Re: 4 Core Champion Aluminum Radiator
[Re: markshemiworld]
#1867290
07/09/15 05:21 PM
07/09/15 05:21 PM
Posts: 1,809 North Dakota
Azzkikrcuda
North Dakota
My dad has one of the 4 core radiators on his 70 challenger and it works with stock fan and shroud.
The only Carbs I care about are under the hood!
#1867309
07/09/15 05:56 PM
07/09/15 05:56 PM
Posts: 1,491 Lethbridge, AB, Canada
dangina
I have a champion 4 core in my 71 runner, just fired today, the first rad was warped, sent it back, second one was manageable, but thats what u get for a $200 aluminum rad
#1867326
07/09/15 06:30 PM
07/09/15 06:30 PM
Posts: 1,513 AZ
Mike P
AZ
Just my . A few years back I was looking at the Champion 4 rows right after they came out. I did a little bit of quick math and figured out that their 4 row radiators actually had less tube surface area than their 2 row with 1" tubes. The key is to get one that actually has 1" tubes. I went with the 2 row for my daily driver which is a 507CI Cadillac powered El Camino. It gets driven virtually every day with a mix of highway and around town stop and go driving. I've never had a heating problem with it, even on long trips on 105 degree days with the AC on.
1957 Plymouth (Hemi, Dual Quads, A833 4 Speed 9 1/4 w 4.10) Sold 1937 Dodge Pickup (Hemi, 6X2 intake, 46RH, Dana 60 w 4.56) Sold 1968 Plymouth Valiant 2dr sedan (354 HEMI, 46RH w/4.30 gears) under construction
[Re: Mike P]
#1867439
07/09/15 10:53 PM
07/09/15 10:53 PM
Posts: 2,869 Pattison Texas
CSK
Pattison Texas
i just pulled my 4 row champion out & replace with a 2 row with 1in tubes, it now runs cool, 512 cid with a/c in south texas link to radiator
#1867527
07/10/15 12:51 AM
07/10/15 12:51 AM
Posts: 7,664 IN
ahy
IN
My car currently has a cheap 2 row aluminum radiator that I got off eBay years ago, but I don't think it was ever quite adequate enough for my motor. Around town and idling in traffic it never goes over 190, but in the summer time the highway driving causes it to get hot and I can't run my A/C without it overheating or drive over 70 for any extended period of time. Any suggestions? Hot at speed usually means not enough radiator or radiator plugged. Cool in town (190F) usually means fan/shroud is OK. I think you need a better radiator. Take your pick of the above (4 core Champion or 2 big core Mancini) or something else but get something better to fix it.
#1867530
07/10/15 12:55 AM
07/10/15 12:55 AM
RapidRobert
but in the summer time the highway driving causes it to get hot and I can't run my A/C without it overheating or drive over 70 for any extended period of time. Any suggestions? over 70 it sure wouldn't be an airflow prob. I'm thinking water flow not fast enough for some reason. But then again maybe the rad ain't big enough but I'm skeptical. How killer (heat pump) of an eng do you have there?
#1867595
07/10/15 08:18 AM
07/10/15 08:18 AM
Posts: 1,513 AZ
Mike P
AZ
Again for what it's worth.......I normally run the thick HD Hayden fan clutches with a 7 Blade fan (they lock up at 210 degrees by the way). A few years ago I built another (off brand) vehicle. Fresh engine, new aluminum radiator,water pump etc. I had a new standard duty fan clutch on the shelf so I used that. Around town, short highway trips no problems, but when I made a trip to Tucson (about 75 miles away) on a 100 degree day it ran pretty warm at highway speed with the AC on. When I got home I changed out the fan clutch to the thicker HD clutch. About a week later I made the same trip, and if anything the outside temperature was even warmer. The truck never ran above 210 degrees. The thicker clutch locks up tighter than the standard duty ones and causes the fan to pull more air. You can actually hear the fan "roar" just a bit when it locks up which some people find objectionable but to me it's a lot less objectionable than a pegged temp gauge.
#1867602
07/10/15 09:09 AM
07/10/15 09:09 AM
Posts: 3,426 weymouth,mass.
meepmeep70
weymouth,mass.
I have a champion 3 core 22", from my 70 RR, worked fine in my 440 6pak, stroked motor to 544 needed bigger radiator, if this 3 core will work for you $100 plus the ride has maybe 300 miles on itand I ran without shroud (I didn't have correct one), it took the 4th radiator to be shipped to me, all the ones before where so beat up and first leaked, if you go champion new ask for extra packing and ask them to check it before they ship,
#1867624
07/10/15 10:28 AM
07/10/15 10:28 AM
Posts: 1,513 AZ
Mike P
AZ
"....The fan that's on it now pulls very good. Enough to blow your hair back if your leaning on the fender with the hood open....."
I've run into that before too, and frankly those were my thoughts when I put the standard duty clutch on the the truck when I built it, but like I said the HD unit actually pulls more air at highway speed than the standard duty one does which in my case was all that was needed.
"..... I was told by several people that overheating on the highway most likely means not enough radiator? ......"
And it very well could be. There is also a possibility that as your radiator is several years old there could be internal corrosion that has caused it to lose efficiency.
Unfortunately trouble shooting cooling problems can often turn into trial and error after the obvious (plugged radiator, timing, collapsed lower hose etc) have been checked and eliminated. When I moved to AZ many years ago I had a steep learning curve to go thru especially when I started adding AC to my hot rods. I tend now to possibly overbuild the cooling system from the start......biggest radiator, 7 Blade fan, HD Fan clutch, shroud, high flow WP, and even play with pulley size from time to time to change fan and WP speed.
I fought a cooling system problem like yours many years ago, cooled great except on the highway. I changed everything to include radiators at least twice. After all the changes and expense I finally found the problem.....turns out it was just air backing up in the engine compartment at speed. I pulled the upper control arm dust shields off (the rubber flaps the cover the control arms) and never had another problem with it.
Anyway good luck and hopefully the radiator will cure it.
#1867733
07/10/15 02:27 PM
07/10/15 02:27 PM
Posts: 1,513 AZ
Mike P
AZ
The 4 row Champion radiators I have seen advertised (and one I purchased) only had 3/8" tubes...effectively 1 1/2" surface area vice 2".
#1867738
07/10/15 02:32 PM
07/10/15 02:32 PM
RapidRobert
that the coolant will be staying in the radiator longer and therefore cool better? no help on the rows issue (& that sounds critical) but on the speed but you want to coolant to flow as fast as possible but not get into pump cavitation. Consider this, if one block of water exits the rad faster (cooled less) that means the next block of water enters quicker & gets cooled faster so it all reaches an equilibrium.
[Re: RapidRobert]
#1868254
07/11/15 03:08 PM
07/11/15 03:08 PM
CSK
Pattison Texas
A slipping water pump,fan belt will make it run hot at highway speed.
#1868517
07/11/15 11:45 PM
07/11/15 11:45 PM
Posts: 10,938 Spokane Valley, WA
Big Bad Bee
Spokane Valley, WA
I bought a Champion 26" 3 core for my super bee. No water in it yet. It wasn't warped but I had to massage the bolt locations to get it to fit. Don't expect a pretty piece. Their welds are good but production methods are worse than a butcher shop. Scratches, burn marks, slag and mashed fins galore.
I’m listening.
[Re: Big Bad Bee]
#1868536
07/12/15 12:13 AM
07/12/15 12:13 AM
RapidRobert
It wasn't warped but I had to massage the bolt locations to get it to fit. Don't expect a pretty piece. Their welds are good but production methods are worse than a butcher shop. Scratches, burn marks, slag and mashed fins galore. Same here, I bought a 2 core direct fit for my DD 318 65 dart from Evilbay & not warped but I had to redrill (1) side flange hole (no big deal). $189 to my door which is decent. cooled fine but a DD 318 ain't really going to test anything. Welds appeared OK as far as I a non welder could tell, didn't remember any slag/burn marks/scratches
[Re: Mike P]
#1869528
07/13/15 05:33 PM
07/13/15 05:33 PM
Posts: 3,011 Covington Georgia
RV2
Covington Georgia
Again for what it's worth.......I normally run the thick HD Hayden fan clutches with a 7 Blade fan Hey Mike P do you have any parts numbers/ sources or pics of this fan clutch? Thanks
