Re: sb indy intake milling plenum
[Re: 71Pan]
#1864703
07/05/15 11:07 PM
07/05/15 11:07 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
Is the carb against the hood or the air cleaner. If the air cleaner hits, you can try a dropped base to lower the air cleaner height.
[image][/image]
[Re: sgcuda]
#1864761
07/05/15 11:51 PM
07/05/15 11:51 PM
Posts: 1,272 Northern Calyfornua
Sxrxrnr
Northern Calyfornua
Is the carb against the hood or the air cleaner. If the air cleaner hits, you can try a dropped base to lower the air cleaner height. Agree! My 71 LT 1 equipped Corvette with 780 Holley comes factory stock with such an air cleaner base. After market type air cleaners will not clear the hood.
[Re: 71Pan]
#1864782
07/06/15 12:12 AM
07/06/15 12:12 AM
Posts: 11,725 Portage,michigan
B3422W5
Portage,michigan
Inch off is fine. Indy even notes that on its site.
