67 broadcast sheet info #186642
01/07/09 12:02 PM
01/07/09 12:02 PM
Ball Ground GA
TrueTripleX Offline OP
Ball Ground GA
Can someone post a copy of a broadcast sheet. I have one for my car but certain areas (because of the springs) are missing and I am trying to guess what would have been in these areas and with the fender tag and knowledge of the car, try to determine what should/could be there. I only need the "header" information and not what is in the box below. Is there a link out there that shows a "raw" 67 build sheet?
Re: 67 broadcast sheet info [Re: TrueTripleX] #186643
01/07/09 06:33 PM
01/07/09 06:33 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
I may have a 67 scanned in at home. I found the wrong one in my 67 Barracuda convertible.
Re: 67 broadcast sheet info [Re: TrueTripleX] #186644
01/07/09 07:39 PM
01/07/09 07:39 PM
BFE
blue67440's Offline
blue67440's  Offline
BFE
I sent one to your email listed in your profile. It's not a blank but you hopefully can read the spaces.
XP29L72 A833 in 881 XP29L72 A727 in 881
Re: 67 broadcast sheet info [Re: blue67440's] #186645
01/07/09 07:45 PM
01/07/09 07:45 PM
Ball Ground GA
Ball Ground GA
Thanks blue667440's, I will watch for it (it is not here yet). I do appreaciate the help
