Re: New Passon Performance 5 Speed update
[Re: relax383]
#1885396
08/05/15 02:39 AM
08/05/15 02:39 AM
Posts: 4,796 Star Idaho
67vertman
Star Idaho
Shhhs....we are all sworn to secrecy! Read back through the thread....Jamie is collecting the parts and pieces to build them by the lot. Three months or so ago he said he would get the lot out in six months.
My Monster are real!
Living within your means makes life pretty easy.
[Re: 64Barracuda]
#1888123
08/09/15 04:41 PM
08/09/15 04:41 PM
Posts: 1,132 Home of the Bluegrass
MoparJunkie
According to the info given at the booth by his guys... They are having a mainshaft supplier issue. There weren't alot of specifics given out other than that. So, maybe a small bump in the road halting assembly???? Maybe Jamie will chime in? However, he is a very busy guy, and I don't expect an update with every issue he encounters... They just wind up causing more questions! Lol
"It takes a Mopar to catch a Mopar” 1971 Roadrunner FJ6 Sassy Grass 505"RB, 18 spline 4 speed, and Dana 60 with 3.54 2022 Hellcat Charger Widebody Redeye Jailbreak: Hellraisin with 8 speed auto
[Re: JamiePasson]
#1889682
08/11/15 07:28 PM
08/11/15 07:28 PM
Posts: 68 USA MO
cdoublejj
USA MO
whats the word? how are people liking them so far!?
[Re: thehemikid]
#1916395
09/20/15 11:06 PM
09/20/15 11:06 PM
67vertman
Star Idaho
Hey 67vertman, how do you like the 4spd OD so far?
I see the 4 is 20%, where the 5 is 30%.
What rear gear are you running?
Hi H-Kid, I really like the OD, with 4:10 gears, it cruises very nicely down the freeway. Even transition from each gear, with no lag or major drop in RPM. Mostly around town, you don't even use 4th gear. One thing I miss from the original geared trans is the lower 1 and 2 pull you get. But once the 5sp comes in I will have the best of both worlds.
[Re: 67vertman]
#1918321
09/23/15 08:20 PM
09/23/15 08:20 PM
Posts: 1,805 ky hills
thehemikid
ky hills
Hi H-Kid, I really like the OD, with 4:10 gears, it cruises very nicely down the freeway. Even transition from each gear, with no lag or major drop in RPM. Mostly around town, you don't even use 4th gear. One thing I miss from the original geared trans is the lower 1 and 2 pull you get. But once the 5sp comes in I will have the best of both worlds. I asked because I ordered the hemi 4spd OD on 9/11 of all dates to order something Anyway I looked at the ratio's and 2nd (in the OD) is right in the middle between 2nd and 3rd in the factory stock 4spd. So another way of looking at it, it shifts 1st-2&1/2-4th-.80. I'm running 3.54, so to me if the cars doing 70 the motors doing a little less than 55. Asked about the trade-in on the 855 when the time comes and Jammie said (iirc but terribly paraphrased) we want beat you up on it, as long as you don't beat the crap out of it. If it was 2 wks for you, then maybe this Friday. But I know he's a busy shop, & 1st come 1st serve.
[Re: thehemikid]
#1918546
09/24/15 01:20 AM
09/24/15 01:20 AM
67vertman
Star Idaho
Hi H-Kid, I really like the OD, with 4:10 gears, it cruises very nicely down the freeway. Even transition from each gear, with no lag or major drop in RPM. Mostly around town, you don't even use 4th gear. One thing I miss from the original geared trans is the lower 1 and 2 pull you get. But once the 5sp comes in I will have the best of both worlds. I asked because I ordered the hemi 4spd OD on 9/11 of all dates to order something Anyway I looked at the ratio's and 2nd (in the OD) is right in the middle between 2nd and 3rd in the factory stock 4spd. So another way of looking at it, it shifts 1st-2&1/2-4th-.80. I'm running 3.54, so to me if the cars doing 70 the motors doing a little less than 55. Asked about the trade-in on the 855 when the time comes and Jammie said (iirc but terribly paraphrased) we want beat you up on it, as long as you don't beat the crap out of it. If it was 2 wks for you, then maybe this Friday. But I know he's a busy shop, & 1st come 1st serve. I am glad to hear that you ordered it. You will like it. I think you will be fine with the 3:54 as they are pretty stout on the street to. I like the drive ability of the gear spacing, it does take some getting used to as you are able to run longer in 2nd and 3rd then before. I think I am going to sell mine on the open market rather than trading it back in. Yes Jamie said that I could recoup most of the price on a trade-in, but I think I can do the same or better selling it myself.
[Re: 67vertman]
#1920472
09/27/15 10:14 AM
09/27/15 10:14 AM
Posts: 732 eastern,Ky
70RT Charger
eastern,Ky
Hi H-Kid, I really like the OD, with 4:10 gears, it cruises very nicely down the freeway. Even transition from each gear, with no lag or major drop in RPM. Mostly around town, you don't even use 4th gear. One thing I miss from the original geared trans is the lower 1 and 2 pull you get. But once the 5sp comes in I will have the best of both worlds. I asked because I ordered the hemi 4spd OD on 9/11 of all dates to order something Anyway I looked at the ratio's and 2nd (in the OD) is right in the middle between 2nd and 3rd in the factory stock 4spd. So another way of looking at it, it shifts 1st-2&1/2-4th-.80. I'm running 3.54, so to me if the cars doing 70 the motors doing a little less than 55. Asked about the trade-in on the 855 when the time comes and Jammie said (iirc but terribly paraphrased) we want beat you up on it, as long as you don't beat the crap out of it. If it was 2 wks for you, then maybe this Friday. But I know he's a busy shop, & 1st come 1st serve. I am glad to hear that you ordered it. You will like it. I think you will be fine with the 3:54 as they are pretty stout on the street to. I like the drive ability of the gear spacing, it does take some getting used to as you are able to run longer in 2nd and 3rd then before. I think I am going to sell mine on the open market rather than trading it back in. Yes Jamie said that I could recoup most of the price on a trade-in, but I think I can do the same or better selling it myself. What are you going to ask for it?
[Re: 70RT Charger]
#1921172
09/28/15 01:38 PM
09/28/15 01:38 PM
67vertman
Star Idaho
I am thinking I can get $600 to $700 for it. It will only have about 1000 miles on it....maybe 2000 if the 5sp doesn't come in until late 2016.
[Re: JamiePasson]
#1929318
10/09/15 10:45 PM
10/09/15 10:45 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
I would love to get a Passon OD 4 speed for $700....
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
