QUESTIONS ABOUT DIFFERENT FUELS........
#1867393
07/09/15 09:21 PM
07/09/15 09:21 PM
Thumperdart
State of confusion
I`ve been running VP-100 and 101 unleaded fuels for 3+ years now and noticed the timing needs are slightly different from this compared to say 110 leaded and was curious for those w/a dyno or those that have dynoed different fuels how they differ on the egt`s. I would ASSume the unleaded burns hotter but not sure so what have you guys found.............Thankxxx
Re: QUESTIONS ABOUT DIFFERENT FUELS........
[Re: Thumperdart]
#1867566
07/10/15 03:11 AM
07/10/15 03:11 AM
Thumperdart
State of confusion
So no one has compared egt`s between unleaded and leaded or is it top secret................ Or does it not work that way........just trying to learn here.
[Re: Thumperdart]
#1867655
07/10/15 11:49 AM
07/10/15 11:49 AM
Posts: 19,384 Las Vegas
Al_Alguire
Las Vegas
Never played with unleaded race fuels or cared what pump gas swill did honestly. Then again we don't look at EGT numbers either just O2 data. IMO EGT info can be misleading at times. Only thing we use it for is to make sure a cylinder is firing. In a blown, alky or nitrous deal it is a more helpful barometer IMO.
[Re: Al_Alguire]
#1867666
07/10/15 12:11 PM
07/10/15 12:11 PM
Thumperdart
State of confusion
Thankxx Al, I think I`m going to go back to mixing 110 leaded w/91 pump 50/50 for the cooling effects of leaded and my car ran real good that way in the past.
[Re: Thumperdart]
#1867679
07/10/15 12:46 PM
07/10/15 12:46 PM
Posts: 52,972 Romeo MI
MR_P_BODY
For years we use to use EGT for the balance of fuel.. but now that A/F meters came about most think EGTs are nothin but trash.. I still use them to balance intakes(runners).. and until about 15 years ago that was also how some tuned the fuel...most fuels are designed for 1280*-1300*... some will go higher.. but you have to know what all the specs are on that fuel... if it doesnt give the temp spec on the MSDS sheet call the company... and 2 companies that make the same fuel wont be the same
[Re: Thumperdart]
#1867685
07/10/15 12:53 PM
07/10/15 12:53 PM
Al_Alguire
Las Vegas
You can find 100 unleaded in Vegas Dom. At some of the Rebel stations in town.
[Re: Thumperdart]
#1867700
07/10/15 01:16 PM
07/10/15 01:16 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Higher octane is slower burning so it would want more timing. Generally speaking.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: Al_Alguire]
#1867725
07/10/15 02:20 PM
07/10/15 02:20 PM
Thumperdart
State of confusion
You can find 100 unleaded in Vegas Dom. At some of the Rebel stations in town. Thankxx guys...............Ya, I found 100 at the pump and in pails but figured it`s cheaper to mix 50/50 since 100 is about the same price last time I checked.
[Re: Thumperdart]
#1867745
07/10/15 02:41 PM
07/10/15 02:41 PM
Posts: 7,506 Az
Crizila
Az
I`ve been running VP-100 and 101 unleaded fuels for 3+ years now and noticed the timing needs are slightly different from this compared to say 110 leaded and was curious for those w/a dyno or those that have dynoed different fuels how they differ on the egt`s. I would ASSume the unleaded burns hotter but not sure so what have you guys found.............Thankxxx As said, not too many guys running individual thermocouples for EGT data anymore - for the reasons stated ( 02 info ). I run Sunoco 110 leaded pump race gas because 1. their use description fits my application. 2. It's less expensive than buying fuel at the track. 3. fuel at the track isn't always available. 4. Not much interested in lugging a 5 gal can of fuel around the pit area. Sunoco 100 ( unleaded ) is also available at the same station where I get my 110 for the same price. From what I have seen, combustion chamber temps are pretty much in the range that Mr P stated. FWIW, looking at the specs of the 2 mentioned fuels, unleaded 100 has a BTU / gallon of 109200 while 110 leaded has a BTU/gallon of 113400. Sooo, it appears that 110 leaded puts out more heat than 100 unleaded ( which also BTW, contains 9.8% ethanol ). Conclusion = I have no idea? For sure, a change in fuels would warrant a change in timing. As you said Dom, dyno info.
Fastest 300
[Re: Crizila]
#1867779
07/10/15 04:10 PM
07/10/15 04:10 PM
Challenger 1
Cincinnati, Ohio
I`ve been running VP-100 and 101 unleaded fuels for 3+ years now and noticed the timing needs are slightly different from this compared to say 110 leaded and was curious for those w/a dyno or those that have dynoed different fuels how they differ on the egt`s. I would ASSume the unleaded burns hotter but not sure so what have you guys found.............Thankxxx As said, not too many guys running individual thermocouples for EGT data anymore - for the reasons stated ( 02 info ). I run Sunoco 110 leaded pump race gas because 1. their use description fits my application. 2. It's less expensive than buying fuel at the track. 3. fuel at the track isn't always available. 4. Not much interested in lugging a 5 gal can of fuel around the pit area. Sunoco 100 ( unleaded ) is also available at the same station where I get my 110 for the same price. From what I have seen, combustion chamber temps are pretty much in the range that Mr P stated. FWIW, looking at the specs of the 2 mentioned fuels, unleaded 100 has a BTU / gallon of 109200 while 110 leaded has a BTU/gallon of 113400. Sooo, it appears that 110 leaded puts out more heat than 100 unleaded ( which also BTW, contains 9.8% ethanol ). Conclusion = I have no idea? For sure, a change in fuels would warrant a change in timing. As you said Dom, dyno info. I have been retailing race fuel for like 25 years, sell Sunoco. Have never seen any kind of spec sheet that show what the EGTs should be. I don't recommend blending fuels because it can affect consistency, maybe that is not concern of yours? Plus its a major hassle. For a street car, I guess no big deal but sure would make it harder to tune. We sold both Sunoco fuels too at the pump, 110 leaded and 100 octane unleaded...with a ton of ethanol in it. Like said. I don't know about you, but I would not want ethanol in my performance gas. We did not sell much 100 octane unleaded, we sell tons of 110 leaded out of the pump plus we stock many other grades in 54 gallon drums. This past spring I took out the 100 octane unleaded and started selling 91 octane straight unleaded with no ethanol. This would be the gas to blend, with no ethanol. We have many street customers do just that. Buy a little of both and put it right into there muscle car at the pump. We have sold way more of that gas so far this year than we did 100 octane all last year, like 4 times as much so far. It's popular for small engines and classic cars. It stores well and will last for years, try that with 100 octane with tons of ethanol in it. And yup 110 leaded has more btus than unleaded so it will make more power(heat) than unleaded just because of the BTUs. I don't think it would change how hot your car runs, that's done by richer or leaner. You could easier make the "hotter" fuel burn cooler just by adding more fuel to the engine.
[Re: Monte_Smith]
#1867842
07/10/15 06:54 PM
07/10/15 06:54 PM
MR_P_BODY
An EGT number is just a number. As Al said, it basically tells you if a cylinder is running and not much else. The design of the header can have as much to do with EGT numbers as anything. They are more reliable in zoomies than regular headers for obvious reasons. BENDS effect things, numbers included At Chrysler we FINALLY set a standard of 1" off the head surface for ALL exhaust reading(EGT).. before for that guys were putting the probes in where ever they liked... and when I say 1".. thats measured within .005.. thats why the 1".. its easy to get that point.... over the years since O2s came around I used to set max power based on the O2 then check with the EGTs on all the cyls just to see what the numbers were in relationship to what the fuel companies called out for max temps... its very close... yes guys now days wouldnt ever think about EGT... but the top fuelers and all those guys still use them
[Re: Al_Alguire]
#1867899
07/10/15 09:08 PM
07/10/15 09:08 PM
Posts: 3,667 Arizona
Chris'sBarracuda
Arizona
Never played with unleaded race fuels or cared what pump gas swill did honestly. Then again we don't look at EGT numbers either just O2 data. IMO EGT info can be misleading at times. Only thing we use it for is to make sure a cylinder is firing. In a blown, alky or nitrous deal it is a more helpful barometer IMO. Who makes a good inexpensive O2 sensor.?? Chris..
[Re: Chris'sBarracuda]
#1867958
07/10/15 10:43 PM
07/10/15 10:43 PM
Posts: 7,506 Az
Crizila
Az
Never played with unleaded race fuels or cared what pump gas swill did honestly. Then again we don't look at EGT numbers either just O2 data. IMO EGT info can be misleading at times. Only thing we use it for is to make sure a cylinder is firing. In a blown, alky or nitrous deal it is a more helpful barometer IMO. Who makes a good inexpensive O2 sensor.?? Chris.. I went with "Inovate" from Summit # SUM-G2995. Lots of options with it - data logging, Etc,
Fastest 300
#1867962
07/10/15 10:48 PM
07/10/15 10:48 PM
MR_P_BODY
I have my O2 meter loaned out right now or I could tell you what I have for a replacement... its been doing good for 6-8 months so for
[Re: Challenger 1]
#1868486
07/11/15 11:05 PM
07/11/15 11:05 PM
Thumperdart
State of confusion
Now I`m really confused. You say we don`t want ethanol in or "race gas" but doesn`t the E in E-85 stand for ethanol? The biggest plus I hear about from people on E-85 is how "cheap" it is and that it runs a bit cooler but I have zero desire to change over at this point and will figure something out............. I called the airport to see about some 100ll but they don`t sell to the public............bummer as I`ve heard good things about it from MOST people..............
[Re: Thumperdart]
#1868584
07/12/15 01:44 AM
07/12/15 01:44 AM
Posts: 7,506 Az
Crizila
Az
Now I`m really confused. You say we don`t want ethanol in or "race gas" but doesn`t the E in E-85 stand for ethanol? The biggest plus I hear about from people on E-85 is how "cheap" it is and that it runs a bit cooler but I have zero desire to change over at this point and will figure something out............. I called the airport to see about some 100ll but they don`t sell to the public............bummer as I`ve heard good things about it from MOST people.............. Think his main concerns were blending ( non ethanol with ethanol - could run in to compatible issues ), Longivity / storage, and a fuel system that may not be "totally" compatible. Not to mention adding another variable ( blending ) to the mix - so to speak. Since the $ is the same for the 2 fuels I mentioned ( Sunoco 100 With E and Sunoco 110 leaded ), no brainer choice for me. Running av gas opens up a whole nuther can of worms, starting with reeds vapor pressure issues, etc. I wouldn't run it and I wouldn't blend with it. BTW, think most AF meters are calibrated using gas with 0 ethanol in it, so when you blend, exactly what are you using for a conversion chart???
Fastest 300
