Page 3 of 11 1 2 3 4 5 10 11
Re: test pic 68 turbo dart project [Re: sgcuda] #1859092
06/28/15 08:01 PM
06/28/15 08:01 PM
davenport iowa
P
paul69cuda Offline OP
P
davenport iowa
more
Re: test pic 68 turbo dart project [Re: paul69cuda] #1859093
06/28/15 08:03 PM
06/28/15 08:03 PM
davenport iowa
P
P
davenport iowa
more
Re: test pic 68 turbo dart project [Re: paul69cuda] #1859097
06/28/15 08:07 PM
06/28/15 08:07 PM
davenport iowa
P
P
davenport iowa
valley plate mod i thought was cool
Re: test pic 68 turbo dart project [Re: paul69cuda] #1859098
06/28/15 08:09 PM
06/28/15 08:09 PM
davenport iowa
P
P
davenport iowa
more
Re: test pic 68 turbo dart project [Re: paul69cuda] #1864629
07/05/15 10:30 PM
07/05/15 10:30 PM
davenport iowa
P
P
davenport iowa
motor
Re: test pic 68 turbo dart project [Re: paul69cuda] #1876795
07/23/15 08:40 PM
07/23/15 08:40 PM
davenport iowa
P
P
davenport iowa
oh ya my first turbo pt94 CEA
Re: test pic 68 turbo dart project [Re: paul69cuda] #1876803
07/23/15 08:45 PM
07/23/15 08:45 PM
davenport iowa
P
P
davenport iowa
more
Re: test pic 68 turbo dart project [Re: paul69cuda] #1876853
07/23/15 09:26 PM
07/23/15 09:26 PM
Aurora, CO
jbeintherockies Offline
Aurora, CO
Originally Posted By paul69cuda
finally i have figured out how to post pics here!!!!!!! <img src="/ubbthreads/images/graemlins/punkrocka.gif" alt="" /> <img src="/ubbthreads/images/graemlins/beer.gif" alt="" />
68 dart turbo 440/ world iron block 4.25 bore /3.75 stroke hemi 8 boly crank 4340 mp performance / manley pro I beam rods / Icon pistons 8.3 comp / EDDY performer heads mild work done / scott brown hyd roller cam custom grind for turbo / F.A.S.T EFI 97 lbs injectors EDDY efi manifold pro flo modified for bigger injectors / D-60 3.73 spool /325 drag radials on rear. all work done by me so far accept the cage and dash. more pics!!!!
I have never built a turbo car, but I really want to. Having said that, how will the engine be mounted? I would think mounting the turbo to the frame rail could cause problems if the engine moves at all (ie torquing out). I'm sure you have already thought that through; just wondering. Looks like a clean implementation so far. Will you be using an intercooler?
Re: test pic 68 turbo dart project [Re: paul69cuda] #1876883
07/23/15 10:02 PM
07/23/15 10:02 PM
La Porte,Tx
mopwr2004a Offline
mopwr2004a  Offline
La Porte,Tx
what brand of rocker arms are you using
Re: test pic 68 turbo dart project [Re: mopwr2004a] #1876925
07/23/15 10:50 PM
07/23/15 10:50 PM
davenport iowa
P
P
davenport iowa
well this new turbo is way bigger than the borge warner so we will test fit motor and trans next week and test fit turbo and look into how best to mount it. for motor mounts i have solid mounts but now i am going to plate the motor but test fitting with t400 trans i bet i will have to modify trans tunnel. the rockers are T&D 1.6 with smith brothers push rods
Re: test pic 68 turbo dart project [Re: paul69cuda] #1876927
07/23/15 10:54 PM
07/23/15 10:54 PM
davenport iowa
P
P
davenport iowa
it will be an air to water inter cooler
Re: test pic 68 turbo dart project [Re: paul69cuda] #1877387
07/24/15 05:28 PM
07/24/15 05:28 PM
Aurora, CO
Aurora, CO
How do you determine what size turbo to use? I assume you have a power level in mind. Is there a cross reference of some sort between size of turbo and power level?
Re: test pic 68 turbo dart project [Re: jbeintherockies] #1877878
07/25/15 02:58 PM
07/25/15 02:58 PM
davenport iowa
P
P
davenport iowa
if you are doing like me a single turbo 440 inch at the minimum go with an 88 mil
383 or 400 the same. i have 8.32 comp i should have done 10.0 comp i am learning from gino who i got the turbo from he is a grudge racer who really knows his [censored] about turbo cars and he is a dealer for precision turbos.
Re: test pic 68 turbo dart project [Re: paul69cuda] #1941339
10/29/15 10:56 PM
10/29/15 10:56 PM
davenport iowa
P
P
davenport iowa
anyone used a boost leash boost control unit
Re: test pic 68 turbo dart project [Re: paul69cuda] #1941447
10/30/15 01:05 AM
10/30/15 01:05 AM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I run the AMS 1000 boost controller. It's a C02 system.
Re: test pic 68 turbo dart project [Re: paul69cuda] #1944081
11/03/15 12:19 AM
11/03/15 12:19 AM
davenport iowa
P
P
davenport iowa
how do you like it
Re: test pic 68 turbo dart project [Re: paul69cuda] #2207504
12/04/16 12:41 PM
12/04/16 12:41 PM
davenport iowa
P
P
davenport iowa
[img:center][/im [i [email][/email] [url=][/url]
[list]
[*] mg][/img] g]
Re: test pic 68 turbo dart project [Re: paul69cuda] #2207507
12/04/16 12:43 PM
12/04/16 12:43 PM
davenport iowa
P
P
davenport iowa
[list]
[*] [url=][/url]
Re: test pic 68 turbo dart project [Re: paul69cuda] #2207522
12/04/16 01:04 PM
12/04/16 01:04 PM
davenport iowa
P
P
davenport iowa
[list]
[*] [url=][/url]
Re: test pic 68 turbo dart project [Re: paul69cuda] #2207523
12/04/16 01:06 PM
12/04/16 01:06 PM
davenport iowa
P
P
davenport iowa
[list]
[*] [url=][/url]
