Question about pulling the front end on take off.. why?
#186497
01/07/09 09:13 AM
01/07/09 09:13 AM
Posts: 4,283 Danville, NH
Mopar_Mike
Danville, NH
Ok, just asking if there is any real advantage to pulling the front end up in the air 5+ feet when you launch at the lights. There is no doubt it looks cool, but what about landing, won't you smash something? not too cool then.. plus aren't you loosing time by going up instead of going out? Just looking for opinions for a real race application. Thanks.
RS23L7 4-Speed
Re: Question about pulling the front end on take off.. why?
[Re: Mopar_Mike]
#186498
01/07/09 10:28 AM
01/07/09 10:28 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Some cars 60' better when doing a wheelie(dont know about 5'). Most of the time the front end sets down nice and smooth so normally nothing gets smashed but yes they look cool also
[Re: Mopar_Mike]
#186499
01/07/09 10:49 AM
01/07/09 10:49 AM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
IMO it takes power to pull the front end up, that power could better be utilized put into forward motion. Wheelie bars are for a purpose of not only to limit upward motion but to help promote the forward motion. Yes high fronts can/do cause breakage.
Clean it, if it's Dirty. Oil it, if it Squeaks.
But: Don't fix it, if it Works!
[Re: Mopar_Mike]
#186500
01/07/09 10:59 AM
01/07/09 10:59 AM
MR_P_BODY
Also there is more than 1 kind of wheelie. You have a car that just yanks the front end straight up out of the lights, usually they fall back down fairly quick, then you have the car that slowly brings them up while traveling forward, these cars usually set them down nice and easy
[Re: Mopar_Mike]
#186501
01/07/09 11:06 AM
01/07/09 11:06 AM
Posts: 3,060 Western New York
sixpackbee
Western New York
Cars that are limited to a stock type suspension usually benfit from that kind of weight transfer. My car wont 60 unless it does stand up. With a limited tire it sometimes has to be that way. As far as smashing something a car that is designed to wheelstand will usually power right through to a smooth touchdown as stated above. If the car looses bite or some other thing happens when the front end is up then we are at the mercy of Sir Isaac Newton and his laws.
1959 Bugeye Sprite 1967 Charger Black L code 1967 Coronet R/T Convert Green 440 auto bought from original owner 1968 Charger R/T Bronze 440 4 spd console AM/FM 1969 Super Bee WM21H B5 A40 D21 N96 1969 Barracuda Formula S 340 Convert pilot car 1969 Hemi Road Runner RM23J D32 Omaha orange 4.10 Dana N96 N85 1970 Super Bee WM23N FE5 V1X 3.91 axle package, N96 1970 Road Runner RM21N B3 V1X D13 1971 MG Midget 1971 Road Runner RM23H GW3, A57 1972 Road Runner RM23P FY1, D21
[Re: sixpackbee]
#186502
01/07/09 03:04 PM
01/07/09 03:04 PM
Posts: 9,910 Eighty Four, PA
B G Racing
Eighty Four, PA
I do it cause it looks cool.We can carry them a long ways as long as nothing breaks or someone gets off the pedal.
[Re: B G Racing]
#186503
01/07/09 03:11 PM
01/07/09 03:11 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
[Re: Florida_70Bee]
#186505
01/07/09 03:29 PM
01/07/09 03:29 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
Usually depends on the power level. If the car has enough power to work the tire and the chassis, all that weight transfer is not needed and is just wasted motion. Lower powered cars need the weight transfer to plant the tire and work the suspension. I will catch flack for this next comment, but don't care. IMO, if your car runs 9s and it has to carry the frontend fairly high to 60ft good, it is setup wrong. Gear, converter, suspension, something is wrong. SS/AH cars always get mentioned in this debate. Some carry the front, some don't, so they can work either way, but in my own experience, the closer you keep the tires to the ground, the quicker you go. Tack a sail on the front of your car for 80 feet and see if it slows it down. I'm betting yes.
Monte
[Re: Monte_Smith]
#186506
01/07/09 03:36 PM
01/07/09 03:36 PM
B G Racing
Eighty Four, PA
Monte
Our best ETs are when we footbrake and keep the front low,anything over 2' or 3' the ET drops.Dragging the back bumper can cost us 2 to 3 tenths if not more. We do it for the show
[Re: B G Racing]
#186507
01/07/09 03:47 PM
01/07/09 03:47 PM
MoparforLife
Upper Midwest
I still contend that a nice floating type lift is the best for ET. Anything more is show. Like BG said.
[Re: sixpackbee]
#186511
01/07/09 04:13 PM
01/07/09 04:13 PM
B G Racing
Eighty Four, PA
And if you watch further Stock and S/S racing you will notice that when automatic car launches the front wheels will hang much further down from the body on a wheelstand than a wheelstand from a Manual transmission car. (I'm not sure for the reason for this though but assume
There should be no difference. If you watch like body styles you should see this. We are not allowed any type of limiter and the suspensions in Stock have to be stock. SS cars are allowed a few more things which can limit the wheel travel.
We tighten up the shocks and torsion bars to control the wheelstand.A lot of SS cars have a screw type of adjuster and a adjustable rebound to limit seperation collaspe(referring to mopar)
[Re: B G Racing]
#186512
01/07/09 04:24 PM
01/07/09 04:24 PM
sixpackbee
Western New York
Bob looking at your picture it looks like my harmless low compression 340 can hang the hoops as high as your car with that funny looking big engine in there.
[Re: John_Kunkel]
#186513
01/07/09 04:32 PM
01/07/09 04:32 PM
Monte_Smith
North Alabama
I love to quote the late Gary Ormsby...."Wheel stands are caused by lack of power".
John, you have no idea how hard it is to convince most people of that very fact.
Monte
[Re: sixpackbee]
#186516
01/07/09 06:26 PM
01/07/09 06:26 PM
Posts: 75,005 U.S.S.A.
JohnRR
U.S.S.A.
