Page 2 of 3 1 2 3
Re: Replacing Timing Chain [Re: MoparforLife] #187078
01/08/09 09:43 PM
01/08/09 09:43 PM
Someplace you aren't
SomeCarGuy Online content
SomeCarGuy  Online Content
This is getting funny. Some of you guys act like degreeing a cam is some sort of high science.
I couldn't care less what you did 40 years ago. Giving a rookie advise like skipping simple check work is crap. It takes a very few minutes to due. Not doing it is just plain LAZY.
Try for more than 40 years. Experience works. Parts are probably closer to specs now than they were then and it worked then as it does now. You sound like one that thinks that every engine out there off the line has been degreed. Yep I am getting lazier by the year. You will to.
It is just poor advise to tell a newbie that it isn't needed. What if he gets off a tooth? Not hard to do when you don't have 40 years experience. I just hate to see something so simple get pushed aside. If he has a problem later, guess what, the installed centerline will be asked and he will have to pull it apart again to check. MUCH easier to do now.
Ever have a "factory freak" or a "dog"? Details do matter.
Re: Replacing Timing Chain [Re: SomeCarGuy] #187079
01/08/09 10:53 PM
01/08/09 10:53 PM
Chicago suburbs
dartgame Offline
dartgame  Offline
Chicago suburbs
If you want to save some money and do not want to check the center line - at least compare your old timing sets gears and marks to the new ones on the replacement set. At least you'll then have some idea if the marks are out of whack.
Once upon at time I had a name brand timing set that was mismarked. I installed it and low and behold the motor ran like crap. I pulled it apart and found one of the marks was a tooth off. Ever since then I check the centerline on every build I do. Better to know, than not know.
Re: Replacing Timing Chain [Re: HemiStan] #187080
01/08/09 11:10 PM
01/08/09 11:10 PM
pacific northwest
W
wings471 Offline
wings471  Offline
W
pacific northwest
wtucker,
I live up in Newport News. Shoot me a PM with your number and I can talk you through putting that timing chain in.
Stan
You can't beat a generous offer like that. The opportunity to learn how to do something like this just makes your mechanical knowledge greater and will aid in understanding other related technical questions/problems ...do it.
Re: Replacing Timing Chain [Re: dartgame] #187081
01/08/09 11:14 PM
01/08/09 11:14 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
Amen from the cheap seats. You guys can brag all you want to about building a thousand or a million motors. I started about 30 year ago and have built maybe a hundred or so. I have found TWO motors that the timing marks were off from the factory. They were both 340 factory sets or may have been replacement sets. One was off 8 and the other off 16 degrees. The friend with the 16 degree off motor always wondered why it ran like crap. I have found a few aftermarket sets needing as much as 4 degrees to correct.I would say the chances are less than 2-3% it would be off more than a few degrees, but it can happen. Degreeing a cam is not rocket science and is just the first step in learning how to blueprint motors. Buying mics and tools will make it enjoyable to build motors. Get busy and learn.
Re: Replacing Timing Chain [Re: SomeCarGuy] #187082
01/08/09 11:31 PM
01/08/09 11:31 PM
Hampton, Ga.
70dart360 Offline
Green Meister
70dart360  Offline
Green Meister
Hampton, Ga.
If its stock dude whats the use? Its gonna be a pig anyway ya look at it. And as far as valve to piston clearance in a stocker Mopar? Whatever, the dang piston is 1/4 inch in the hole. Say what ya want, but I been a master mechanic for 25 years and unless its a performance engine why waste the time and try to confuse they guy? Never seen someone degreee a cam in a stock engine doing a basic timing chain job. You must be one of those shop owners that suck every red cent out of their customers for worthless extras!
Line your dots up man and run with it.
70 Dart Swinger 72 D-100 440 shortbed 76 Pinto, 68k 21mpg!
Re: Replacing Timing Chain [Re: 70dart360] #187083
01/09/09 12:13 AM
01/09/09 12:13 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
Re: Replacing Timing Chain [Re: MoparforLife] #187084
01/09/09 12:42 AM
01/09/09 12:42 AM
California
mickm Offline
mickm  Offline
California
or how about, if he feels like getting more technical and learning something new, degree it.
if he doesn't, don't.
problem solved.
Re: Replacing Timing Chain [Re: SomeCarGuy] #187085
01/09/09 12:47 AM
01/09/09 12:47 AM
This is absolute nonsense. FIRST degreeing a cam won't do much good if you don't know what you started with. That is, it might run better on the factory marks, anyhow.
SECOND just because you didn't degree the damn thing does not mean you'll "get it off a tooth."
Please don't make fun of 40 years experience. Engines pretty much work the same way now as they did 40 years ago, WAIT!!! WAIT!!! WE ARE talking about a 40 year old engine!!!!
I'll guarantee you that the thousands of 340's 440's 383's and probably street hemi's that went down the production line NEVER SAW A DEGREE WHEEL. The factory assembly line folks slapped the sprocket "on the marks" and down the line it went.
AND ONE LAST TIME. If you get the cam "on the marks" degreeing will NOT do you any good until you have a baseline. Depending on whether this is a "torque monster" street engine or an RPM screamer, you won't know which way to push the wheel until you find the baseline.
From the sounds of the original poster, I doubt that he has access to a chassis dyno, and neither do most of the rest of us.
Re: Replacing Timing Chain #187086
01/09/09 01:09 AM
01/09/09 01:09 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
This is my point exactly.If you lined it up "on the marks" as you call it, the timing marks could be off and you would never know.The only way to check the marks is to degree it. You say that you have done thousands of engines and never degreed a stock motor, then how do you know they were all correct? One of the motors that I found to be off 8 degrees was one that I had built before I started checking the cam degree. I always wondered why is had less low end torque than I expected. I agree that the chances are slim, but I have had two in my "short" 30 years of engine building.
Re: Replacing Timing Chain [Re: fastmark] #187087
01/09/09 01:14 AM
01/09/09 01:14 AM
Hampton, Ga.
70dart360 Offline
Green Meister
70dart360  Offline
Green Meister
Hampton, Ga.
Take all the mechanics that dont, and break it down into odds like in Vegas. Bout a million to one that it'll make a drastic difference.
Re: Replacing Timing Chain [Re: fastmark] #187088
01/09/09 01:38 AM
01/09/09 01:38 AM
Just for clarity, I never said that.
The point I'm trying to make, though, is that DEGREEING a cam to whatever the grinder specked does not guarantee that is what you are going to want. So without trying it, establishing a baseline, and then deciding to advance/ retard it from there is simply shooting in the dark
Re: Replacing Timing Chain #187089
01/09/09 10:49 AM
01/09/09 10:49 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
I agree with that statement. I decided that since I was a decent engine builder, I would build my own Jr Dragster motors a few year back. I did not realize the close tolerances and severe duty that was placed on the parts. I only had one failed motor in all those years so I can safely say I was successful. One of the things I tried was changing the cam timing to kill the low end and give me better finish line power. My engine part provider said not to do it and he had his cams dialed in to the perfect degree as per his R and D. I used his cam timing for awhile and then went to my experiment. Small changes in a 50 hp 3.5 Rhino make a big difference. After that I had less trouble with tire spin and ran max mph. We were usually the fastest kids at the track. Man I miss those days.
Like I said, the marks are probably ok and just lining them up will be fine. It always pays to check.I kind of get like the mad scientist when I get mics in my hand. It's fun!
Re: Replacing Timing Chain [Re: fastmark] #187090
01/09/09 11:30 AM
01/09/09 11:30 AM
Upper Midwest
Upper Midwest
So far no one has brought up the fact that the gear broke - where are the pieces? The pan should really really be pulled and cleaned. The threads at least checked for condition to see if they will hold or if a new cam is in order. If this is an old engine it wouldn't hurt to check bearings while the pan is off.
As for degreeing this cam it is an unknown centerline so you need a base line to start with. Put the gears and chain on and run it.
Re: Replacing Timing Chain #187091
01/09/09 11:33 AM
01/09/09 11:33 AM
Kirkland, Washington
Pacnorthcuda Offline
I don't build engines, but I install cams from time to time, and I want to KNOW the installed centerline so I have that baseline info. If I install a cam straight up without degreeing it I don't really know what the ICL is. Then, if some issue comes up, like a soft bottom end, or a top end that lays down early, I am left guessing if its the cam ICL or not. My last install on a Voodoo ended up 106.75 on a recommended 106 install. (yes I installed straight up) If I did not degree it, I would not know.
Re: Replacing Timing Chain [Re: 70dart360] #187092
01/10/09 01:24 AM
01/10/09 01:24 AM
This is a performance website so...
A stock engine will need all the help it can get and if it is off it will for sure be a pig.
Why leave it to chance on the sole reason that you feel like being lazy?
Re: Replacing Timing Chain [Re: 70dart360] #187093
01/10/09 01:25 AM
01/10/09 01:25 AM
Why roll the dice?
Re: Replacing Timing Chain #187094
01/10/09 01:26 AM
01/10/09 01:26 AM
Yes, you need a baseline but without doing the job you will be pondering about what to do without a clue.
Re: Replacing Timing Chain [Re: SomeCarGuy] #187095
01/10/09 08:45 AM
01/10/09 08:45 AM
Ansonia, CT
CJK440 Offline
CJK440  Offline
Ansonia, CT
What if the intake lobe for #1 was ground right and all the others ground off???
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
Re: Replacing Timing Chain [Re: SomeCarGuy] #187096
01/10/09 08:45 AM
01/10/09 08:45 AM
Upper Midwest
Upper Midwest
Another point being like in this case it is an unknown and unknown spec. No idea what to degree it to. Yep better pull a number out of your A&& and that will be fine, it is degreed now.
Whoopie Poopie this is a performance sight, that being the case it is an unwarranted question for it being a stock engine. No more non performance questions asked here. Oh better run right out and degree that driver too because coming from the factory it wasn't. Suprising that they even run not being degreed. BTW: if it makes you feel better by all means go ahead and degree it. But for a driver you won't gain squat.
Re: Replacing Timing Chain [Re: MoparforLife] #187097
01/10/09 08:48 AM
01/10/09 08:48 AM
Ansonia, CT
CJK440 Offline
CJK440  Offline
Ansonia, CT
And what about the valves??? If it broke while running I'm sure some met the pistons in a bad way.
Page 2 of 3 1 2 3
