Re: Dyno Headers: Adjustable Primary Length Range?
[Re: gregsdart]
#1865868
07/07/15 02:16 PM
07/07/15 02:16 PM
Posts: 9,100 Rogue River, OR
Jeremiah
Rogue River, OR
Thanks Greg. The wallace site was about 31" for my 511 so I figured I'd start with that.
[Re: Jeremiah]
#1866413
07/08/15 09:18 AM
07/08/15 09:18 AM
Posts: 10,013 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Another option is to buy a small block chevy weld it yourself header kit and use the Mopar BB head flange. Cheaper, and you can get smaller sizes of tube.
[Re: Jeremiah]
#1866442
07/08/15 10:29 AM
07/08/15 10:29 AM
Posts: 16,929 NC
440Jim
NC
I was planning on running 2-2.125"x4" TTI's. What length (avg) are the TTIs for comparison? It would be interesting to test the TTI length with your new dyno headers (2.25) for comparison.
[Re: 440Jim]
#1866524
07/08/15 01:05 PM
07/08/15 01:05 PM
BradH
I was planning on running 2-2.125"x4" TTI's. What length (avg) are the TTIs for comparison? It would be interesting to test the TTI length with your new dyno headers (2.25) for comparison. IIRC, the TTI 2" to 2-1/8" step headers have a 3.5" collector, same as their standard 2" like I run. IMO, a 4" collector is way too big for a 2" tube, and maybe even borderline for a 2-1/8". I had some Headers by Ed documentation years ago that was really "picky" on how it sized collectors based on tube diameters and applications. Ol' Ed was into sizing collectors in 1/4" increments, rather than the common 1/2" size changes. Although the TTI 2" to 2-1/8" step headers do not have the identical tube lengths as mine, I can tell you the 2" TTI B/E-body header have a really wide range in tube lengths (from about 25" to 41") that AVERAGE to approx. 32". They're the epitome of UNequal length as a result of being "designed to fit", rather than "designed to peform". Still, they still seem to work OK. I wish TTI made a 1-7/8" to 2" step for B/E-body, but will stick w/ my standard 2" since I don't see my combination needing anythying bigger. FWIW, Steve Dulcich did a header comparison article some years ago where two of the headers tested on his old EMC Chapman-headed 470 B engine (700+ HP) were the Hooker 2" Super Comps (very close to equal-length primaries) and the TTI 2" to 2-1/8" step headers. There were REALLY close across the entire power curve, with the TTI averaging something like only 1/2 or maybe 1 HP more.
[Re: Jeremiah]
#1866539
07/08/15 01:15 PM
07/08/15 01:15 PM
Posts: 2,673 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
I never have understood people using dyno headers. If you want an idea of what your engine really makes when you use it, instead of on a dyno, I don't think you want dyno headers or a deep dyno pan.
2011 Drag Pak Challenger
[Re: rickseeman]
#1866542
07/08/15 01:23 PM
07/08/15 01:23 PM
BradH
I never have understood people using dyno headers. If you want an idea of what your engine really makes when you use it, instead of on a dyno, I don't think you want dyno headers or a deep dyno pan. I agree that you should test w/ what you'll actually run as closely as possible. In my case, I had to bring along a set of Hooker 2" Super Comps because they fit the dyno cart, but my more "chassis-fit friendly" TTI 2" headers wouldn't.
[Re: BradH]
#1867100
07/09/15 08:45 AM
07/09/15 08:45 AM
gregsdart
I never have understood people using dyno headers. If you want an idea of what your engine really makes when you use it, instead of on a dyno, I don't think you want dyno headers or a deep dyno pan. I agree that you should test w/ what you'll actually run as closely as possible. In my case, I had to bring along a set of Hooker 2" Super Comps because they fit the dyno cart, but my more "chassis-fit friendly" TTI 2" headers wouldn't. Start with the dyno stuff, tune and get the fuel/air data, switch to what you are going to run and retest. That is what I would do, but they said they couldn't hook up to my headers due to the curved collector exit.
[Re: Jeremiah]
#1868333
07/11/15 05:45 PM
07/11/15 05:45 PM
Posts: 31,060 Oregon
AndyF
You guys are right on target as to why I can't use the headers that will be in the car. I seriously doubt the TTI's will fit on the dyno. I ordered up the Shcoenfeld set so we shall see. Which headers did you order from Schoenfeld? If you buy them from Summit the shipping is free. Price is the same as direct from Schoenfeld. If you got the 1 7/8 - 2 inch headers I might want to try them out some time. Or buy them from you after you use them on the dyno if you don't plan to keep them.
[Re: Jeremiah]
#1868415
07/11/15 08:34 PM
07/11/15 08:34 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I used my complete engine on my last dyno session.. my headers that I built for the car, my fuel... worked out great Get the Pipe Max program.. you cant go wrong... been using that program for 20+ years and even tried to mess it up to see how much power was lost
[Re: Jeremiah]
#1872849
07/18/15 01:19 PM
07/18/15 01:19 PM
AndyF
Benefits of mass production. A person would spend a lot of time trying to build those and they wouldn't come out as nice.
The collector does need to be a bit longer to work right. I think PipeMax will tell you to put a 15 inch collector on it or something like that.
One nice thing about the Schoenfeld headers is that they have the long straight section before the collector so you can cut the primary tube length down if you want to. If you want to run a merge collector then you have the room to cut 10 inches or so off the primaries and weld in a merge setup.
[Re: AndyF]
#1872909
07/18/15 02:55 PM
07/18/15 02:55 PM
BradH
One nice thing about the Schoenfeld headers is that they have the long straight section before the collector so you can cut the primary tube length down if you want to. If you want to run a merge collector then you have the room to cut 10 inches or so off the primaries and weld in a merge setup. +1 on the collector length; I was going to suggest 18" as a baseline. The collector design used looks low tech, IMO. Merge or not, you might want to see what options you have to cut those off and replace them with a more efficient design (unless there's more hiding inside than the outside leads me to believe).
[Re: Jeremiah]
#1873112
07/18/15 07:32 PM
07/18/15 07:32 PM
MR_P_BODY
I have said for the longest time that the collector length need to be added on.. in MOST cases it should end up in the 16" to 18" range but other factors come into play... and a big one is RPM.... I use to love building headers.. I think I am just over a 100+ sets.. about 14 sets for my own junk... plus doing a lot of 2 cycle chambers.. I learned a lot of merge stuff working on chambers
[Re: MR_P_BODY]
#1873311
07/19/15 02:17 AM
07/19/15 02:17 AM
Jeremiah
Rogue River, OR
Interesting notes Mr. P!
For conversation let's say I am going to run a full 3" TTI exhaust system. Would I want to cut back the 3" pipe on the head pipes and add in, for example, an 18" length of 3.5" to the collector? Is this an open header only thing?
For instance the dyno has 4" flexible exhaust tubing that goes to giant roof mounted mufflers.
Would the results improve if the exhaust was unhooked from the dyno room exhaust system? Obviously this is impractical - anybody want to weigh in on the theory aspect of it?
Also of note: I mocked up a standard Mr. Gasket header gasket to the Schoenfeld headers and the ports will need some clean up to match the gasket. Not a big deal because the surfaced them and then ground away the weld bead therefore some clean up with a carbide burr will be necessary.
