In-line Hemi Carbs & Linkages
#18636
11/13/05 08:58 PM
11/13/05 08:58 PM
Posts: 36 Northern NY, Clinton County
rrrttt
I recently purchased a crate 426 HEMI to drop in my 69 RR 4 sp. I want to install dual quad inline 4bbl carbs. Car has hood air grabber so height is important for the air grabber breather baseplate to make a seal.
I'm going to purchase a dual quad inline intake from Mopar Performance which they say is the correct factory height when installed on a Hemi.
I need advice as to what front & rear carbs (brand & #'s) to run with this set-up so I will maintain correct height and also the airgrabber breather baseplate openings will fit on top of carbs.
Would also appreciate inline linkage & fuel hookup make & model #.
Re: In-line Hemi Carbs & Linkages
[Re: rrrttt]
#18637
11/13/05 09:17 PM
11/13/05 09:17 PM
Posts: 5,118 Alone in the darkness
gamagoat6x6
super street
super street
That`s going to be a little tricky because the original hemi carbs had a 4-7/8" air horn and all the aftermarket stuff has the holley size 5-1/8" but the originals were a little taller so you could get someone to machine some cone shaped adapters. I think I heard somewhere that someone was making baseplates to match the later "eddy" style carbs.
`02 RAM2500 SPORT V10 4x4
`06 GMC sierra
NO cars
[Re: AndyF]
#18643
11/18/05 01:05 AM
11/18/05 01:05 AM
Posts: 5,122 Chicago Blackhawks
hemicar1971
Chicago Blackhawks
JohnRR those intakes are night and day.The Stage V is a performance intake and will out horse power the MP intake by a quite a bit.For Hemis Only use to have some figures on their web site to compare most intakes and carbs but I am not sure what is on their Web site right at the present time. If you plan on running a stock motor compare a factory intake and a MP intake for price,if your running some cam and headers go with the Stage V stuff and use the Carters or Hol. but with the Stage V intake your carbs are spaced farther apart than stock.Now the single four intake you get with a crate motor Hemi is just there on top of the motor so nothing can get into the motor.I have run this intake and its not a very good performance intake,could be ok on a stock motor. I have also got a Vanke intake and the Stage V intake out performs it also by a lot. www.forhemisonly.com
[Re: VanishPt]
#18646
11/18/05 08:08 AM
11/18/05 08:08 AM
Posts: 75,088 A Banana Republic near you.
JohnRR
thanks guys , sorry for the confusion on the intakes , from the outside they look pretty similar , but yes from the pictures i have seen the MP manifold is a dual plane , looks like a modified , streched verison of the stock with the Vanke mods done to it ?????
[Re: JohnRR]
#18649
11/18/05 07:11 PM
11/18/05 07:11 PM
Posts: 306 Texas
bogusracer
Texas
John,
The new Mopar 2x4 intake for Holleys is the same as the old "Marine Intake" that Mopar made for drag boats in the late 60's early 70's. It is an inline 2x4 setup and you are correct, the carb spacing is different than the OEM 2x4 Street Hemi intakes that run the Carter AFB's.
In addition as previously mentioned the OEM Base plates will need to be modified to work with the new Mopar Intake & Holley Carbs.
Last, the OEM street hemi's did have a progressive linkage for the carbs as you stated in a later post.
Bogusracer
[Re: bogusracer]
#18650
11/18/05 07:21 PM
11/18/05 07:21 PM
Posts: 12,494 Western Colorado High Desert
moparmarks
I used this Edelbrock linkage on this car. Edelbrock carbs on a stock 66 manifold. This linkage can be set up for progressive or non-progressive. Sorry, don't have a closer pic. Worked really well. I set it as progressive.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
[Re: moparmarks]
#18653
11/20/05 12:44 PM
11/20/05 12:44 PM
Posts: 131 British Columbia
yellowgtx
British Columbia
I used the same set up as Moparmikes picture.. It is a stock 66 manifold and 750 eddy carbs. --75's butterflies are a bit close to manifold bores.. I double gasketed to clear. The linkage can be set iether way.
After almost 71 years I am on my last car. A 65 Plymouth Satellite straight axle altered wheel base car.
[Re: yellowgtx]
#18655
11/20/05 12:53 PM
11/20/05 12:53 PM
moparmarks
Hey it's Mark not Mike. My x-mother in law called me Mike for 3 years. LOL.
