W5] #187105
01/07/09 09:29 PM
01/07/09 09:29 PM
NW Pa.
KD800X Offline OP
KD800X  Offline OP
NW Pa.
Thanks!
I was just checking, I got a price of $600.00 with our fuel. So it's in the ball park. I just wanted to check and see if that was the going rate.
Thanks again
Re: Dyno Cost [Re: KD800X] #187106
01/07/09 09:31 PM
01/07/09 09:31 PM
Toronto Ontario, Can
Glen440 Offline
Glen440  Offline
Engine or chassis dyno?
It costs me about $100 an hour on chassis dyno with a discount for a long session.
$400 a day on engine dyno.
87 dakota 6.1 hemi
Re: Dyno Cost [Re: KD800X] #187107
01/07/09 10:48 PM
01/07/09 10:48 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Thanks!
Thanks again
Sounds way high to me
Re: Dyno Cost [Re: Bob_Coomer] #187108
01/07/09 11:06 PM
01/07/09 11:06 PM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
We charge $650 a day to dyno.... included in that is paying for 3 employees (myself, the dyno operator, & one other SDSS employee) for an entire day to work on setting up engine/tune/remove engine.....
I don't really allow customer to do much at all to motor themselves that day if they are there, they sit back & watch.
The cost of that piece of equipment (new state of art dyno)& the special room it is ran in, water system etc is over $100K... that's also big part of what you're paying for. For that kind of $ it should be on nice well kept dyno in a nice test cell.
If you're dynoing at a hole in wall place with no built in dyno test cell etc. on a 20+ year old homemade/hodgepodge dyno I'd expect cost to be less. I've seen lots of videos on youtube of some pretty ratty looking dynos/cells/rooms that I know I would'nt want to test a motor on/in & would be embarrased to charge $650 to dyno on.
Re: Dyno Cost [Re: RyanJ] #187109
01/07/09 11:47 PM
01/07/09 11:47 PM
Glendale Az
Darryls-Demon Offline
Glendale Az
I payed 800.00 dollars for three break in pulls and two power pulls.
The timing was set once valves lashed twice,plugs changed once and one jet change.
Oh and the motor was built at this shop.
Re: Dyno Cost [Re: Darryls-Demon] #187110
01/08/09 01:11 AM
01/08/09 01:11 AM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
around here in so cal 600-700 a day plus fuel
Re: Dyno Cost [Re: 70blackfish] #187111
01/08/09 01:20 AM
01/08/09 01:20 AM
the last time I used Vrbancic Bros. DTS dyno in SO CA it was $500.00 a day plus fuel, that was in early 2005 The local Pro power dyno in Madras,OR is $500.00 a day also. I do all my own tuning and parts changing so that prtobally doesn't make it cheaper. it' my motor and I want to work on it my way, not pay someone else to do it their way My feel on a tight lash is ultra tight to some and real tight to other guys that build motors, we all have are own ways and feel
Re: Dyno Cost [Re: Darryls-Demon] #187112
01/08/09 01:22 AM
01/08/09 01:22 AM
Wellington, Ohio (20 minutes f...
MrMoparRacing Offline
Koffel's Place II
740 River Road
Huron, Ohio 44839
Phone: 419-433-4410
Fax: 419-433-2166
Development Work (10 hours with Fuel, Lubricants & parts extra operator) $900.00/day
Run In and Power Check-Street/Strip (Chev. & Chry) $350.00
Run In and Power Check-Race $450.00
Run In and Power Check-All others $550.00
I have Scott Koffel build all of my engines and I could not be happier! My 408 with cast iron old 2.02/1.60 (slightly worked) heads with a .630 roller cam has ran a best of a 9.77 @ 140mph in my 1970 Dart.
Re: Dyno Cost [Re: MrMoparRacing] #187113
01/08/09 01:50 AM
01/08/09 01:50 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
a little over a year ago, my wife let me do a an engine dyno day at kammer&kammer in dayton Oh. they're also mopar racers!
full dyno day, with A/F, tuning, etc. I think the day was $300? or was it $500? I don't remember now...they'll do 3 chassis pulls for $100, maybe $300 was chassis dyno with tuning, and $500 was for an engine dyno day. I really can't remember now--mostly because my out the door bill was about $1200! yea, the wife wasn't too happy about that, but their quoted price over the phone did not include fuel, oil, gaskets, etc. so that was probably another $100-150 or so added on, and then my Eddy 750 carb w/electric choke gave up 90hp to a holley 750HP (no choke), both were OOTB, so that was another $650 added in! plus a lift plate so I could quit using my chains bolted to the engine to lift it...
definitly worth the price though. it was a day to myself, no work, no family, just me and my hobby, hanging out with a bunch of guys who build engines for a living. I was in heaven, walking around their shop checking out various projects they had going on, picking their brains about engine building, etc.
I'd do it again, and WILL do it again when Iget the motor built for my Cuda. I just hope I can get to it in this lifetime before they either forget about me or all retire!
**Photobucket sucks**
Re: Dyno Cost [Re: 70Cuda383] #187114
01/08/09 01:51 AM
01/08/09 01:51 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
plus, I can say that I know for sure, exactly what the power level of my engine is, and I won't be your "typical GM guy" who just adds the numbers from the catalog together to claim that their 8.0:1 SBC with mild cam, intake, and headers is making 500 Hp.
Re: Dyno Cost [Re: 70Cuda383] #187115
01/08/09 09:26 AM
01/08/09 09:26 AM
i paid
$400.00 for a full day .i brought my own fuel.
Re: Dyno Cost #187116
01/08/09 11:23 AM
01/08/09 11:23 AM
SoCal
Brian Hafliger Offline
SoCal
We charge 450.00 if we build it, or 550.00 for off the street customer.
Re: Dyno Cost [Re: Brian Hafliger] #187117
01/08/09 12:31 PM
01/08/09 12:31 PM
Mt. Eden Ky.
Hemi Allstate Offline
Mt. Eden Ky.
I paid $400. plus fuel etc. Amongst other things I think breaking the engine in on the dyno, may save the $350 ceramic coating on my headers. This and the ability to monitor closely all the vitals , during break in made the cost well worth it to me.
I also enjoyed being with "like minded" people for the day.
Mark
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: Dyno Cost [Re: RyanJ] #187118
01/08/09 07:04 PM
01/08/09 07:04 PM
Carbondale PA
Domino1609 Offline
Domino1609  Offline
Carbondale PA
Ryan, we both have been at one dyno that fits the list!!
Dont say it though!
LOL
Rick
Re: Dyno Cost [Re: Hemi Allstate] #187119
01/08/09 07:09 PM
01/08/09 07:09 PM
NEW JERSEY
BIGSPEED Offline
BIGSPEED  Offline
NEW JERSEY
We charge 88.00$ per hour if we build the engine or 110.00per hour for outside jobs.Our Superflow 600 is equiped with wideband o2 to monitor each individual cylinder,the only correct way to evaluate manifold distribution and firing orders.
Ceralli Racing Engines & Checkered Flag Machine Racing engines , CNC porting & induction development http://www.checkeredflagmachine.net/
Re: Dyno Cost [Re: MrMoparRacing] #187120
01/08/09 07:29 PM
01/08/09 07:29 PM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
Koffel's Place II
740 River Road
Huron, Ohio 44839
Phone: 419-433-4410
Fax: 419-433-2166
i went there too!
Re: Dyno Cost [Re: blownzoom440] #187121
01/09/09 02:58 AM
01/09/09 02:58 AM
NW Pa.
KD800X Offline OP
KD800X  Offline OP
NW Pa.
Hey Guys,
Thanks for all the reply’s. You've helped me out a lot. I'm not getting the best price in town, but nothing worth while is cheap, but at least I'm not getting screwed either.
We're not looking to try to find every ounce of HP we can fine. I'm just looking to find the fuel curve to for jetting and I want to know the Peak Tq and HP to eliminate a lot of guess work, and maybe try a couple of different things. $600.00 is still cheaper than wasting half the season, burning up a set of tires and entry fees + fuel, only to chase ghosts.
Again thanks for your help
Kevin
